Question about Alpine IVA-D300 Car DVD Player
Bottom row of touch screen won't work
How do I get the bottom row of buttons to work on my screen?
May have a sollution for ya. i cant spell. try to reset the alignment on the screen. i had the same problem once and somewhere in settings you can RESET the screen alignment. good luck
Posted on Jan 10, 2008
Mic not working
You may have to return your iphone to your store if the mic really does not work. But first try completely turning off your iPhone. Hold down the top button until "slide to power off" comes on... Then slide to off. Once completely off, wait a minute and click the upper right button to turn on again.
Many times "things" don't work because you have too many apps open atone time... So close the apps you are not using. To see what apps that are open, double click the button at the bottom of your screen quickly... Make sure that your first icon page is showing when you do this...By double clicking you will then see at the bottom of the page a single row of all apps that are running... You can then press on the app icon(s) that are open for a second or so.... And "x" will appear. Touch the "x" to turn off the app... NOTE: Make sure that you only do this on the highlighted bottom row...
Oct 14, 2013 | Cell Phones
Epox ep-8npa sli user manual barcode label says 5a 000901821. d33221 is also stamped on board
I don't have access to a motherboard manual, (User Manual), for the Epox EP-8NPA SLI motherboard, Wayne. Sorry.
The only info I have is the basic info on the Specifications,
http://www.newegg.com/product/product.aspx?Item=N82E16813123257
If this problem is in direct relation to the Front Panel header on the motherboard, it shouldn't be too hard for you to find the Power On switch connections.
(Plastic front of computer is the Front Panel.
Area of pins on the motherboard, that the wires from the Front Panel connect to, is the Front Panel header. { FP_1 )
Processor to the top, Ram Memory to the right, and the long white PCI slots to the bottom; the Front Panel header is the long black rectangular block of pins, at the very bottom right.
Pins go across the Top row, and across the Bottom row, of this rectangular block of pins.
Connections made will be from a pin on the top row, to a pin on the bottom row.
It only takes two contact pins for the Power On switch.
(The Power On switch is an ATX power on switch. It is located inside the plastic Power On button assembly.
Here is a basic example of an ATX power on switch,
http://www.directron.com/atxswitch.html )
Touch two pins (One top row, one bottom row), with an LED light.
Take the two wires of the LED light, and use them to touch the two contact pins.
Contact made is no longer than 2 seconds.
If you find the right two contact pins, the Power Supply should turn on.
If not, no harm, no foul.
For example, you have touched the two pins for the HarDDrive activity LED light.
Or pins for the Power On LED light.
You won't hurt anything using a small LED light for a jumper.
Once you find which contact pins turn the Power Supply on, therefore turning the computer on, you can experiment, and see what the other pins are for.
A) Power On LED light
B) HarDDrive activity LED light. and so on.
{ IF, the Power Supply does Not turn on, you have a bad Power Supply}
If this is not the problem simply state so in a Comment. We'll go on to see if we can find the solution.
Regards,
joecoolvette
Nov 23, 2011 | Computers & Internet
I dropped my iphone 3g and cracked the screen....I replaced the screen and now the bottom half won't work...it says slide to unlock...and it won't slide...but the top that says slide to turn off...
Check the 2 pins connected on the home button if touch the interface of the board,might not hitting that is why the slide unlock not working.
Jul 21, 2011 | Apple iPhone Smartphone
My Samsung Jet s8003 is giving me problems. Frequently when I touch one icon on the bottom of the screen icons say the keypad or phonebook or messages it fails to open. When i open the menu with the middle...
Hi , From the description of ur problem it is very clear that ur touch pad is not synchronizing up with the touch . To fix it u will have to reset the factory settings and u need a a code to do the same . I will give u the code and see if it works .one of these will work for sure
  • *2767*3855#
  • *#5239870*#
  • *#7092463*#
Note : don't forget take a backup of ur contacts and other important things that u can't afford to lose
Nov 09, 2010 | Samsung Jet S8000 Cell Phone
Bottom of Touch Screen won't respond
Id try going to settings, general, reset and try that, but id do a sync firstly so you don't accidentally lose everything......
Dec 19, 2017 | Apple iPhone 3G Black Smartphone
The last row of icons on my iphone won;t work. Help....
The last row of icons which is the bottom row with Phone iPod etc?
It sounds as though your digitizer is bad, the iphone digitizer is delicate and seems often goes bad.
does your unlock screen work?
the bottom off the screen handles the unlock and bottom icons.
if your unlock switch works then you may just have a software problem going on.
reboot your phone by pressing and holding the power and home buttons until the apple appears.
when it reboots see if it works properly, if not you may have a bad digitizer.
is your iphone a 2G or a 3G?
Jun 03, 2009 | Apple iPhone Smartphone
Change the picture size on an aurex tv using the buttons on the side of tv
I too have an Aurex TV ..and have to adjust the screen size regularly .I do this by the hand control.at the bottom of the handset are two rows of buttons..3 on the bottom row and 4 on the next row up..the on furthest on the right on the row with 4 buttons is the button for screen size change.
Oct 09, 2008 | Televison & Video
Touchscreen offset
Here's what you do: Turn off the gps. Then, hold the power button for approximately 30 seconds. The calibration screen will appear. Follow the instructions to re-calibrate the touch screen.
Feb 26, 2008 | Garmin StreetPilot C320 GPS Receiver
Alpine IVA-D300 Car DVD Player Logo
121 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
