Question about Zenith D52WLCD 52" Rear Projection HDTV-Ready Television
Reset lamp clock
We have replaced the lamp in the tv but the warning light will not go out.
zenith has advised us that a repair person has to use a remote unit to reset the clock. if the clock is not reset, the tv will stop working in approximately 30 -60 days.
  • 1 more comment
  • Charty Jan 18, 2008
    Replaced lamp in D52WLCD. Need directions to reset lamp clock
    charlainewood@msn.com
  • Charty May 11, 2010
    Still waiting for solution to reset timer on projection lamp on D52WLCD. Ladywinn was going to post a solution for us. I still need this help.
  • Anonymous Mar 14, 2014
    i needs to reset the tv clock on hd52g887 after replacing the tv lamp
  • Zenith Master
  • 5,138 Answers
You need to reset lamp timer this is to tell set it now has new lamp i have the information at my shop as soon as i can , I will up date this with how to reset timer.
Posted on Jan 01, 2008
  • ladywinn
    ladywinn May 11, 2010
    Menu-9-8-7-6 enter.
I HAVE A 52" ZENITH
There are several models on several generations of Zenith manufactured LCD projection tv's. Without knowing the exact model of yours i can't be sure but in most of them the Lamp life counter is reseted this way: with the tv in stand-by, you press the "?" key on the remote then immediately you press 9,8,7,6 and then the OK. If the procedure was correct the 3 lights on the front of the tv will blink to signal the end of the reset procedure.
In others , hold down the Mute button on remote and Enter on TV at the same time for a few seconds, you should get a screen prompt asking if you want to reset the timer for the lamp.
May 25, 2011 | Televison & Video
Lamp light will not turn off after installing a new one.
you might have to reset the lamp counter in order to get the indicator light to turn off, there are several websites than describe the procedure, the one i'm looking at is fixyourdlp.com/2007/11/29/reset-your-zenth-or-lg-dlp-tv-lamp-counter/good luck!
Jan 09, 2010 | Zenith E44W46LCD 44" Rear Projection...
I have a zenith e44w46lcd tv, while watching it, it turned off and now will not turn back on again. Green light flashes for a bit then goes back to red. Also lamp light is on orange. Do I need to replace...
More then likely your lamp is faulty, you can replace this lamp urself, but on zenith models the lamp comes as a bulb only, you will have to change the lamp and use your original housing. Also lamp timer will have to be reset. The only reason you might need a repair man is to go into factory mode and reset lamp timer. But if you are mechnically incline you can swap the lamps yourself..
Thanks any questions email me at -
Delhielectronics@live.com
Sep 27, 2009 | Zenith E44W46LCD 44" Rear Projection...
How to reset lamp hours
try holding the enter button on the tv and the mute button on the remote. a reset screen will pop up and then just press the center direction button twice.
Sep 04, 2008 | Zenith D52WLCD 52" Rear Projection...
ZENITH D52WLCD
I just found the solution on another model of Zenith TV. Hold the enter button down on the TV and the MUTE button on the remote. In approx. 5-7 seconds a screen will pop up asking if you want to reset the lamp timer. Hit the bullseye button in the middle of the arrows and it will reset. Worked perfectly.
Apr 15, 2008 | Zenith D52WLCD 52" Rear Projection...
Lamp reset.
there are 2 clocks 1 for lamp and 1 for total, the total you cant change. dark picture, make sure your got same wattage lamp for replacement, I find original Philips lamps the best. if it continues follow manufacture instructions on cleaning mirror and lens.
Apr 12, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith HD 44 inchr red lamp light is on
sir,,,maybe,,,,,but you said your tv is ok soo i think its just alright,,,thnkss
Jan 29, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith Lamp Light on
When the lamp is replaced the lamp timer must be reset. The timer is set for just so many hours and then the warning lamp is illuminated. The only way to reset the lamp that I am aware of is with a zenith programmer remote. Perhaps you can find a local lg/zen service center to allow you to use a programmer and instruct you on resetting the timer.
Lamp Indicator is Orange
Press 'Enter' on the TV then press 'Mute' on the remote while holding 'Enter' down. A menu will pop up on the screen, allowing you to reset the light. It's also worth noting that you can get to the service menu by pressing 'Menu' on the remote and TV at the same time. There is an option for checking the number of hours on the lamp.
Apr 19, 2007 | Zenith E44W46LCD 44" Rear Projection...
Zenith D52WLCD 52" Rear Projection HDTV-Ready Television Logo
195 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
