Back to:
Tags:
Rainbow E series Canister Wet/Dry Vacuum
Rainbow e series
posted by mrka on Dec 29, 2007
Hi, A couple of weeks ago my separator broke one small piece, but it still runs. The problem is when it runs for about 3 min. it smells like something electrical getting hot...whould the separator cause this problem.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jan 15, 2008
Not Rated (0)
reddevil6
Rank:Guru Guru
Rating: 88%, 1194 votes
It could if the separator is binding, or dragging, when it turns, causing the motor to over heat, that maybe what you are smelling. If it is, then replace the separator.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on rainbow e series:
I don't want to Accept this solution
Can you Help with these Vacuums problems?
Once in a while it will make a real faint noise the...
the silver disks or fans how do they go back together
the power nozzel or main unit of the rainbow e series has...
whenever i try to dispense water out of my wet vac the...
was just using it today and turned it off for a moment and...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
