Question about Panasonic CT-36D32 36" TV
TV turnes its self off
My TV shuts its self off for about 3 minutes and then back on for about 10 minutes. I took the back off of the TV and it stays on all of the time. Seems to be getting hot? I took air and cleaned all of the dust out but did not help. Any suggestions?
  • 373 Answers
Sounds like you have a bad solder connection. Since you had the back off can you slide the chassis out not forcing anything and may have to unplug a couple of plugs to get it out and turn the chassis upside down carefully and with a magnifying glass look for bad connections in the solder If you see obvious bad connections they can be soldered with rosin core solder and soldering iron used in electronics. Put the hot iron on the bad connection first to heat it up and then apply solder letting it flow over the connection. let cool and solidify. Hope this helps
Posted on Dec 30, 2007
Tv shuts off itself
If it does not have any sleep timers set then it is malfunctioning and needs to be replaced.
Aug 19, 2014 | RCA F32650 32" TV
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
I have Toshiba TV Model #65HM167. The problem is when I turn it on - it will stay on for 30m to 3 hrs, and then just shut it self down. I pull the power cord for 30 minutes and then plug it back in and it...
check the fan to make is working properly. It's in the lamp compartment on the left side of the unit. clean the vent on the rear unit and the fan fin's gently. good luck
Dec 13, 2009 | Toshiba 50HM66 52" Television
Olevia 332h comes on for a few minutes then turns off
I have the same problem with my Olevia 332h. The TV shuts off after 10 seconds. I decided to wedge a desk fan in between the wall and the back of the TV. It worked! The TV doesnt shut off anymore. This problem is obviously heat related. I hope this information helps you.
Jun 03, 2009 | Olevia LT23HVX 23 in. LCD Television
RCA P52937SG
Time to replace.
Mar 10, 2017 | Televison & Video
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Shutting off and on...
the problem may be due to dry soldering in the power supply stage if it was with the lamp there would be red or green light showing the presence of the power to the tv after making it own some of the components get hot and it will make the the soldering point conectionless and after some time the heat sink get cooled and the soldering point gets connected and u will see the picture again it is a simple problem if u have a soldering iron u make it hot and re solder all the components in the first part of the circuit board and the problem if rectified
Jul 03, 2007 | LG RU52SZ30 52" Television
Panasonic CT-36D32 36" TV Logo
96 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
