XM Radio
Problem for XM Radio (XMP6000)
My xm delphi xpress radio always reverts back to
By car0407 on Oct 21, 2009
my xm delphi xpress radio always reverts back to the introductory channel whenever the radio is turned off. why?
Comments:
Oct 21, 2009
- Thats all well and good...the problem is...that it just started all of a sudden. The radio holds all of it's settings and favorites. If I was listening to station "A" and turned the radio off or turned the vehicle off, then turned them both on again, the radio would be tuned to station "A". Now when I turn either the radio or vehicle off, the radio always reverts back to the preview channel. I reset the radio using it's restore to factory setting option. But it still reverts back to the preview station whenever the radio or car is turned off. Is the radio defective?
Solution #1
posted on Oct 21, 2009
Not Rated)
muebe
Rank: Guru
Rating: 90%, 287 votes
The problem could be that the constant power wire for the stereo might not be connected or connected to the switched power. On the radio there are two power wires. One is red(constant power) and yellow(switched power). If the red wire is not connected to constant power then when you turn the key off the radio will lose power and revert back to the factory settings. Check those wires and let me know what you find.
Comments:
Oct 21, 2009
- Either something could be defective in the radio now making the XM part of it to lose it's memory or XM updated the firmware on the XM software and caused the problem. Unless there is a setting in the radio menu to change the home station then you may need to live with it or change the radio. Did this problem happen not too long after XM and Sirius merged? Maybe that has something to do with it?
Solution #2
Not Rated)
emissionwiz
Rank: Guru  Car Audio & Electronics  Expert
Rating: 90%, 8320 votes
this problem is caused by the "keep alive memory" either being defective or it has no power (always hot), pull the radio out and check the power sources to the radio, you will have one hot wire (12 volts) with the ignition key turned to the off position, if u don't check for a blown fuse, it is possible this wire was never connected, so check that as well.
Popular Solutions for XM Radio
Questions and Unsolved Problems for XM Radio
Do you recommend XM Radio (XMP6000)?
Answer
Answer
I had Lexus install an XM in my new car-2009 ES 350. Have several other XMs in car/office that work... (More)
Answer
XM receiver is reading an antenna problem. I thought the wire might have been damaged so I bought a... (More)
Answer
I have an xm radio in my car and it has locked up some how and I cannot get it to turn off or... (More)
Answer
I would like to get Channel 18 which it says is Elvis. I do not even show a channel 18. Do I need to... (More)
Answer
my xm online is loading but not playing , everything else seems to play
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top In Dash Receivers Experts
Top Audio & Video Equipment Repairmen
in , AR
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
