I am looking for a replacement frosted white glass for Hampton Bay Bow Track Bar light model number 109813. It states use with "4JDRCIGU10". It is dimension designer lighting. I can not find this anywhere and am hopeful you can help
thank you, pat pdahodgey@yahoo.com
The variable speed switch in my HB Fan broke and when I took down the unit, the wires fell out so...
(More)
The variable speed switch in my HB Fan broke and when I took down the unit, the wires fell out so that I could not tell which wires went to the four receptacles on the switch unit. I replaced the unit and guessed at the position. Fan works but does not have the middle speed. Is there a resource to tell which wire goes in 1,2,3 and L by color?
I need a wiring diagram for Hampton Bay model AC-374. I bought a display model unknowingly that the...
(More)
I need a wiring diagram for Hampton Bay model AC-374. I bought a display model unknowingly that the wires were cut inside the housing. There is a sleave of four (4) wires that has been cut in which i do not know where or how they are to be hooked up. There is a black and white wire that was not cut that is hooked up to the incoming power supply. The lights come on but that's it!...nothing else.
