Question about Uniden DCT648-3 Cordless Phone
Checking voice mail remotely
We have a Uniden DCT648 and are away from home--what is the procedure for checking my voice Mail? I thought it should be 1. call the phone 2. press * 3. enter PIN But that is not working.
  • marie Mahnken Jul 25, 2013
    how do I set pin?? I have model E2811 with At&T
  • 126 Answers
This may be a little late, you are probably home already, but here it is anyhow:
Remote Operation
You can check, play, or delete messages, even record a new greeting message from a remote
location (when you are away from home, or from another room using a handset).
Additionally, you can turn On or Off your answering system remotely.
Remote access away from home
You can operate your answering system from a remote location using any
touch-tone telephone.
1) Call your telephone number and wait for the system to answer. If the answering system is
off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is off),
press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code" on page 25
or 54).
3) The answering system announces the current time and the number of messages stored in
memory. You hear "To play incoming messages, press zero-two. For help, press one-zero".
You will hear a beep.
4) Enter a command within 15 seconds, each command there after must be entered within 2
seconds. You may select a command from the following chart:
Command Function Command Function
0 then 1 Repeat a Message* 0 then 6 Answering System On
0 then 2 Playing incoming Messages 0 then 7 Memo Record/Stop**
0 then 3 Skipping a Message 0 then 8 Greeting Message Record/Stop**
0 then 4 Deleting a Message 0 then 9 Answer System Off
0 then 5 Stop Operation 1 then 0 Help Guidance
* For Repeat a Message function, press 0 then 1 within about four seconds to repeat
the previous message, or press 0 then 1 after about four seconds to repeat the
current message.
** For Memo Record and Greeting Message Record function, the first time you enter the
corresponding command, it starts the Recording function. If you want to stop the
recording, press 0 then 7 or 8.
5) After the command has finished, you hear intermittent beeps indicating that the system
is in the command waiting mode. You may enter another command at this time from the
chart above.
6) When you are finished, hang up to exit the system. The answering system automatically
returns to standby.
Posted on Jan 26, 2008
How to empty my mail box
Here's a possible solution I found with a search engine:
I believe your callers MAY be reaching a "Voice Mail" system that is part of your phone service - from whatever service provider you have.
To confirm that this is true, simply disconnect the main base unit from the phone cord and then call your home number from another phone (such as a cell phone). If you still hear that "mailbox full" announcement, then you have confirmed that there is some kind of voice mail system active - and full - on your home phone number.
So what that means is that you will need to contact your service provider and get the official instructions on how to access that system - to listen to and delete any messages that are there. Each service provider has different procedures, but you can often call your own number - from your home phone - and get straight into the system. Once connected, there should be "speech menu" that will guide you through the messages and how to delete them.
Also, you may want to configure or disable this voice mail system so that the Uniden has a chance to answer calls while you are away. This usually involves either setting the number of rings on each system so that your Uniden can answer first, by having a lower number of rings than the voice mail system.
There may be other steps needed IF this voice mail issue is not the problem.
Aug 25, 2014 | Uniden Lands Phones
We have a voice mail box for our home number, we would like to be able to access it remotely. How do we find our remote help
First try this. When you call your home number, and the voice mail picks up, hit either the * or # key. It might have to be pushed as soon as the voice mail answers or after the beep. Try both. You might have to set up a pin from the voice mail menu from your home phone.
May 17, 2011 | Cell Phones
How do I access voice mail remotely? I have had the phone for a long time and forgot my password.
The remote access procedure and default password vary from model to model. Since you neglected to specify the model of your Uniden cordless system I can only suggest you select it from the list beginning here to download a copy of the manual.
Mar 19, 2011 | Uniden Cordless Phone
My uniden cordless phone says vm on the screen. What does that mean?
It is voice mail and some time you checked voice mail on your cordless phone but light will keep flashing that you need to check your voice mail. if it does not fixed then You need to also delete the voice mail from any voip device and it should turn off blinking lights and will clear vm message.
Feb 17, 2010 | Uniden Lands Phones
We have a Uniden DECT1588 Series system that we have just purchased. We are connected to a Voice Mail Service through Bell. We can receive the messages from the answering service but the light on the hand...
OK. You have a phone set with an answering machine, yet you continue to pay MaBell for Voice-Mail. Is there any compelling reason. That was my feeling when I first read your question but I thought you might not like what I had to say, so I consulted the Uniden FAQ and here what they have to say.
If you Uniden phone has a digital answering machine, and you also have voice mail through your phone company, the message indicator light will not light up when you have a message in your voice mail system. We recommend you discontinue your voice mail and use the Uniden internal digital answering system.
Jan 04, 2010 | Uniden DECT 6.0 Cordless Phone ID
Uniden dect 6.0 caller id light wiil not go out
I am not aware of any Uniden phone that has a "Caller ID" light. If you are talking about the small red LED on the top of the handset, that is a voice mail indicator and can be triggered by either a voice mail being held by your telephone service provider (Called Call Notes by some of the "bell" companies) or an unheard message on the telephones internal answering machine. Most of the time this is due to a voice mail on your service provider. If you don't think you have Voice Mail from your telephone service provider, call them and make sure, now days they include it with a bunch of other features without you ever asking for it. If you do not have voice mail through your telephone provider and there are no new messages on your answering machine, follow the Reset VMWI indicator procedures in your owners manual availible at http://www.uniden.com/index/manuals_results.cfm?cat+1
Apr 25, 2009 | Uniden DECT 6.0 Cordless Telephone...
How do I retrieve my voice mail when I'm away from home?
Go to the base unit.
scroll to the answering machine option.
Under there is a setting for your security key.
you can read what's there, or change it to your own two digit code.
when you call in, during the message, enter that two digit code and it'll go into messages. There's a "toll saver" mode so that the machine answers after two rings instead of 4, so that if you call and it rings 3 times, you know there's no new messages.
Manual:
http://www.uniden.com/pdf/DCT648-2om.pdf
Feb 03, 2009 | Uniden DCT648-3 Cordless Phone
for this model of phone, you perform the following:
1- Call the phone, wait for the machine to answer
----if the machine is on, it should answer within about 4 rings and begin playing your answering machine message
----if the machine is off, it will still answer after about 10 rings with a series of beeps
2- During the message (or beeps if it is off) press 0 and then enter your 2 digit PIN code. This should get you remote access to the phone. from there you can follow the menu structure that the phone tells you. If you never entered a PIN code, that's not a problem. the default code for this model of phone is 80.
you have about 15 seconds to enter a command, all commnds are two digit (01 through 10) and the digits must be entered within 2 seconds of eachother for the command to hold.
follow those directions and you'll be checking your messages in no time flat.
Jun 09, 2008 | Southwestern Bell (S60802)
Uniden Voice Mail
http://uniden.com/index/manuals_results.cfm
Nov 29, 2007 | Uniden Cordless Phone
Uniden DCT648-3 Cordless Phone Logo
2,289 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
