Question about Zenith VCS442 VHS VCR
No power to unit
VCS442 recorder is rather new, not used much but now trying to set it up for use. Plugged in, fuse tests good and power gets past fuse, on-off button seems to be good. Any suggestions on what I can do?
  • jaxbeach Dec 30, 2007
    Thanks. Nothing lights up now. I pulled and looked at that fuse and it looks ok but I'll try a new one.
  • 4,102 Answers
Hi when you switch it on does anything light up like the display or standby light if not then it is going to be the internal fuse needs replacing these are cheap to buy it is located where the powe lead goes into the unit and it is a glass fuse take it to shop to make sure you get correct fuse let me know how you get on.
If the video lights up and you get standby light or any light check that the lock function on the controll isnt activated as this will cause the controll to fail let me know how you get on ok
Posted on Dec 29, 2007
  • paul proctor Jan 03, 2008
    Hi happy new year sorry its been a while have been in hosptal over xmas so havnt had chance to check mail.
    The fuses can be brought for pennys but make sure you get correct one.
    If you are sure fuse in plug is working and replacing the internal fuse where wires go into the video player itself and then you know this is not the problem if nothing still lights up then it is going to be a problem with a resistor on the board itself i dont think it will be the on off switch as it should still light up even if the video is on stanby you should have red light or if their is a display then it should show the time even though the video is off.
    You will need to make sure the video is getting power ot the internal fuse then you will need a good magnifying glass and check all resistors for any signs of over heating or might be melted slightly.
    You can usually see the one or ones that are no good using mag glass on finding the bad resistors you will need to purchase exactly the same resistors to put back in.
    You will need good soldering iron to remove reisistor and for putting new one in make sure you dont touch nothing else as this could cause you problems.
    Also check the foil that runs between resistors to check for splits this can also cause a problem and is hard to repare probably cheaper to buy new video if this was the case hopefully its just resistor.
    If you dont have correct testing equipment to test the circuit then the only thing you can do is check with mag glass untill you find bad resistor.
    Let me know how you get on ok
Hello my name is Christopher I have a 96 Chevy K 1500 5.7. my fuel pump isn't turning on. I have a new relay. good pump and wiring seems intact.I tried an experiment( carb swap) and removed the pump...
check that the earth wire is making good contact , when ignition off the relay should have power to one prong , does it ? the brighter light on one prong than the other does point to a earth problem though, i presume you have checked the fuse board , as you know some fuses feed thing's not mentioned , worth a check , keep me posted if you wish
Nov 03, 2014 | 1996 Chevrolet K1500
Hi, I stupidly turned on my brand new Francis X7 machine without using a transformer (I bought it from the US, used it in Malaysia), and of course, something blew, and it now doesn't work at all. Any...
The machine is made to work with 120 volts and you have plugged this on a 220 volt mains circuit thereby blowing up the fuse, or the power circuit, possible heater and the main controller unit board.
A step down transformer was needed to work this unit safely . Now unless the unit is opened the damage cannot be confirmed but if you are lucky the fuse would ahve blown and saved the rest. if so test it with a new fuse using a 220 to 120 volt convertor.( transformer with good rating)
Jul 05, 2011 | Microwave Ovens
After several months of inactivity (it's in a vacation condo) the unit will not not turn on, I have but new batteries in the remote and have tried to turn it on manuall, no power at all
It is possible the DVD Recorder took a power surge if it was left plugged in if not, then items that are left for a long time without use sometimes draws more power on start up than normal blowing the fuse.
Dec 20, 2010 | Philips Magnavox MWR10D6 DVD Recorder
How do you record digital channels using a Zenith VCR VCS442?
A VCR is an analog device from input to tape. You cannot record "digital channels" to such a device.
If you have cable or satellite box, it is often possible to record from the RCA outputs of the box. Copyrighted material will still be blocked by circuitry within your VCR.
Jan 02, 2010 | Zenith VCS442 VHS VCR
Replacing DVD drive on R04
Could be you have been double-crossed by the used drive. Installation is pretty easy as the data and power cables are both keyed (check the pins on the drives data cable connector to make sure they are not bent). Only other thing I can suggest on the replacement drive is to make sure it set to "MASTER".
I suppose you could try another drive just to confirm that the issue is in the replacement. WalMart sells an internal 22x LITEON DVD Writer for $39, Bar Code 44149 00406 (others may not be IDE) that you can test or permanently repair with.
To test, unplug your ilo and simply:
1.Setthe new 22x drive to MASTER (comes set as slave out of box, see theirdocumentation or the drives cover switch legend markings).
Note: If you want to test using a pre-recorded commercial DVD you will need to do step 2 and first install it in a PC. You can, however, test a blank DVD+R at this point by just connecting the cables.
2. If you wish to play commercial DVD's in your ilo, you must first install this DVD writer in a PCand play part of a studio recorded commercial DVD. This will set the units Region Code.If you don't do this, the drive will not play commercial DVD's (it willnot start or it will lock after copyright screens). If you don't wishto play commercial DVD's in your player, you don't have to do thisstep... it will play DVD's it creates just fine without it.
3. Take off the top of the ilo and move the flat data cable and the power connector to the new 22x drive.
4.Re-test all your issues. If your problems go away then you need the newdrive. If not, the only other user action I can think of short ofmaking sure all the cables are tight is to reload the firmware(http://www.ilohelp.com./download2.htm) but that assumes you can get past "hello" which sounds like you may not be able to do.
The new 22x drive can be installed in the ilo and, with some work,look just like the original from the outside. Some other posts also sayyou can open a hole in the top or back cover for the cables to exit andjust leave the new drive on top of the ilo. Not crazy about that optionbut up to you.
Hope this helps. Good luck!
May 07, 2009 | iLO DVDR04
My Magnavox MWR20V6
If unit is still under warranty return it. If unit is still sold at the orginal place of purchase buy another and return the first one stating it wont work and get a refund
1) power source is good? (receptical on the wall or power unit. Locate DVD rec. to another receptical and check Rec. again)
2) power cord going to unit is good, no cuts or melted spots
3) power setting on unit is correct (small red slide type buttong for different country voltage settings)
4) internal fuse, change it even if it doesn't look bad.
5) Weigh the cost of a new one to the repair cost of the old one. If you buy a new one get a good brand RCA is still one of best and longest lasting.
Jul 18, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Power problem.
1. Make sure the AC outlet is good.
2. Make sure there is no damage to the AC line cord.
3. Look to see if there is a fuse at the rear of the unit. It's usually located inside a black circular housing with a screw off cap that says "fuse".
If not, unplug the unit and remove the outside cover. Look for a blown fuse on the motherboard or power supply. Replace it with the EXACT value of the original fuse. You can purchase a new fuse at Radio Shack or hardware store or auto parts store. Try powering up the unit again and see if it works now or whether the fuse blows again. If it blows again, the power supply may have been damaged.
Please let me know if I can be of further assistance to you.
- Jim
Mar 20, 2008 | RCA DRC8320 DVD Recorder/VCR
Fi 5750c adf will not initialise
Just something simple to try...check your software setting to see if it is set for ADF or Flatbed feeding. You said the light bar moves when power is interupted or the adf opened. But you never said if it is scanning in Flatbed mode. If the Flatbed scans, then check the software setting. Most of the flatbed/adf hybrid scanners start up defaulted to flatbed, so when you try to scan, the adf won't pull anything thru until you change to ADF mode.
Mar 13, 2008 | Fujitsu fi-5750C Flatbed Scanner
No Power
How do you knoe it's good? Does it LOOK good, or did you test it with an ohmmeter? Sometimes - particularly when the get old a fuse can LOOK good, but be bad.
Other possibilities - power cord, plug or outlet bad (is the outlet the un it's plugged into on a switch? Are there other WORKING appliances plugged into the same outlet?)
Sometimes there are other fuses not readily visable - INSIDE the unit.
Last - and worst power supply in the unit simply quit. And that a big repair.
Let me know what you find.
Mar 01, 2008 | Teac R-H300 Dual Cassette Deck
Zenith VCS442 VHS VCR Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
