Question about Panasonic NN-S962 Microwave Oven
Comes on when you open door, and now it finally quit working
I have had this microwave for approx. 6yrs. About 2 yrs after purchase it started the problem of coming on when you opened the door. I had that repaired it was a door switch problem.
Last year it started it again but I never had it repaired and a few months ago it quit doing that on and off. Then right before Christmas this year you could press the sensor cook button and it would not come on at all. Not even if you opened the door. LOL So I tried the minute cook button next to the sensor cook button. That would work so I would immediantly hit the stop button and then try the sensor button again and it would work. So for a few days I would hit the minute cook button stop it and then hit sensor cook all was okay and the problem of opening the door and it started had ceased as well.
Christmas day it would not do anything and hasn't since!! I have tried every button. The clock still works and you can change time. When you press the minute cook button you hear a click the light comes on it starts counting down and three seconds later you hear a click and the light goes off. Hummmm
I want to know if it is worth repairing or am I better off purchasing a new microwave? I have gone ahead and purchased the Kenmore 721.67903 convection/microwave and hope it does not have as many problems. But if this one can be fixed and not at a major cost I would have it repaired to use in the game room.
Thanks for any help,
  • bsirvine Feb 24, 2008
    Very same problem. About 3 weeks ago it began. Now ALSO, the timer runs for 3 seconds, shuts off the fan and turntable, runs for 3 seconds more, shuts down then goes back to the default display.
  • Anonymous Jun 05, 2008
    plat is not moving
  • 579 Answers
I think you've put up with enough hassle from this unit and should get another one. Intermittant flakey problems are hard (read expensive) to fix.
Posted on Dec 31, 2007
I have a over the range microwave that is not working,it showing code F7,it runs a few seconds and then shuts off,we had been having a problem with the door,sometimes when you close the door it won't
a faulty door seal is serious. microwave radiation should be contained within the unit. if you can not fix the door mechanism then junk it.
Sep 14, 2014 | Microwave Ovens
MICROWAVE POWER TEST Hi Everyone, In this tip I will show you how to easily test...
Hi Everyone,
In this tip I will show you how to easily test your Microwaves power. If it is sufficient, or if it is not heating effectively anymore.
Non heating Microwaves are a common issue, and the most likely component that is faulty is the Magnetron - These days Magnetron's are quite expensive (usually about 50% the price of a new Entry Level Microwave). Low heating could mean a Magnetron becoming faulty (unlikely, as a Magnetron either works, or it doesn't work)
Tools required: A Normal Glass (Heat-resistant, in other words Microwave friendly), Water (Room Temperature) , a Centigrade Thermometer (Can get this at any Pharmacy)
1) Fill a glass with approx. 125 ml water. Use water at room temperature (from the tap), avoid using refrigerated water as this will work against the test we are doing.
2) Measure the initial temperature of the water with the thermometer (It should be between approx. 10 & 20 degrees).
3) Place the glass with the water about 2 cm away from the center of the Microwave Oven plate.
4) Heat the water at full power (The highest setting possible on your Microwave) for 70 seconds.
5) Stir the water (For 5 - 8 sec).
6) Measure the final water temperature with a thermometer.
7) If the increase is 45 degrees or more, then your microwave is heating sufficiently, if not it could mean replacing the Magnetron, or purchasing a new Microwave.
I hope this guide as helped you. If it has, please rate it accordingly.
on Apr 23, 2011 | Microwave Ovens
I have a sharp carousel 1200 watt and my daughter cooked a toaster strudle for 2 mins and the microwave shot flames and has no power any more. it is approx 7 yrs old, would this do that or possible another...
It sounds like the magnetron has failed, and the main fuse has blown, this is not related to what your daughter put in. This gave out because of parts failure, due to repair cost consideration should be given to a new one because prices have come down.
Feb 23, 2011 | Sharp Microwave Ovens
Oven resets (like power failure) frequently - either while pressing buttons or while cooking food. Approx 5 yrs old - problem just started.
The following parts may cause this problem and must be tested:
Control Pad: This is most likely the problem , testing the contol pad is quite complicate.
Door lock: A defective door lock can cause the magnetron and turntable motor being turn off erratically. This wont cause the program to reset.
Power cord and power connection solder joints: this can cause a microwave restarting because vibration caused by the oven working cause power interruption.
A bad shielding to controller board can also cause the microwave resetting because of the interference caused by magnetron on control board circuits. This is also quite common.
The control pad or control board are the parts that are most commonly causing this problem.
Dec 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Frigidare FMCB115Gc Has power won't start up
Could be a blown fuse in the HV transformer primary circuit,bad connections to the magnetron filament,open thermal protector or thermal fuse,
Sep 03, 2009 | Frigidaire Mid-Size Microwave
Microwave is not working
One of the door switches needs to be replace.
Oct 30, 2008 | GE JVM1440 Microwave Oven
Microwave doesnt heat anything.
it is the door problem it seems to be known issue per target sales guy he advise to call emerson since it is past 90 days for target to return
Jan 19, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Panasonic NN-S962 Microwave Oven Logo
268 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
