Question about Lexmark P4350 All-In-One InkJet Printer
Lexmark Hi, when I print or scan with my lexmark P4350 the first 2 inches from the left margin are almost invisible. any idea how to solve this. The machine It's pretty new, I must have used it maximum 20 times. Thanks a lot. Davide
  • 233 Answers
Re-seat the cartridges
Posted on Jan 04, 2008
Why doesn't it print on LABELS at the top of the page?
I share a link please visit and follow step by step instruction.
I hope solved your issues.
http://ulearnoffice.com/word/printing.htm
Thanks,
HP Printer Support
May 30, 2014 | HP LaserJet 1020 Printer
How do I change margin setrtings foe Lexmark P4350
If you are preparing to print a document that you have created in Microsoft Word, you may be concerned that all the text on the page will print exactly as you see it on your screen. This is not always the case. You can adjust your print margins to ensure that your text prints on each page exactly the way you would like it to appear.
Opening Your Document
Open your Microsoft Word document by double-clicking the Word icon on your desktop. If you do not see the icon on your desktop, then you can locate it where it is buried on your "Start" menu. Click "Start," followed by "All Programs." Then click "Microsoft Office," followed by "Microsoft Office Word." A new document will open on your screen. Click the "Office Button," followed by "Open." Scroll through the files listed, and double-click the one you would like to print. It will open on your screen.
Check Your Margins
By default, your page margins are set to 1-inch margins on the top, bottom, right and left of your page. You can check your margins or change them by clicking "Page Layout," followed by the "Margins" button.
Select New Margins
Select a different margin size, such as "Narrow," which indicate 1/2-inch margins, or "Wide," which indicate one-inch margins on the top and bottom and two-inch margins on the left and right. You also can select "Moderate," which indicate one-inch margins on the top and bottom and 3/4-inch margins on the left and right. Finally, you can select "Mirrored," which indicates one-inch margins for the top, bottom and outside. The inside margins are set at 1 1/4 inches.
Print Your Page
Print your page. Press "Control" plus the "P" button. The printer dialog menu will come up. Make sure that "All Pages in Range" is selected. Press "OK." If your printer cannot print your new margins, then a new menu will pop up telling you to adjust your margins.
I hope you find it very helpful. Best regards.
Aug 22, 2011 | Lexmark P4350 All-In-One InkJet Printer
Print en enveolppe with hp color laser jet 2600n
Envelopes can be printed from tray 1 or 2. Select the type of envelope you are using from the PRINT dialog box or the driver. In your program, set the margins. Typical margins for a commercial #10 or DL envelope would be: Return Address Top margin 15mm(0.6 Inch) Left margin 15mm(0.6 Inch), Delivery Address Top margin 51mm(2 Inches) Left margin 89mm(3.5 Inches). For the best print quality, position margins no closer than 15mm (0.6 Inch) from the edges of the envelope. Avoid printing on the seams of the envelope. Envelopes with a peel-off adhesive strip or more than one flap that folds over to seal must use adhesives that are compatible with the heat and pressure of the printer fuser. the extra flaps and seals can cause wrinkling, creasing and feed jams, could even damage the fuser.
Apr 15, 2009 | HP Color LaserJet 2600n Printer
Lexmark x4550
That usually means that the document with the border has margins that are outside the printable range of the printer. Try temporarily setting the margins to 1" all the way around and try again. If that solves the issue then you can decrease the margin to your desired setting.
Thanks
Aug 03, 2008 | Lexmark P4350 All-In-One InkJet Printer
Printer cuts off top 1 inch of PDF document
Go to the printer properties and try setting it up with border less printing.
Cheers
May 23, 2008 | Lexmark X4270 All-In-One InkJet Printer
Hi just got a lexmark X2550 INTALLED IT AFTER TURNING OFF ANTIVIRUS LIKE IT SAYS PTINTED OFF FIRST PAGE THEN PUT IN SCANNER LIKE IT ASKED SCANNED IT BUT WILL NOT PRINT IT OFF I HAVE REINSTALLED BUT STILL...
The Epson's USB cable would also work with the Lexmark. The 1st time print and scan, to my knowledge, will not really print but align the print heads. You can try to print a Windows test print by going to Start, Printers & Faxes, right click on Lexmark X2250, left click on Properties, and left click on the Print Test Page button.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 19, 2008 | Lexmark Office Equipment & Supplies
Printing Borderless at 42" width?
Set the roll size to 44 inch, set your left margin to 0 (in your preprint software), experiment. With margins set at 0, using Onyx Productionhouse 7.3, the 9800 will print approx 41.8 inch image on 42 inch roll 43.8 on 44, etc. This is considered borderless printing. No matter what size roll you tell the printer it has in it, it will print to about an eighth to a sixteenth of an inch short of the paper's actual edge (that's the left side of the roll paper coming out of the printer - the right side of the print). If you load, for example, a 36 inch roll, tell the printer its a 44 inch roll, and send a 40 inch wide print, with a left margin of 0 it will print around 35.8 inches, cutting off the image just before it would overprint and get ink on the machine (1/8 - 1/16inch before the edge of your 36 inch stock). It is possible that these tollerances will be different depending on what software you send your images with... hope this helps!
May 08, 2008 | Epson Stylus Pro 9800 InkJet Printer
Scanning document leaves streak down right hand side
hmm this has happened before
make sure it is sitting straight and cleaning it might help
Jan 07, 2008 | HP PSC 1315xi All-in-One Printer
Epson TM-T88IV causing small margins when printing to Lexmark 250dn
PRINTER WORKS BUT prints the moment I scan a item,WHICH I DONT WANT. I WANT IT TO PRINT ONLY IF I NEED TO
Aug 03, 2007 | Epson TM-T88IV Label Printer
Lexmark P4350 All-In-One InkJet Printer Logo
77 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
