I have a Toshiba projector TDP-S8 when you hit the power button the lamp flickers for about one or two seconds then goes out. I'll have to wait about 20-30 sec. then I can do the same thing again. can you tell me what the problem is. Thanks TonyI have a Toshiba projector TDP-S8 when you hit the power button the lamp flickers for about one or two seconds then goes out. I'll have to wait about 20-30 sec. then I can do the same thing again. can you tell me what the problem is. Thanks Tony
You can't post conmments that contain an email address.
after installing the new lamp, hold the volume top & bottom key simulteniously, when green light indicate at panel start the projector & go to service there you may found reset lamp ? press yes the lamp will reset.
First make sure your signal cable is ok and well connected.
Next check the projector input settings in the menu, and confirm that you have the correct input selected.
Also make sure your Laptop display settings allow for an external monitor.
Baba Anji
The reason why the projector is shutting off is so the lamp doesn't explode. It's more of a safety feature on the projector, you can reset the lamp and it might work for another 500hours. If the picture is still pretty bright I can get you the reset procedure, but be warn that when the lamp does eventually blow it could shatter the glass inside, so be careful, it shouldn't hurt the unit.
I have the same problem but with a Toshiba laptop.
