Question about Maytag MER6769 Gemini Electric Kitchen Range
F1-6 Fault Code
We have a Maytag MER6769BA Gemini Electric Range and were boling water (back left burn) when the it started beeping. There was also a message that started scrolling across the display showing the "F1-6 Call authorized servicer or dealer 888-462-9824". The manual calls it a fault code and said to hit cancel. If it continues, disconnect power and wait a few minutes, than reconnect. If it continues call authorized servicer. I disconnected and it appears to have solved it but still would like to know what F1-6 means, any clue?
  • Anonymous Dec 10, 2008
    I was boiling water on the back burner of my Maytag mer5730aaa glasstop range when it beeped and flashed f1 I disconnected the power then turned back on like it said to do but now only my burners work and not my oven. Why?
  • Anonymous Mar 08, 2009
    its meking noice and its shoing f1
    Scholar:
  • 196 Answers
This code is in responce to a fault/failure in the lower keypad assembly. It is possible the keypad was bumped.
Maytag Gemini fault codes.
Fault code Suspect area Fault code Suspect area
F0 - 0 None
F1 - 1 Runaway cook upper oven
F1 - 2 Runaway cook lower oven
F1 - 3 Runaway clean upper oven
F1 - 4 Runaway clean lower oven
F1 - 5 Keypad cancel upper
F1 - 6 Keypad cancel lower
F1 - 7 Keypad disconnected
F1 - 8 Keypad shorted
F1 - 9 Slave
Posted on Dec 30, 2007
We have a Maytag Gemini electric range. It has
My wife has been complaining of the same thing happening with our Gemini electric oven! I am not aware of a recall, but would also be interested to here if there is one!
Jul 14, 2010 | Maytag MER6772 Gemini Electric Kitchen...
How do i get fault codes for maytag gemini?
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, there is an "Error Code" link listed under the Special Features section. The Maytag Gemini series fault codes are listed there. You can print the list for FREE. I hope this helps you.
Sep 11, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Gemini range: Back left on range top does not
Check the surface element for continuity.
Check the surface element receptacle for a good contact and voltage..
Check the surface element switch for voltage and continuity.
Mar 09, 2009 | Maytag MER6549 Gemini Electric Kitchen...
Maytag gemini f1-9 error
plug it back in and press the cancel button
Mar 31, 2008 | Maytag MER6772 Gemini Electric Kitchen...
GE oven range showing F9 fault code and beeps annoyingly
problem is listed as a door lock/latch issue check wiring to the door lock assy(which is usually fine) generaaly requires replacing the self clean latch assy
Mar 11, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini Electric stove fault code F 1-2 when using the oven(s)
The oven temp sensor has gone bad.  F1-2 would be for the lower oven and F1-1 would mean the upper oven.  If you give me the model # from the sticker on the oven I can direct you to a diagram, part #, and price.  These are very easy to replace.  Should be located inside the oven in the upper right or left hand side.  It looks like a silver rod about 4-8 inches long and crimped on the end.  Most of them can be removed from inside the oven by removing the two screws, pull out the sensor (harness and all) plug in the new sensor, put the screws back in and your done.  Some have to be removed from the back of the oven by removing the lower, larger back panel and follow the same process as mentioned above.  Hope this helps.
Oct 19, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6769 Gemini Electric Kitchen Range Logo
2,894 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
