Question about GE 32GT660 32" TV
Unstable signal Picked it up at a garage sale. Picture was beautiful. Brought it home, plugged it into our cable and it says unstable signal. What the heck did we do to it?
  • 373 Answers
Are you sure it says unusable signal instead of unstable signal.
This means that you have the wrong input in place in the tv. If you got the original remote with it there may be an input button. on it. Some RCA's use 00 for the video input. If your cable goes directly to the antenna connector on the back you should get all channels when you do auto search in the menu provided you have the right input programmed. If you are using a cable box the tv must be on channel 3 or 4. video input uses rca cables red white and yellow to the proper input on the tv but there again the input must be set correctly. Possibly in the menu do a search there. Hope this helps.
Posted on Dec 30, 2007
21FU2RLX. Why does the picture become unstable after TV has been operating for some time?
check the aeriel is in good condition and is providing a good signal. Reset the tv to factory default and et it up from scratch. Check the tv is well ventilated.
If you do all of these and the set behaves badly after a period of use I would think you either have a component fault or it is behaving badly because heat mau be building up in a particular component or circuit which is why it only becomes unstable after a while.
Jul 19, 2015 | LG Televison & Video
My pictur on my tv looks like it is snowing how can I fix it
try to watch a movie that doesnt contain snowing...
If you mean white pixels for no reason on the screen while whatching the tv it can be caused by unstable power, or tv signal.
try to remove tv cable, then replug it so the picture will clear
Apr 13, 2013 | Televison & Video
Unstable picture
The x-box is likely connected to a rear input on the set, try doing that yourself--by the way what is brand and model number?
Does it do this when on screen display (menu etc) are called up?
Dec 10, 2012 | Televison & Video
Unstable connection
ome wireless networks based on the 802.11b or 802.11g standards transmit their signal in a narrow radio frequency range of 2.4 GHz. Various other electronic devices in a home, such as cordless phones, garage door openers, baby monitors, and microwave ovens, may use this same frequency range. Any such device can interfere with a Wi-FI home network, slowing down its performance and potentially breaking network connections.
The 2.4 GHz Wi-Fi signal range is divided into a number of smaller bands or "channels," similar to television channels.Many wireless products ship with a default Wi-Fi channel of 6. If encountering interference from other devices within the home, consider changing the channel up or down to avoid it. Some Wi-Fi channel numbers overlap with each other. Channel 1 uses the lowest frequency band and each subsequent channel increases the frequency slightly. Therefore, the further apart two channel numbers are, the less the degree of overlap and likelihood of interference.
If this won't work, Then consider buying a new wireless router as your current is deemed broken.
Nov 21, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Unstable signal on a SONY KDF-50E2000 08760591
Can you please explain what you mean by an unstable signal? Without details, the problem can be anything from a weak signal being presented to the tuner to a defective tuner to poor signal processing later on. Also, check the picture and sound using different inputs to the set. If hte problem is the same regardless of hte input signal, that tells us that the problem is in the video signal processing circuitry. Also, place a menu on the screen. Is the instability present with the menu display?
Thanks,
Dan
Nov 04, 2009 | Sony KDF-50E2000 50" HDTV
Rolling of picture
You camera is PAL and you are attaching with Ntsc TV or VCR. Both Pal and Ntsc are different systems and incompatible to each other.
If you want to see correct playback of your Camera, it requires Pal or Multi-System color TV.
Need further info, please let me know.
Oct 04, 2008 | Sony Handycam CCD-TRV68 Camcorder
Picture on email is unstable looks shaky.
if u have graphics card means jus remove it and connect it in the ordinary pin
Jul 03, 2008 | E-Machines eMachines Desktop PC
Televison & Video Logo
199 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
