Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
PIP on an older SONY with DISH
Somehow the DISH remote turns on PIP but how do we turn it off
or disable the PIP so it won't do it again?
  • 43 Answers
If you are using the satellite remote then you need to contact the dish company and ask them how to program the remote. Good Luck
Posted on Jan 23, 2008
Pip won't turn off. can the pip be removed or bypassed?
Some of the older sets with PIP require only the original remote to operate or turn on and off.
The PIP board usually develops problems with surface mounted caps and there is a "modification" where traces are cut and two 4.7 mfd caps inserted which will bypass the PIP board from the set--a model number would tell me if this is possible in your set or not--you missing the original remote? Almost any Mitsubishi remote of the era with PIP controls should do the job.
Dec 02, 2012 | Mitsubishi Televison & Video
Picture in picture Mode will not turn off
Your universal remote control does not have the PIP control feature of the original.
Jan 01, 2018 | Hitachi Televison & Video
I have a sony (model KP61V75) a split screen came on (two pictures) and I cannot figure out how to get it back to one screen. Im going crazy!
Some television remote controls have a PIP OFF button, while others only have a PIP button that needs to be pressed repeatedly until the PIP/Twin-View window disappears.
NOTES:
  • Some Sony rear projection televisions have a FLASH FOCUS button that will turn off the PIP/Twin-View feature.
  • Some Sony universal remote controls, if programmed to operate a Sony TV, can disable the PIP/Twin-View feature by pressing the REC or ENT button.
  • If the original TV remote control is not available or is not functioning properly, auto programming the television tuner orperforming a power reset may deactivate the PIP/Twin-View feature.
  • If pressing the appropriate buttons on the TV remote control does not work, then the PIP/Twin-View window might be from a two-tuner cable or satellite set-top box. If this is the case, use the remote control provided with the set-top box to remove the PIP/Twin-View window.
Jan 25, 2011 | Sony Televison & Video
My tv is a sony xbr. somehow we got ourselves a black box (small) in the lower right hand corner. The remote doesn't have pip and we never used the pip. but i cannot get rid of this box. i tried to reset...
A solution I found for our KV-32XBR200 was to press Setup on top of the set, then select the "Demo" item with TV/Video. The text overlay apparently banished PIP. Verified this twice, as I'm at this page because our remote can only turn PIP on :-).
Oct 21, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Don't have original remote control. Somehow, a window for PIP opened, and I can't get it to turn off. Have a new sony remote RM-V310A, but the PIP button won't activate the remote. Any...
Many TV functions can be controlled from the on-screen menus using buttons on the TV itself. These include all kinds of settings however Sony did not include PIP in these menus. Therefore a valid remote is required to operate PIP. One thing you could try is removing the cable from the secondary input on the TV which provides the signal for the other picture. Without an input signal PIP may be disabled. Also, try buying a universal remote and setting the proper code for your TV. Original remote could be hard to find but remotes.com may have one.
Aug 05, 2010 | Sony KV-27S45 27" TV
How to work a sony 40 in projection tv's picture in picture feature
Locate PiP button on TV remote and press it to turn on picture in picture function and again press the same button will turn off PiP feature.
Hope this info will help you.
Thanks.
Nov 28, 2009 | Sony Televison & Video
Turning OFF picture in picture!
I have an old Sony Trinitron; had the same problem... somehow turned on the pip while moving the television off its stand. I have neither the remote nor the manual.
Does your tv have a 'demo' button on the front? Mine does; when I pressed it, the pip disappeared!
Jan 06, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
PIP for Sony KV-27XBR45 television trouble shooting
If you have the original remote for this TV on the pip menu (left side slider on remote all the way up) there is a pip off button. If you unplug the unit long enough it should go back to normal. If you go into demo mode and then exit mode you will again be out of the pip. With out the original remote you cannot easily turn pip off.
Apr 13, 2007 | Sony KV-27XBR45 27" TV
PIP won't turn off
I pressed "Demo" on the front of my TV and it worked, I have an old Sony KP-53XBR35 VIDEOSCOPE XBR - no original remote and the Universal remote has PIP button but would not shut it off.
Finally it's off!!!!
Jan 23, 2007 | Sony KV-35V35 TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
206 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
