Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite 3T - clean drain pump filter
How do you get to the filter talked about in some of the threads. Thanks a lot for your help!
  • 2 more comments
  • Tom Pessemier Dec 30, 2007
    Thanks for your fast response to this question. Can you tell me if it's the top or bottom panel I need to remove to access the pump? Also, is the filter attached to the pump, or will that be obvious. Sorry, I'm new to this appliance repair thing. :) Thanks!
  • Tom Pessemier Jan 02, 2008
    I found the filter. You have to take the lower panel off with three machine screws at the bottom of the washer. Then you just twist the white cap counterclockwise until water oozes out onto the towels you had previously put under it. Thanks again.
  • Anonymous Sep 15, 2008
    I have a Kenmore Elite that is 7 years old. My problem is that I need to change the filter and don't know how to get to it. Also will changing the filter help if I have cilt in my water from my septic tank?
  • Anonymous Mar 29, 2014
    How do I clean the HE 3t pump
Take the front panel off and there is a pump, be sure that you have towels or a bucket, there will be excess water and junk since it is clogged
Posted on Dec 30, 2007
Why does thread keep breaking when I try to sew?
First thing, install a brand new needle.
Second, try loosening the upper tension. The ideal tension is when the upper thread and bobbin thread meet in the middle of the fabric.
If the thread is constantly breaking, usually the cause is incorrect threading or the thread has jumped out of a guide, or is wrapping around something like the thread spindle. Remove the thread from the top of the machine, RAISE the presser foot, and rethread the upper thread from the beginning.
If the thread is shredding at the needle's eye and then breaking, it is usually an incompatibility of the thread, needle, and fabric or the tension is too tight.
This may help with needle/thread choices:
http://www.schmetzneedles.com/all-about-needles/
Nov 13, 2015 | Sewing Machines
91 Honda 2.2 camshaft torque specs
Thanks a bunch for sharing this with all folks you sincerely understand what you're talking about. that is for all and sundry, I made this torque spec thread when you consider that I and lots of others here always ask approximately torque specs. discover myself searching trough all my Haynes and Chilton books for torque specs even as I understand i will make a list like this one to make it less complicated.
Expert Custom Essay Services
Feb 21, 2015 | 1991 Honda Accord
I have a singer ultralock 14u34. The lower looper will not stay threaded when I try to sew, just works for an inch then nothing is catghing and the looper is no longer threaded.
Some sergers will unthread themselves if the thread is not threaded through the throat plate right. Especially the lower looper because there is not a lot of space for it to move. Try bringing the thread from the looper straight up through the hole in the throat plate, not to the side of the plate. You can also talk to the professionals at the link that I have attached. They are very helpful and easy to work with. Good luck Sewing Machine Repair Repair Sewing Machines Sewing Machines Repair Fix...
Jan 25, 2015 | Singer Sewing Machines
Dear Sir/Madam, I have a Feiya CT 904 & CT 902. The agent i bought the machine from forgot to give me the password for the two machines. After using the machine for about a month,the machine is as
Are you looking for a password or a thread problem? I'd talk to your agent for the passwords. The description about the thread cuts, the machine stops until the thread is put back doesn't make a lot of sense to me. A little more description would be helpful. Is the thread breaking, or do you have an auto-snip/cut feature?
Feb 22, 2013 | Sewing Machines
I own a singer machine with the no of 6110 on the front. I have had it to a shop twice now. The bottom thread is loose on the stitches as in loped not like the top thread. Please help Thanks!!!!!
Sounds like your tension is not set correctly or your threads are not threaded correctly. Try putting tension to all zeros or re-threading the top and bottom threads. Changing the needle also sometimes helps as a blunt needle does a lot of damage
Dec 08, 2010 | Singer Sewing Machines
I have a '77 cadi with 425cid and quadrajet carb. Rebuilt the carb and works great but there is a pretty good fuel leek at the filter, coming through the threads. Tried plumbers tape on the threads ,...
you can go to the parts store they have a repair kit you can buy to fix your problem,It is a common problem that they have,the repair kit is motormite and the part number is 55124, I hope this helps you and please vote on this solution,have a happy new year
Dec 29, 2009 | 1976 Cadillac Deville
Fuel leaks out of the bottom of fuel filter
Did you recently replace the filter?
If so it needs to be tightened
If not it needs replaced
If it is the style that threads instead of clips then becarefull not to cross thread it.
Mar 29, 2009 | 1995 Chevrolet Silverado 2500
How to thread my 535fa
I don't even know where to start. Send me you're email address and I'll get back to you with my phone number as I don't want to post it for the world to see. I'll be able to talk you through it.
Feb 20, 2009 | Necchi 3537 Mechanical Sewing Machine
Bobbin thread is loose and looping
Okay it is the tension scrow on the bobbin. There is a small screw on the bobbin and by tightening it it gives you more tension on the bobbin.
Dec 24, 2007 | Brother LS-2125 Mechanical Sewing Machine
Kenmore Elite 45986 Front Load Washer Logo
325 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
