Question about Lite On LVW-5005 DVD Recorder
Doesn't recognize disks anymore
My LVW-5005X no longer will recognize that I have a disk inserted.
It will open and close with no problem, but always reports NO DISK.
I have tried already written DVD disks, blank DVD-R and DVD+R disks,
and blank CDs.
The unit has worked until now, but I had trouble with the door opening so I had to open the cover and remove the burner so I could get to the manual eject lever. Now it opens/closes with no complaint, but somehow it no longer recognizes there are disks in the unit.
  • pgruok Jan 07, 2008
    Exact same problem. Help!!!! Does not recognize any discs!
  • Anonymous Feb 10, 2008
    My unit has recently been experiencing taking a long time to preparing disk for recording. when a new disk is inserted it takes a longer time that usual to recognize the blank disk. if it recognizes the disk at all for recording.
    Even with RW disk that were previously recorded. after erasing the disk fails. the recorder does not recognize that disk.
    I TRIED A CD-R DISK AND IT RECOGNIZED THE DISK AND WAS ABLE TO RECORD SVD MODE.
    BUT AGAIN THE UNIT WILL NOT RECOGNIZE ANY DVD +R/ OR DVD-R DISK.
    From the FAQ'S rw disks can be used 1,000 times I' am not getting that lenth of service. the unit scratches that disk a lot . the just dont last as long as expected.
  • 31 Answers
This is a common problem with the Lite-on LVW range of DVD recorders due to changes in the construction of more recent DVD R media. It can be solved with a relatively simple firmware upgrade.
Goto : http://r00.liteonit.com.tw/DC/english/download/index.asp
You'll need to have a blank CD and a CD/DVD writer in the PC you use to download the file.
Follow the instructions on the website to upgrade your firmware, this should then allow you to write to DVD's once again.
Posted on Mar 06, 2008
Sony vx-515 dvd tray won't open
Mine was a Sony TS-P532 DVD in a Model GX315 player. A BLU-RAY disk got inserted and won't eject. Remove the player cover and on top of the drive is a 3 X 3 (approx) metal plate with a plastic wheel visible in it. Un clip the two sides of the metal plate and it will pivot up and the disk can be removed.
Mar 26, 2014 | Lite On LVW-5005X DVD Recorder
i would try lens cleaning cd 1st ok might be dirty lens just cant read it if not that try firmware update to the unit thx nick
Feb 04, 2008 | Lite On LVW-5005 DVD Recorder
Word Processor no longer reads disks
Sounds like the disk drive has died. Brother does not have parts for this model anymore. You may have to find some one to convert your disks to another format.
Oct 07, 2013 | Office Equipment & Supplies
Manual for LVW-5005X CD/DVD need copy Have the Player need manual to hook up to TV
The user's manual is available from Lite-On as a .zip file. http://us.liteonit.com/us/index.php?option=com_wrapper&Itemid=153 Select Audio/Video and then your model number in the two drop down menus; then click Search.
The direct link is http://www.liteonit.com/DOWNLOADS/DC/LVW-5005X/user_manual/en_us/LVW-5005X_US_English.zip .
You will need to unzip the file to read the document. With Windows, right click on the file after downloading and select "Extract All".
I hope this helps.
Apr 30, 2011 | Computers & Internet
I have a DVD Recorder, Lite-On LVW-5005X. I have been having sporadic problems with the disc tray not opening for some time. But usually after repeated attempts, it would open. I have recorded and...
You need to replace the disc tray belt,it streches with age.It is called a square belt,size 1.9.To open try tapping on TOP of cabinet with your knuckles just above the disc tray door.While you are doing this press the Open button.Once again this must be done at the same time,the door will open 90% of the time.When you get it open you will see the little black square belt,this can be removed and replaced with a twizzers.Make sure belt is in the track if not it will jam and door won't close.
Dec 10, 2010 | Lite On LVW-5005X DVD Recorder
The eject button on my VRDMC5 DVD recorder does not work at all.
When idsk is not recognized it is because the laser mechanism can no longer focus on the disk. If this happens with all disks then the unit is fubar and it is time to go shopping since repair is not cost effective.
Apr 24, 2017 | Sony VRD-MC5 DVD Recorder
Unreadable disk error
The laser in 5101 could be defective or maybe just dirty.Try cleaning with a commercial cleaning disc,put a drop of rubbing alcohol on cleaning brushes.When this happens sometimes it will still be a usable disc but not always.Try putting in another dvd player or recorder or your PC if it plays dvds,the readers in PC are of a better quality and will often read discs that those cheap dvd readers can't.
R+ or R- discs need to finalized after recording RW+and RW- discs do not.It is always a good policy to finalze the second your recording is finished otherwise it may not play in other players or recorders.
When you make a recording in a dvd recorder an it doensn't recognize the disc it just recorded it quite often has a defective laser.This particular model has been plagued with early laser failure.
Mar 14, 2008 | Lite On LVW-5101 DVD Recorder
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
No Response To Open Button on Remote
I had the same problem- the door would not open.
I opened up the unit removed the drive and discovered a lever which allows to manually eject the tray. After playing with this a bit, I discovered that if I hit open on the until and depress this lever, it would open reliably. Not ideal, but at least it gives me ability to open/close.
Unfortunately once I put the unit back together, it no longer recognizes any disks. I must have damaged some disk sensor mechanism in the process. On the bright side however, it open/closes reliably now, doesnt even require the lever to be depressed manually. So if I can just get it to recogize disks, I am in good shape again.
You may not need to open up the unit and remove the CD burner to get to the manual lever, but you have to remove the fancy cover plate for the tray to be able to access the lever. The cover plate on mine is silvered and says "All write". The lever is on the underside of the tray to the left side, a paperclip might be able to poke thru to access it without removing the whole front cover.
Good luck.
Dec 27, 2007 | Lite On LVW-5005 DVD Recorder
Lite On LVW-5005 DVD Recorder Logo
532 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
jason
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
