Question about Logitech R-10 Computer Speakers
No sound out of speaker(the one with the volume control on it
I am not getting any sound out of the speaker with the volume control on it, i have tried unplugging it and plugging it back in, still nothing. The balance is also centered, please help!!!
  • 1 more comment
  • Anonymous Jan 05, 2008
    I CAN'T HEAR NOTHING
  • Anonymous Jan 06, 2009
    i got advent portable speakers as a present for christmas! i wanted them for a Patroit PC with windows XP home edition just wondering if they should work cos they're not working for me?????
    CAN ANYONE HELP
    My email is mairead8116@gmail.com
  • kimquan22 Feb 14, 2009
    logitech x - 120
    Novelist:
  • 108 Answers
I'm taking it that from what you're saying, the other speaker is working perfectly.
here are a few things you could try, if this is the case. You've probably attempted most of them, but it doesn't hurt to cover all your bases.
Turn both your speakers, and windows Volume Control up full blast. (while you're within the Volume Control window, it wouldn't hurt to check to see if the balance is off there, as well). Put your ear to the speaker, and listen hard- do you hear any faint hissing or crackling sound, like static?
If you do, then the speakers are working perfectly on their end. The hissing sound would be power going through them. this can only mean that there is :
a) a problem with the connection to the computer - fiddle around with the cable connecting it, twist it slightly in the socket and look for and *gently* bend any creases you may find back into their proper places, while playing a song. if at any point you hear the other speaker come on, you have your culprit. Also, try plugging a headset or spare set in if you have any, to eliminate the possibility it's a bad jack with the soundcard. if you hear both speakers on your headphones playing, it's NOT the card.
b)a problem with the software you're using to play sounds. again, open up Windows Volume Control, and check the speaker balance there. if the problem occurs only with certain programs, like Winamp or Windows Media Player, open up those programs and check the balance there.
If you, on the other hand, DON'T hear any sound coming
from the speaker in question, or if what happened above doesn't work, it could be a problem with the cable connecting the two speakers together. Play with the audio cable connecting to both of them for a bit, see if you can get them working by repositioning it, again while playing test music.
If the above solutions don't help, you could be looking at a blown speaker, and they may need to be replaced. if you do so, i'd recommend any one of the 2.1 (two speakers and a subwoofer) systems that Logitech sells. they are extremely simple to set up, and have excellent sound for a good price.
Posted on Dec 30, 2007
  • twinkielicio
    twinkielicio Jul 18, 2012
    thank you so much i got them to work there amazing now yes
Rear speaker volume
Check wire connection to rear speakers and ascertain the speakers are properly grounded. Using a multi-tester, there should be "zero" ohms resistance between the speaker ground and a nearby nut, bolt, or metal component part of the receiver. Get a cheap speaker and splice the test speaker to see if there's sound when radio is "on." If there's sound, but you can't control the volume, then the volume control knob is defective. The volume knob is a potentiometer, which is a variable resister identical in principal to the electronic fuel throttle of your vehicle. If volume is controlled by 2 buttons, then the button's circuit are not connected to the main motherboard.
Nov 28, 2013 | Audio Players & Recorders
Computer detects speakers but no sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
Oct 26, 2011 | Durabrand 5.1 Surround Sound Computer...
Cannot get volume on computer
also
Oct 22, 2011 | Audio Players & Recorders
My computer speakers are not producing sound. the pruduct is fujisu semiens
also
Sep 28, 2011 | Audio Players & Recorders
My logitech x530 speakers are not playing
also
Sep 28, 2011 | Logitech X530 5 Speakers
I did some thing nd my speakers are not working
you might muted your sound or deleted the sound drivers
also
Sep 28, 2011 | Logitech X-530 5.1 Speakers
Speakers were working,then i pressed something to see if was gonna sound different and now i cant find my way back to what it was...sound is coming from the computer to the tv,,but external speakers have...
also
hope it helps
Sep 22, 2011 | Logitech X-230 Computer Speakers
I have checked and rechecked the setup and I am getting no sound. I have sound signals from my soundcard but no sound coming from my speakers. They are on. The power cord is plugged into a fonctionnal...
also
hope this helps you
Sep 19, 2011 | Logitech Z-2300 Computer Speakers
I cant get the sound to come out of my speakers. I have checked all conection, ect
also
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 01, 2011 | Logitech LS11 2 Speakers
Sound output is low nowadays even at full volume whereas before it was ok. I didn't change anything with my computer nor did I change my speakers.
Two possible causes.1) Vol Settings changed in windows2) Bad hardware
1) Check your system's sound settings:
For Xp
  • Goto Control Panel
  • Double Click Sound and Audio devices / Sound, Speech, and Audio Devices
  • In device Volume Click Advance
  • Master Volume Control Window will open
  • Increase all the volumes to max, also make sure that Mute us UNCHECKED.
OR
  • From the bottom right corner of your screen in system tray, double click a small speaker icon and open Master Volume Control.
For Vista and Windows 7
  • From system tray (its at bottom right corner of your screen) double click on small speaker icon, it will open Volume mixer
  • Increase the volume to max.
2) If this does not work, then test your speakers by connecting it to some other system and vice versa.
If you get desired sound volume when you connect some other speakers to your system, then you have to change your speakers. And if your speakers are working fine on other system then you may have to purchase a new sound card.
May 17, 2010 | Computers & Internet
Logitech R-10 Computer Speakers Logo
434 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
