When the call has gone through, try changing the volume. If it says "Earpiece-Earjack Mode", the phone 'thinks' something is plugged into the data/charging port. Try using a clean toothbrush with a very small amount of alcohol on it (90% isopropyl is best) and brushing the port vigorously. If using 70% alcohol, use dust off or someother cnned air to dry he port out. If you are still having he issue, damaged is inside the phone and probably can't be fixed.
