Question about Durabrand DU1901 TV
28 inch Hi get whistling noise but not all the time any solutions.
    Problem Solver:
  • 7 Answers
Have a look around the TV and see if you have any recording equipment there if there is move it that will stop the whistling.
Posted on Jan 01, 2008
Whistling noise during down shifting
Hi Anonymous, could be clutch hub or throw out bearing. Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 04, 2014 | 2002 Harley Davidson FLSTS Heritage...
Whistling sound form tweeters
The unit is picking up noise from the electrical system of the vehicle--power is either connected to the wrong place or a noise filter needs to be inserted at the voltage source for this equipment.
Apr 23, 2012 | Infinity Speakers Infinity Reference 1031t...
My 1yr old dishwasher is makes a whistle noise
Hi jgonsalves,
Please check my following tip for the full solution to your problem.
Click here -> L.G E1 Error / Whistling Sound
Kind Regards :-)
* If you found this solution helpful, please rate it.
Jul 06, 2011 | LG LDF6810ST Stainless Steel Built-in...
99 dyna 88 cubic inch pops and whistles at idle ,engine noise and no fuel milage 40000 miles on engine,engine light stays on
If it'll whistle "Dixie", I'll buy it. (BG) No, if it's popping and whistling, it's probably got a vacuum leak somewhere. If it's a carbed engine, just look for an unplugged VOES vacuum line. It comes right off the backside of the carb. It might be time for a set of intake gaskets as well. If it's fuel injected, I can't help much there as I don't know a lot about those but if it's popping while idling, it's lean whether it's carbed or injected. If it's injected, you'll probably have to take it to a dealer.
Good Luck
Steve
Jul 09, 2010 | 2000 Harley Davidson FXD Dyna Super Glide
Shower head is making high pitched whistling nois
The holes are probably clogged from hard water. Take the whole head assembly and dip it in a bucket of CLR for an hour or so. Then rinse off and give that a try. If your cheap, you can use a bucket of white vinegar and a little bit o water, but the smell is most disagreeable.
Feb 12, 2010 | Grohe 28444000 Chrome Movario Movario Five...
We have a 1990 Daihatsu charade, at times when we start the car and drive we hear a whistling noise, this occurs now and then, does anyone know what this could be? And also how do we get the rev odometer...
1. That whistling noise is a loose fan belt,tighten it or replace it.
2.The odometer - just remove the end that goes into the engine and have the groove on it enhanced , it will work fine
Oct 20, 2009 | 1990 Daihatsu Charade
High pitched whistling
Try changing refresh frequency, color depth or resolution (wait for the whistle to appear before testing). Admittedly, you might have to give up some image quality - less colors, or less resolution. There is probably a problem in the TV syncing mechanism - if you can, try getting it replaced. "High pitched whistles" in video and TV hardware are usually harbingers of bad news.
Aug 24, 2009 | Samsung SyncMaster 245T 24 inch LCD...
Whistling noise when accelerating
you most likely have an aftermarket radio installed
the noise you hear is engine noise, if yo turn your radio off it will go away
this can be fixed by either getting better wiring for your aftermarket radio or by installing a noise filter, you can purchase that at most big electronic stores
Jun 23, 2009 | 2002 Acura 3.2TL
2003 Mercury Grand marquis utlimate edition Whistling noise coming from the rear and eerie annoying.
What speed?
In the trunk area?
Around the rear doors?
Only in crosswinds? Sometimes the antenna makes a whistle noise in cross winds at 50 plus mph.
Get a roll f 2 inch masking tape, and tape off areas one at a time and test drive.
May 12, 2009 | 2003 Mercury Grand Marquis
Occasional 'whistling/whining' from back of TV
I wonder if there is enough air circulating around your equipment?? My DVD recorder makes a sound unless I open the doors on the cabinet that contains all of my equipment. The cable company says it is a fan to cool down the units.
Jan 30, 2007 | Bush WS6671 28" TV
Televison & Video Logo
96 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
