Question about Kensington PocketMouse 72214
Mouse wont shut off with the scroll butten and connect button. Do both buttons need to be held down for a few seconds?
Push the scroll button, then the reset button with pen tip on bottom of mouse
Posted on Mar 13, 2008
Mouse is not doing well
Shut down computer.
Unplug the rat.
Press each button repeatedly about 10-20 times.
Hold down all for a few seconds.
The mouse electronics sometimes builds up a charge, causing the false triggering you experience.
Pressing buttons while unpowered helps to discharge the capacitance.
Plug mouse in and reboot.
Hopefully this clears the problem.
Nov 16, 2017 | The Computers & Internet
Onn wireless mouse stopped working
Make sure the batteries are inserted correctly and have charge
make sure the usb device is properly inserted
make sure you turn the mouse on depending on type/brand of mouse it will vary it could be a button or switch on top bottom
or you might use the safe mode option
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer then if your mouse works
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question/exclamation mark? ! or a red X right update driver
hope this helps
Feb 12, 2012 | Computers & Internet
My cordless Logitect mouse has started to shut off by itself.It comes on again when I press the red button underneath, but it stays on only for a few seconds and then shuts off again. Can you help?
Remove the battery of the mouse and install new one and then press connect button from the mouse side and the receiver side also.
Have a nice day and do not forget to rate please...!
Feb 13, 2010 | Computers & Internet
Left button not working after few days of purchase
There are several possible solutions. I would first try reloading the drivers if you installed any. Disconnect the mouse and start the PC. Then shut down and connect the mouse and restart. Of course the first thing you need to check is the batteries in the mouse and the receiver that is connected. When working with wireless it is possible something maybe interferring with the signal for the button click function as well. Hope this helps.
Nov 20, 2009 | Microsoft Wireless Optical Mouse
Cordless Optical Mouse Not Working
you need to connect it back to the reciever, everytime you connect the mouse on the bottom it will be looking for the reciever to connect to. Try pressing the connect button on the reciever first then the connect button on the mouse
I hope this helps
Nov 15, 2008 | Logitech Cordless Mouse
My Iogear mouse wont work
In order for you to make the mouse work with your computer, please try the steps below:
1. Make sure that you're using fresh batteries.
2. Make sure that the mouse is turned on.
3. Hold down the connect button on the receiver (the mouse cradle) and hold down the connect button under neath the mouse at the same time for five seconds and then release the buttons.
4. Try moving the mouse around and that should work.
Apr 15, 2008 | IOGear (GKM521R) Keyboard
Mouse will not work
Press the button till mouse light comes on.
then try Normal 0 pressing the receiver button and then press the button on the mouse momentarily. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Mar 20, 2008 | NexxTech NOM Mouse
you don't need a driver. to switch pc, use keystrokes below.
' Scroll Lock / Scroll Lock / 1 or 2'
'1 or 2' being the pc location on the switch.
hope this helps.
Mar 04, 2008 | KTC IntelliView KC102P (DSKTCKC102PS2)...
Two port kvm belkin
Switch to the First PC [Scroll Lock] [Scroll Lock] [1]
Switch to the Second PC [Scroll Lock] [Scroll Lock] [2]
Previous Active Port [Scroll Lock] [Scroll Lock] [Up Arrow]
Next Active Port [Scroll Lock] [Scroll Lock] [Down Arrow]
Switch Audio to the First PC [Scroll Lock] [Scroll Lock] [F1]
Switch Audio to the Second PC [Scroll Lock] [Scroll Lock] [F2]
AutoScan Mode [Scroll Lock] [Scroll Lock] [0]
Change All to the First PC [Scroll Lock] [Scroll Lock] [A] [1]
Change All to the Second PC [Scroll Lock] [Scroll Lock] [A] [2]
Other information:
In AutoScan mode, the switch remains on one port for 10 seconds before switching to the next. This time interval cannot be changed. To exit autoscan mode press [Spacebar].
When in AutoScan mode, no mouse or keyboard controls. If the user moves the mouse or uses the keyboard while switching the connection between computer and the switch might be interrupted and cause erratic mouse movement and errant display when using the keyboard.
Maximum resolution supported is 2048 x 1536 @ 75Hz.
If mouse movement is erratic:
make sure you do not have more than one mosue driver installed. Make sure that the driver is either for a standar PS/2 mouse or a Microsoft compatible PS/2 mouse. Make sure you do not have any mouse drivers loaded in your CONFIG.SYS or AUTOEXEC.BAT files. Avoid moving the mouse or pressing the mouse button when switching ports on the switch. You can reset the mouse and resume porper mouse movement simply by unplugging the mouse from the switch and allowing 2-3 seconds before plugging it back in.
Company information:
Nov 03, 2007 | Computers & Internet
Kensington PocketMouse 72214 Logo
118 people viewed this question
Top Kensington Computers & Internet Experts
Level 1 Expert
Alun Cox
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
