You can download the audio driver for your model laptop from this WEB site. http://fujitsufmv.blogspot.com.au/2012/10/fujitsu-fmv-c8220-drivers-bios-bundled_12.html
As you have mentioned that you have a desktop PC . So you need a wifi lan card to access the wireless router. Then you can access the internet through your wifi router. You can buy a wifi lan card for the same and go for Netgear GA311 for the same. Hopefully it will help you.
Sorry you are having so much trouble... If you are looking for HARDWARE, the following site is not for you. If you are looking for software drivers, then go here: (copy the entire address below and paste it in to the address bar)
first check for all the drivers in the device manager....
if every thing is perfect in driver side, then check if the ethernet/ lan is enabled....
then check is the light in the ethernet adapter is lit, when you plug any ethenet cable in it...
still if it is not working, then finally try to update the latest driver for the ethernet controller....
if nothing works, then buy an pci ethernet card and use it.....
you can also buy external cards like usb to ethernet converter...
even belkin manufactures usb to ethernet controller....
buying a lan card is costly..........u can hav the same adv by buying a modem of bsnl which has lan and wifi for the same rate which is usb connected to the comp
