-   my bluetooth was working one day and then just stopped. i have tried resetting everything but nothing happens . my bluethooth is in disabled mode and when i try to change it to enable it just displays "enabling bluetooth" on the screen and nothing else happens. help-   meldan
Feb 06, 2009
-   I can´t activate bluetooth on my Garmin nuvi 660. I never have updated the firmware. It was running OK until yesterday when I tried to use it and it oddly apeared disabled... Since then I cannot turn it enabled.-   RaulBlas
Jan 29, 2009
-   I have same problem-   Guest
Jan 14, 2009
-   tried all the tricks in the book:
press reset button
start up in maintenance mode and clear all user data
Start up in maintenance mode and clear all waypoints
don't know what else to do.. seems to do this after certain software updates?! currently running version 4.7 of software. Version 4.6 was fine... with version 4.5 the bluetooth kept crashing as well.-   ivanka769
Feb 21, 2008
-   my blue tooth keeps turning off by it self it is very annoying this is happenning ever since i upgraded the blue tooh firmware on the web updater-   Guest
Please try to do these steps:
Turn off Garmin Nuvi
Turn "bluetooth" function OFF (on your cell phone)AND turn off your cell phone
Now, turn on Garmin and make sure bluetooth is in enabled mode
Next, turn on your cell phone AND turn "bluetooth" function ON
Wait about 30 seconds or less, your Nuvi should connect now w/ a phone icon.
I understand, it's such a pain, but it works for me everytime I do this.
Remember, Phone must be off and bluetooth is also off before you turn on your Nuvi.
Good luck!!!
A GPS girl
I had the same problem, and this is how I fixed it. Now it's working fine.
Thank you for contacting Garmin International,
If
you are currently running the most current version of bluetooth
software, and you are still seeing issues where your compatible phone
is still not connecting properly, please try the below procedure, which
will reinstall the version of bluetooth you have downloaded in case
there was any corruption during the transfer or installation of the
bluetooth version.
1. Power the unit on
2. Touch View Map
3. Touch the ETA/Speed button in the bottom left hand corner.
4. press and hold your finger over the speedometer for 10-15 seconds until a new screen appears.
5. Touch next at the bottom of the screen until the top blue banner reads Bluetooth Status.
6. Touch UPDT P, then Touch yes.
7.
At this point the unit should go to a page that says Updating Bluetooth
Firmware, allow this to finish, once finished, press quit, then press
and hold the back button. At this point, go back through and try to
connect your Bluetooth device again.
Unit turns on loads software then map and within three minutes shuts off saying low power even...
(More)
Unit turns on loads software then map and within three minutes shuts off saying low power even though it is plugged in and power cord works, seems the battery has no charge or will onlystay on for a minute or so then turns off.
I was replacing the battery and by accident I threw it away all 4 screws of my Garmin Nuvi 680 :(...
(More)
I was replacing the battery and by accident I threw it away all 4 screws of my Garmin Nuvi 680 :( Any idea of the exact specs of the screws? I remember they were a T6 torx and there were 2 longer (inside, holding the PCB) and 2 shorter (behind the antenna), but need to know the exact the length and size (diameter) so I can find a proper replacement.. Any help would be greatly appreciated.
I have a Garmin 660. The screen shows the routes and turns, but the voice command suddenly stopped...
(More)
I have a Garmin 660. The screen shows the routes and turns, but the voice command suddenly stopped working. How do I turn the voice back on?
