Question about Miele CVA4070 Coffee Maker
Machine froze when cleaning
CVA 4070 froze when the cleaning process was at 4th minute. It was not actually running a clean and at 4 min just stopped doing anything. Display shows CLEANING, but nothing happens and it is impossible to resent it, but turning of the power supply. ANy suggestions?
  • Anonymous Apr 04, 2009
    I have te exact same problem
  • 5 Answers
Call 800-999-1360
Posted on Aug 07, 2008
My miele coffee maker CVA 4070 dispensing tubes are clogged
I had this problem ... you need to remove the dispenser from the rear of the door. Then once removed clean in running water. Its a sealed unit but you can squirt high pressure water inside to dislodge the coffee sludge. When clean .. fill with water and make sure the 2 spouts drain evenly. regards
Jul 09, 2014 | Miele CVA4070 Coffee Maker
My miele coffee maker CVA 4070 how do I reset when it's locked in descaling
When you start the cleaning cycle, Don't stop the process by pulling the plug! Turnthe unit off from inside wait 5+ seconds & turn back on and thecleaning cycle should restart... If you do not use a cleaning TAB..Open& shut the LOOSE coffee Door under the drawer (Top Left) and thecycle will continue.
Cva 4070 drip tray issue
Miele CVA 4066 -Empty drip tray warning would not go off even after draining the drip tray, cleaning contacts, and resetting power. Water was coming out from under the empty tray.
I pulled unit out and removed sheet metal in rear around water inlet. when I attached water line and power cord & turned on power, I could see water dripping out of one of the 2 solonoids on the water inlet valve. $168.00 from Miele and no expensive service call.
May 27, 2012 | Miele CVA4070 Coffee Maker
My cva 4070 is only providing steam when I request milk froth. How can I fix this problem
your frothing mechanism is clogged with dried milk. The chrome spout and black rubber hose come off by turning the plastic collar and pulling down. refer to your manual for pictures and step by step cleaning and maintenance instructions. your machine came with a cheat sheet card that is yellow and has a clear plastic laminate over it. it was in the box with the accessories. refer to that for an exploded view of your frothing mech.
May 10, 2011 | Miele CVA4070 Coffee Maker
Descaling process counts down on the displat but no solution is running through the unit and thr counter stops on 1 min remaining
This is normal behavior, your machine is fine.
For example, the machine says "5 minutes remaining" and then it goes 5:00, 4:59, 4:58....etc all the way down to 4:01.Then it changes to "4 minutes remaining". Which is 4:00, 3:59, 3:58, etc.
So at "1 minute remaining" the machine is really at 1:00, then 0:59, then 0:58 and all the way down to 0:01.So, after the "1 minute remaining" goes away, the machine is actually done cleaning itself.
May 08, 2011 | Miele CVA 4066 Stainless Steel
How do i clean my miele coffee system cva 4070?
I have a cva4075 so this may not be exactly the same, but on the 4075 you open the front of the machine and pull out the left hand plastic container on the top. Underneath on the right hand side you will see a small flap. On the bottom side of the flap is a red triangle sign. That flap is the top of the funnel for the ground coffee. You drop the cleaning tablet into this funnel.
Apr 12, 2009 | Miele Coffee Makers & Espresso Machines
I need directions to clean my miele CVA 4070
The cleaning instructions are on page 34-45 of the owners manual =>
Please leave feedback. Thank you.
Dec 11, 2008 | Miele CVA4070 Coffee Maker
Miele CVA 4070 coffee system
I called Miele hot line & here is the solution to fixed the problem... 800-999-1360.
Whenyou start the cleaning cycle, Don't stop the process by pulling the plug! Turnthe unit off from inside wait 5+ seconds & turn back on and thecleaning cycle should restart... If you do not use a cleaning TAB..Open& shut the LOOSE coffee Door under the drawer (Top Left) and thecycle will continue.
Aug 25, 2008 | Miele CVA4070 Coffee Maker
Miele coffee maker cva 4070
OK. Here's the deal. I struggled with this CVA 4070 (F 73) problem also recently, and even posted a questions in the cyber world about it. I jiggled, re-cleaned the machine, re-read the Miele manual, and scoured the internet for schematic drawings of this brewing unit's insides. No luck. Finally after finding out I'd have to pay $199 just for a service clown to walk in my front door, I said NYET!!!  I must solve by myself. If I can take apart & fix my Dyson, etc, etc, I WILL DO THIS TOO!!  (MUST HAVE COFFEE>>>)
Pull out the brewer, turn it a quarter-turn to your right, and look at the spot where that small black plastic piece -- shaped like a block "M" or block "W" -- should be situated. Pull it out, if it isn't out already. Don't worry about yanking it out or harming these parts, said the Miele troubleshooter guy in New Jersey on the phone. They're "made from the same plastic used in football helmets."  Okey-dokey.
This approx. 1.5" wide, blocky plastic piece is part of the "slide" that takes the brewed coffee grounds into the waste container. When positioned correctly, it looks like a block "W,"  with the "wings" ointing up, and slides in just under a brown 1.5" flat piece. A small, down-facing tab on the brown piece clicks into the "W" piece and holds it in place. The "W" should feel fairly solid, although it is not rigidly in place, as the entire mechanism is a movable system to deposit the grounds in the waste receptacle.
Put everything back inside your CVA 4070 "love" machine, hit "on," and wait for it to go through its warm-up.  No F73 message?  Yeah!  Mission Accomplished. You, like I, have fixed your Miele, saved your family relationships, and saved yourself a bundle from unnecessary service calls.
Feb 27, 2008 | Miele CVA4070 Coffee Maker
Miele CVA4070 Coffee Maker Logo
482 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
