Question about Zenith SY2765S TV
White Lines and Bright Screen
Last night when I turned on my TV I heard a loud click like a static shock.
Right after that the screen was very bright and I couldn't see what's on, so I left the TV off for a while and turned it back on.
The screen looked normal, but then 2 seconds later I heard a click (not as loud as the 1st time) and the white lines showed up then started to dim out. The screen is still bright, but watchable and there are dark lines when text is shown on the tv.
Left it unplugged over night and I'm still having this problem.
  • 373 Answers
I believe you have a shorted transistor on the crt board on the back of the picture tube which should be Q5104. Let me tell you my experience with these Zenith's The original problem is the picture tube shorting out and caused this problem. If you replace the transistor the same problem could arise again because of the tube and it could even knock out the main board power supply. I have seen this happen. And I have put in the transistor and no problem. You can get one at the Radio Shack by taking the bad one out and get them to cross reference it for you. All Zenith transistors have a prefix number (not on the transistor) which is 121- (with the dash!) and the number on the transistor The new one must go back in the way it came out! I recommend someone with electronic soldering and desoldering experience. Hope this helps
Posted on Dec 30, 2007
Sony KP-57WV700
Hi. It seems that the g2 voltage of the picture tube is too high, resulting in a white screen, often with white horizontal lines. The g2 (= second grid) voltage is derived from the flyback high voltage. The voltage divider is mostly integrated in the flyback trafo housing.(including the adjustment knobs). A failure in this divider may lead to this defect. The static you hear may come from sparking in the divider. The flyback trafo is soldered onto the main printed cirrcuit board. Sometimes, one of the pins sits loose in the soldering pads.
Turn on the set and observe for any sparking around the entire flyback circuitry, and, or the flyback trafo itself
The screen turns black after a while, as a too high beamcurrent is detected. The set disables the flyback. Stand-by blinks meaning that there is a fault condition.
Be carefull with the high voltages. The flyback voltage is very high (20-30 Kilovolts !) and may be lethal !!
Jul 02, 2012 | Sony KP-57WV600 57" Rear Projection...
Tv turns itself off
hello. it sound's like you have a picture tube that is shorting out from a something arking in side of your set.!!! eather on the (CTR PIN COUSHION).!!! OR ON THS CHASSIE.!!! THAT WHAT MAKING IT DO THAT.!!! TIME TO GET A NEW SET.!!! HOPE THIS HELP'S YOU.!!! "GOOD LUCK"
Aug 11, 2008 | RCA 20F511T TV
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
It sounds to me like you're describing the re-trace of the unit. It is repairable, and more so the sooner you get it to the repair facility.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Lost picture, sound fine Sanyo ds19310
are you seeing bright white lines along with blue colour please clarify so I can give you the best solution
Sep 12, 2007 | Sanyo DS19310 19" TV
RCA 32V420T 32" TV
This RCA set uses the CTC187BD chassis. Look on the back of the set and to the right of the cable connector you will see 2 controls sticking out, one on top of the other. The top control is for focus and the bottom one is screen, or overall brightness. If these controls have been turned clockwise then you will have a bright, fuzzy picture with white lines (retrace lines) through it. Tune in a channel with white letters on the screen and turn the top (focus) control until the letters are crisp and sharp. Go into the menu and turn the contrast and brightness all the way down, and then turn the bottom control (screen) until you can just see the picture, just above the point where the picture is too dark to see. Go back into the menu and reset the contrast and brightness and the picture will be back to perfect.
Jun 28, 2007 | RCA 32V420T 32" TV
Fuzzy white lines
YOUR tv DEVELOP a problem in the video ocillator or the tunner section have this set check by a qualified tech.to solve your problem good luck.any more contact nicodhem@yahoo.com i hope by now you have gotten your set fixed the repairs will cost you about between $50.00.to $200.00 good luck.
Feb 25, 2007 | Sharp 32U-S60 32" TV
Red Screen
Sounds like the red color tube is goeing bad you wil hafto call in a tech to conferm it Sony is noted for tubes goeing bad, in the future leave sony alone
Sep 24, 2006 | Sony KP-57HW40 57" Rear Projection...
Some part of TV has been fused causing no picture on screen , only bright green horizontal lines , not even video channel could be set ,cannot see menu on screen please help by specifying possible...
if the screen is real bright green with thin small white lines in it its probably a shorted picture tube. Or a shorted Green driver Transistor. Good Luck
Apr 12, 2006 | Thomson 14MG135 14" TV
Televison & Video Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
