Question about Microwave Ovens
Daewoo Microwave Rangehood
I turn the microwave to any setting and it runs through without a problem, but immediately after it finishes cooking the screen goes blank and none of the controls work. After about 10 minutes everything comes back on again. Any suggestions. The unit is brand new.
  • Grumpy32 Dec 30, 2007
    Nope. New house and outlet is breaker blown....anything else it could be....simple solution. Thanks. Could it be connection in the microwave itself? Warranty may be a problem as it was purchased in the States and I live in Canada.
  • Anonymous Mar 20, 2014
    Brand new unit
I was cooking on stove and the vent was running then all of a sudden the microwave shut off and
not won't work at all. Nothing comes on?
Posted on Nov 22, 2008
  • 236 Answers
Please check your ac outlet may be loose, try for another outlet for testing.
Posted on Dec 30, 2007
  • Felizardo Erilla
    Felizardo Erilla Dec 31, 2007
    then I think your right it maybe in the microwave itself, the last solution for that is the to call for qualified technician.
Genius S333 refer to manual error after 3 seconds
If microwave runs only without turn table, I am suggest to check if turntable electric motor has got short circuit. If yes, I have some left.
Nov 13, 2013 | Microwave Ovens
Hotpoint Microwave Model RVM1435BD 001- microwave comes on when I open the door.
Many microwaves have similar issues. Usually, (not always) only the light is on and the fan is running, not the section that produces the microwaves. This problem can be caused by the door switches that are out of alignment or a defective control board.
Nov 14, 2017 | Hotpoint Microwave Ovens
GE Microwave (JVM1860CD001) control board buzzes.
see this causes and fix it. God bless you
Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Exhaust Fan Motor If the microwave is loud when running the fan motor might be
Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Oct 10, 2012 | GE Microwave Ovens
Burns my popcorn constantly. is there a different setting i can put it on?
Solution to your microwave problem is given as below.
* 1 Set your Daewoo microwave on a countertop near an electrical outlet and plug it in. Open the door and place the circular roller guide in the center of the oven cavity, then place the glass cooking tray over it.
* 2 Set your food on a microwave-safe dish and then put the dish on the cooking tray and close the door. Make sure that it latches properly.
* 3 Turn the upper knob to select a power level. Power levels include "Defrost," "Med-High," or "High." If your Daewoo has a touch pad, touch the "Microwave" button once to set the highest power level. Touch it consecutive times to lower the power level.
* 4 Turn the lower knob to set the cooking time. For cooking times less than two minutes, turn the knob up past the two-minute mark, then back to the correct time. For touch pad models, enter in the cooking time with the numerical keys and then press "Start."
* 5 Open the door at any time to stop the cooking and check the temperature of your food. Shut the door to automatically continue cooking, or turn the timer knob to the right to add more time. For touch pads, press the "Stop/Clear" button, then key in a new cooking time and press "Start."
* 6 Open the door when the timer reaches the "Off" position and take out your food.
Sep 24, 2011 | Daewoo KOC-925T Microwave Oven
Occassionally (about 5% of the time) the microwave continues to cook and buzz after the timer has run out and the fan stops running.
sounds like the program bord is faulty,, when your finished cooking leave the door open a little that will save the microwave from trying to cook nothing?
Aug 28, 2010 | Whirlpool GT4175S Microwave Oven
Not heating up
weve found its not worth repairing microwaves
Jun 29, 2010 | Daewoo KOC-925T Microwave Oven
Microoven model 860A is not getting heated
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
Feb 25, 2010 | Daewoo KOR-860A Microwave Oven
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
Daewoo microwave that won't cook
More than likely a door switch inside the unit is misalligned or faulty. Crack it open and check for proper allignment and good open/closed circuits with a VOM.
Sep 24, 2008 | Daewoo Microwave Ovens
Microwave Ovens Logo
77 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
