Question about Phase Linear UDV9010 Car DVD Player
HELPPPPPPPPPPPPPPPPPPP!!! display it says "caution its unlawful to operate a vehicle while videois displayed in the drivers viewing area engage emergency sequence to enjoy" so i guess i need a code to play it which i cannot find
    Champion:
  • 227 Answers
Ground your parking brake wire(light green). Goodluck.
Posted on Mar 06, 2008
2wd vs AWD
Page 13 of owner's manual says:
AdvanceTrac
(if equipped):
Illuminates when the AdvanceTrac
system is active. If the light remains
on, have the system serviced
immediately.
AWD locked (if equipped):
AWD
Illuminates when all wheel drive
LOCKED
(AWD) is engaged/activated. If the
light continues to flash, have the
system serviced.
Page 224:
ALL WHEEL DRIVE (AWD) SYSTEM (IF EQUIPPED)
Your vehicle may be equipped with an All Wheel Drive (AWD) transfer
case. With the AWD option, power is supplied to all four wheels
automatically with no need to shift between two-wheel drive and
four-wheel drive. If your vehicle is equipped with the AdvanceTrac
stability enhancement feature, you can change AWD modes, if desired,
by selecting AWD options through the message center.
For the lubricant specification and refill capacity of the AWD transfer
case refer to Maintenance and specifications chapter.
If your vehicle is equipped with AWD, a spare tire of a different
diameter than the road tires should never be used. Such a tire
could make the vehicle difficult to control as well as result in damage
to driveline components.
Utility and four-wheel drive vehicles are not designed for
cornering at speeds as high as passenger cars any more than
low-slung sports cars are designed to perform satisfactorily under
off-road conditions. Avoid sharp turns or abrupt maneuvers in these
vehicles.
The following sections, Normal operation, Autolock operation and
Disabling AWD, apply only to vehicles which allow the driver to change
AWD modes through the message center.
Normal operation (vehicles equipped with AdvanceTrac
During normal operation:
• the AWD system is in AWD AUTO mode (AWD LOCKED will
illuminate in the message center for four seconds when you first start
your vehicle). The AWD LOCKED indicator in the instrument cluster
will also come on.
• AWD AUTO mode can be overridden by pressing SETUP in the
message center. When you first press SETUP, AWD <AUTO> will be
displayed, then if you press RESET within four seconds of pressing
SETUP, AWD <LOCKED> will be displayed. AWD <LOCKED> provides
power to all four wheels constantly which allows you to operate your
vehicle in severe winter or off-road conditions such as deep snow, ice
or shallow sand. It is not recommended that you use AWD <LOCKED>
on dry pavement.
Page 225:
• AWD <LOCKED> can be cancelled by pressing RESET in the message
center. (The AWD LOCKED display in the message center will then
turn off and the display will return to AWD <AUTO> for four seconds
when the shift is complete.)
Autolock operation (vehicles equipped with AdvanceTrac
If the AWD system begins to overheat, the system will place itself in the
Autolock mode:
• the AWD LOCKED indicator light will illuminate in the instrument
cluster and AWD DISABLED <LOCKED> will be displayed in the
message center.
• AWD LOCKED will be displayed in the message center for four
seconds and a warning chime will sound. This condition may clear
without any action being taken by the driver.
• the AWD LOCKED indicator light in the instrument cluster will turn
off when the AWD system cools down.
• When the system is sufficiently cooled down, AWD AUTO RESTORED
will appear in the message center for four seconds and a warning
chime will sound.
Disabling AWD (vehicles equipped with AdvanceTrac
When a problem is detected in the AWD system:
• the AWD LOCKED indicator light in the instrument cluster will flash
eight times every two minutes in the message center.
• The message center will then display AWD DISABLED for four
seconds, then SEE OWNER'S MANUAL. A warning chime will also
sound. The warning displays and chime will continue until RESET is
pressed (which will clear the message from the display).
• AWD LOCKED can still be engaged by pressing SETUP (the message
center will display AWD <DISABLED> LOCKED), then pressing
RESET. The AWD LOCKED indicator light will illuminate in the
instrument cluster and the message center will display AWD
DISABLED <LOCKED>.
• To disable AWD, press RESET. The system will go back to AWD AUTO
mode momentarily, then the AWD LOCKED indicator light will flash in
the instrument cluster eight times every two minutes. The display will
then show AWD <DISABLED> LOCKED for four seconds and then
turn off.
Page 226:
• If a serious problem occurs with the AWD system, the AWD LOCKED
indicator light in the instrument cluster will flash 10 times every two
minutes. The message center will also display CHECK AWD and a
warning chime will sound. You can press SETUP to check the status of
the AWD system (which will display AWD <DISABLED> LOCKED),
but the AWD system will be disabled until the system is serviced.
Driving off-road with truck and utility vehicles
AWD vehicles are specially equipped for driving on sand, snow, mud and
rough terrain and have operating characteristics that are somewhat
different from conventional vehicles, both on and off the road.
When driving at slow speeds off-road under high outside temperatures,
use 1 (First) gear when possible. 1 (First) gear operation will maximize
the engine and transmission cooling capability.
Under severe operating conditions, the A/C may cycle on and off to
protect overheating of the engine.
Nov 30, 2013 | Lincoln Navigator Cars & Trucks
What does a c on the dic mean?
Your vehicle has a Driver Information Center (DIC).
All messages will appear in the DIC display located
below the speedometer in the instrument panel cluster.
The DIC buttons are located on the instrument panel,
to the left of the instrument panel cluster.
The DIC comes on when the ignition is on. After a short
delay, the DIC will display the information that was
last displayed before the engine was turned off.
The DIC displays trip, fuel, and vehicle system
information, and warning messages if a system problem
is detected. The bottom line of the DIC shows the
shift lever position indicator. See Automatic
Transmission Operation on page 3-23
for more
information.
If your vehicle’s DIC has these features, the compass
direction and the outside air temperature may also
display on the DIC when viewing the trip and fuel
information. The compass direction appears on the top
right corner of the DIC display. The outside air
temperature automatically appears in the bottom right
corner of the DIC display. If there is a problem with the
system that controls the temperature display, the
numbers will be replaced with dashes. If this occurs,
have the vehicle serviced by your dealer/retailer.
The DIC also allows some features to be customized.
See DIC Vehicle Customization on page 4-66 for
more information.
DIC
Sep 05, 2010 | 2002 Buick Rendezvous
Linear uv7
GROUND THE PARKING BRAKE WIRE DIRECTLY TO GROUND OR 12VOLT WHICH EVER IT CAUSE FOR WHICH IS USUALLY GROUND. U MAY ALSO HAVE TO INSTALL A TOGGLE SWITCH TO . CONSULT UR USERS MANUAL ON THE PROCESS FOR ACCESSING THIS FUNCTION
Aug 16, 2008 | Car Audio & Video
Parking brake connection
You need to ground your packing brake wire(light green). May be bench test first before intall. Goodluck.
Feb 27, 2008 | Phase Linear UDV9010 Car DVD Player
HELP!!!!
there is a blue wire with a yellow stripe on this unit that if you hook it straight to ground you will never have to worry about it again.... This wire is actually the parking brake wire which only is to allow you to watch movies while you are stopped and the emergency brake is engaged but if you take it and hook it straight to ground it will bypass all that crap...
Dec 29, 2007 | Pioneer AVH-5700DVD Car DVD Player
Can u help me please =(
same problem, we need answers not more posting about the problem
Dec 29, 2007 | Phase Linear UDV9010 Car DVD Player
Help with the code????
ground the parking brake wire to the car chassis (or splice with the black ground wire) and you won't have that screen come up anymore.
Linear uv7
here's the code. I did this with my remote and it works.
press stop twice(which is also the band button)
press1,2,6,4
press down 1 time(button below the play/enter)
press play/enter 1 time
(you should see the menu now)
brake override should say no
I was told to change macrovision to no
hit system setup twice to save and exit
hope it works like mine did
Dec 07, 2007 | Phase Linear 160W AM/FM/CD Receiver W/...
Linear uv7
Is the parking break wire connected to the parking break switch?
Sep 22, 2007 | Phase Linear UDV9010 Car DVD Player
Why are my pictures jagged when I view them on my computer?
Your monitor may not be optimized for viewing images. For the best on-screen viewing, set your monitor display as follows: For computers running the Windows operating system: Select Start > Settings > Control Panel > Display. In the Display Properties window, select the Settings tab. From the Color Quality drop-down menu, select the highest setting your monitor will allow (usually 24 or 32 bit). Drag the Screen area slider to either 800 by 600 or 1024 by 768. Click Apply, and then OK. For computers running the Macintosh operating system: Access the Monitor Control Panel. Set the color to Millions of Colors.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Phase Linear UDV9010 Car DVD Player Logo
Top Phase Linear Car Audio & Video Experts
Lyle Siemens
Lyle Siemens
Jaime Hernandez
The Audio Lab
Are you a Phase Linear Car Audio and Video Expert? Answer questions, earn points and help others
