Question about Pioneer AVH-5700DVD Car DVD Player
HELP!!!! display it says "caution its unlawful to operate a vehicle while videois displayed in the drivers viewing area engage emergency sequence to enjoy" so i guess i need a code to play it which i cannot find... MIND YOU IVE GOTTEN COMMENTS MESSING AROUND WITH THE WIRING BUT, I DIDNT WANT TOO MESS WITH THE WIRING CUZ I DONT EVEN KNOW HOW TOO.....
  • Anonymous Jul 04, 2008
    u need a switch that will be put on and off to let the caution message go off the sreen so that you could watch the video. one of the wire will comes from the ingniton and the other nutral wire but get a good person to do it for you.
Display it says "caution its unlawful to operate a vehicle while videois displayed in the drivers viewing area engage emergency sequence to enjoy" so i guess i need a code to play it which i cannot find... MIND YOU IVE GOTTEN COMMENTS MESSING AROUND WITH THE WIRING BUT, I DIDNT... Read more
Posted on Nov 09, 2008
Just wire the handbrake wire to a bare metal point on the car.
Basically when it sees that the car has the handbrake on, its completes the circuit and allows playback.
Make it believe that its always on by earthing the wire you are supposed to attach to the handbrake :D
Posted on May 09, 2008
There is a blue wire with a yellow stripe on this unit that if you hook it straight to ground you will never have to worry about it again.... This wire is actually the parking brake wire which only is to allow you to watch movies while you are stopped and the emergency brake is engaged but if you take it and hook it straight to ground it will bypass all that crap...
Posted on Feb 20, 2008
We, 07 rendezvous park aid quit working. Needfixed
Rear Parking Assist Inoperative - Red Indicator Flashes
Does the red indicator flash ?
Diagnostic Aids
• The RPA system is equipped with an on-board diagnostic display feature capable of displaying diagnostic trouble codes from the RPA display. Before using this diagnostics, it is necessary to get familiar and understand how the on-board diagnostic feature operates. Refer to Diagnostic Trouble Code (DTC) Displaying and to Diagnostic Trouble Code (DTC) Clearing on how the diagnostic trouble codes are displayed and cleared from the RPA display system.
• Make sure the rear park assist (RPA) object sensors located on the vehicle rear bumper are clean and clear. Remove any objects that is blocking the sensors.
• Inspect for after market devices which could affect the operation of the RPA system.
This vehicle is equipped with an on-board diagnostic display feature capable of displaying diagnostic trouble codes using the 3 indicators on the rear parking assist display. After the bulb check has been completed, the red outside indicator flashes to indicate a malfunction with the system. The module disables operation of the URPA system under this condition.
In order to enter the diagnostic mode, complete the following actions:
With the ignition turned OFF, short the rear parking assist diagnostic connector to ground while the vehicle is in PARK. For the location of the rear parking assist (RPA) diagnostic connector, refer to Object Detection Component Views .
Turn ON the ignition.
Place foot on the brake.
Shift the vehicle into REVERSE within 5 seconds.
If the vehicle is not shifted into reverse within 5 seconds after turning the ignition ON, the diagnostic mode will still be initiated. However, a reverse input wiring fault will be registered as sequence #7 as shown in the Diagnostic Indicator table below. Refer to Diagnostic Trouble Code (DTC) Clearing for the specific steps on how to clear diagnostic trouble codes. After the reverse input wiring code is cleared, repeat the diagnostic trouble code displaying steps in order to enter the diagnostic mode.
When the diagnostic mode is first entered, the rear parking assist display displays the amber outside indicator and the red outside indicator. Then, the indicators on the rear parking assist display will display one or more of the sequences in the table below to indicate where the fault exists within the rear parking assist system. Refer to Diagnostic Trouble Code (DTC) Clearing for the specific steps on how to clear diagnostic trouble codes.
The Rear Parking Assist (RPA) Diagnostic Connector (UD7) is under the front of the center console behind the BCM - body control module.
Nov 18, 2017 | Cars & Trucks
Sound works but there is no display on the monitor. it worked for the first few days then now cant see nothing. Does the park brake wire have to be hooked up in order to show the display cause i know it...
  • Yes it does. The emergency brake wire is a safety feature. If you don't have it hooked up it won't even display anything. If you do have it hooked up then you have to have the emergency brake engaged to be able to view DVD'S. The manufacturer does this so people can't just unhook the brake wire and watch DVD'S while driving
Regards, Tony
May 20, 2011 | Pyle PLD61MU Car Video Player
Linear uv7
GROUND THE PARKING BRAKE WIRE DIRECTLY TO GROUND OR 12VOLT WHICH EVER IT CAUSE FOR WHICH IS USUALLY GROUND. U MAY ALSO HAVE TO INSTALL A TOGGLE SWITCH TO . CONSULT UR USERS MANUAL ON THE PROCESS FOR ACCESSING THIS FUNCTION
Aug 16, 2008 | Car Audio & Video
Parking brake connection
You need to ground your packing brake wire(light green). May be bench test first before intall. Goodluck.
Feb 27, 2008 | Phase Linear UDV9010 Car DVD Player
My phase linear uv7i can't plays dvd's or cd's and the screen is totally blue
caution it´s unlawful to operate a vehicle while video is dispayed in thr drivers viewing area
engage emergency brake sequence to enjoy video???? help help please
Jan 26, 2008 | Phase Linear UDV9010 Car DVD Player
HELPPPPPPPPPPPPPPPPPPP!!!
Ground your parking brake wire(light green). Goodluck.
Dec 29, 2007 | Phase Linear UDV9010 Car DVD Player
Can u help me please =(
same problem, we need answers not more posting about the problem
Help with the code????
ground the parking brake wire to the car chassis (or splice with the black ground wire) and you won't have that screen come up anymore.
Linear uv7
here's the code. I did this with my remote and it works.
press stop twice(which is also the band button)
press1,2,6,4
press down 1 time(button below the play/enter)
press play/enter 1 time
(you should see the menu now)
brake override should say no
I was told to change macrovision to no
hit system setup twice to save and exit
hope it works like mine did
Dec 07, 2007 | Phase Linear 160W AM/FM/CD Receiver W/...
Linear uv7
Is the parking break wire connected to the parking break switch?
Sep 22, 2007 | Phase Linear UDV9010 Car DVD Player
Pioneer AVH-5700DVD Car DVD Player Logo
313 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
