Sony Trinitron WEGA
We have a Sony WEGA Trinitron Color TV, Model KV24FV12, we have it connected to satellite, the picture has stated to go on and off, that is, we are watching TV and it will go black for a half second and come back on. This set is 7 years old. What is the problem? Get it fixed or buy another one?
  • 3130 Answers
SOURCE: Sony Trinitron TV will not turn on
First thing that comes to mind is that the horizontal driver transformer has bad solder connections on the primary and the secondary windings. Also a set this old could also have a defective regulator IC if you dont know wht m saying , b=est thing to do is find out how much an estimate is then go back to best buy and see what a new set cost cause man you got your moneys worth outa this one for sure!!!!! Good Luck
Posted on May 02, 2006
  • 3130 Answers
SOURCE: Sony TV - Loss of half the picture
sarge, it sounds like the vertical output IC went bad on you. If it was a bad connection or a bad capacitor, your picture would have been a straght line across the screen. They call the output section of the IC a push-pull type of amp, so the top half of the sweep IC went out. If you have had some soldering experience, and or experience with solid state repair, locating the bad IC and replacing it is no big deal. If you havent, stay safe and call in a pro to assist you in this repair, as there is alot of high voltage inside this puppy that is still present even if the set is unplugged. It should not cost an arm or a leg to repair this set. An honest repair on a set like this if you take it in should not exced 125 to 150 bucks. Good Luck PS Please dont forget to rate this thread.
Posted on Oct 22, 2006
  • 398 Answers
SOURCE: Sony Trinitron KV-32S40 32" TV problem
This is a simple and common problem. The solder joints on the vertical output IC have cracked loose. I actually did a housecall on the exact same set with the exact same symptoms this morning! A good tech will resolder the pins of the vertical output IC and all other major solder joints on the main board and the set will play fine.
Posted on Sep 30, 2007
  • 116 Answers
SOURCE: Sony FD Trinitron Wega
The power supply board is failing. There are twi integrated circuits in the horizontal drive circuitry that have to be replaced. The original integrated circuits are the same type and you will see written on each..."MCZ3001D" and need to be replaced with Sony # 670581001 or the "D" board with those parts on it needs to be replaced. The cost of the entire board is high-about $375.
Posted on Mar 01, 2008
  • 375 Answers
SOURCE: Sony fd trinitron 36 in kv-36fv26 wega
check the ic mounted on the neck board.
Posted on Mar 27, 2008
Sony FD Trinitron WEGA KV-32FS120 32
Check and replace the CRT base connecting socket.
May 17, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony TV trinitron wega 42 inch picture is red. Is there any solution to remove the problem?
The problem with your TV trinitron wega is at the color adjustment section. It is located at the color board mounted at the back of the picture tube. There are variable resistors that represents the color pattern in the picture tube. Adjust the red color to low level to lower the red color.
Nov 03, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
I accidently pushed something on the remote to my sony wega trinitron and now it says 'no signal' I don't know how to get the picture back
You probably switched the TV from analogue to digital mode or vice-versa.
There should be a small button on your remote control marked DTV or ATV. Try pressing this.
If you are using a separate cable/satellite/tuner box from a SCART cable, turn off the tv, and turn off the cable/satellite box. Then turn the TV back on, then the cable/satellite box back on. The TV should recognise there is an external input and you should be OK.
Oct 16, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No color on sony wega trinitron when hooked up to satellite, but plays movies in color
Try reprogaming your tv. And be sure you do not use a super video cord along side a yellow rca jack or components cords in the same aux. Check it out!
Nov 29, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Green screen and distorted picture sound is good but no picture
It must be connected with the color circuit of your tv, a board connected to back end of the tube. Could be dust, cob web or carbon deposit shorting a transistor. Popping noise if loud enough can be attributed to high voltage circuit fault and picture tube.
Have it service by a qualified person.
Apr 04, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony FD Trinitron Wega model KV-34BR800
Sony Wega Triniton KV-32FS100 TV
For the last week my TV has been going to a black screen for 10 seconds or so then the picture returns. It has been continual. Last night it stopped going to black screen, but now the standby light flashes 5 consecutive times and the color went haywire. A lot of red and everything that is suppose to be black is green.
I did a soft and hard reset with no success. What's wrong and is it worth fixing? Bought new in November 2002.
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony FD Trinitron WEGA KV-24FS120 24" TV Color changes
Try turning down (off) the color during such an episode. If the image is tinted pink or green instead of black and white when you do this,you have either an intermittent short in your CRT (tube), which is terminal,or a gun drive problem, which may be repairable. If you're feeding it component instead of composite signal,it may just be a bad connection of the B-Y cable.
Mar 19, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony Trinitron Kv24Fv12
stand by timer light flashes 7 times no pic no sound. how do i
stop timer
Apr 09, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sonny tv triniton
Buddy, Not a problem for the average Home Technician. Unless you are good at Solid state Electronics service. Problem is faulty Red Outpuit Transistor or associated components. Best to seek professional hellp.
Mar 31, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Monitor colours are only fluro purple & green!
use a 10 ins, speaker magnet to front of picture tube degussing color
Nov 29, 2006 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
