Question about Dryers
Kenmore dryer. 80 series. 6 years old.
Dryer runs but does not heat. had overtemp switch replaced. ops ok now. is there a reset botton on this switch? repair took only 10 minutes.
All of a sudden there was no heat. I turned the knob a few times, sometimes it would get hot and then the next time it wouldn't. Help! Last year, the thermostat was replaced. Once the heat went, it never came back.
  • 2 more comments
  • RRH57 May 11, 2008
    drum rotates no heat kenmore 90 series checked coils,hi limit switch,ops.thermostat,and thermo fuse.120 volts everwhere.turn on dryer voltage drops to 1volt
  • Anonymous Jun 04, 2008
    kenmore 80 series runs but no heat. where is the fuse and how do you test it
  • coulthardfam Jun 18, 2008
    Our dryer drum rotates but the heat lamp heats up then clicks and the flame starts very briefly then stops but the drum continues to rotate.
  • Anonymous Aug 09, 2008
    will not heat
  • 240 Answers
There is no reset button on these thermofuses unfortunatly. Sometimes you can have a timer go out and cause a fault in the thermostats, thermofuses, etc. Doesnt happen to often, but it does happen. Be sure before you spend a lot of money, that you thoughly clean and check you dryer vent tubes or pipe. A clogged vent tube will normally cause major league problems (i.e. burned thermofuses, busted elements, out-of-temp thermostats, slow or no drying conditions, etc.). You can replace these yourself pretty easy if you have some hand tools (call Sears to fix and you can buy a new one) and a couple of minutes. Let me know if you want further instructions or help. Good Luck!!!! JIm
Posted on Dec 30, 2007
Sounds like there is dirt and or lint in the fire eye that is used to keep the gas on. Find that, clean it, and try again.
Posted on Apr 27, 2008
My dryer will only run for 5-10 minutes
sounds like you have a bad motor,when it heats up it's stalling and when you go to restart it there are start windings and run windings in the motor it's not switching over to the run windings so when you hold the start switch in you're sending constant power to the motor,all it does is when you push the button it's a momentary switch power goes to the motor and hits the start winding in the motor should be just for a moment,then it switches over to the run winding and this keeps the motor running,your motor isn't doing this,
Dec 23, 2017 | Whirlpool Dryers
Dryer runs and heats but cuts off by itself after a few minutes of running time. Just started doing this. Help please. model # medc700vw0
Check the filter and ductwork for lint build-up (inside the machine and out ... all the way to the vent on the outside of your home).
If this is ok, the cycling thermostat (the one that monitors the temperature and turns the dryer element on and off) is probably going bad. This usually progresses from functional to gradual failure as the bimetalic element no longer pushes the little rod inside to its full limit.
These are relatively cheap and one of the easiest repairs on a dryer.
Check here for the correct part and how-to videos:
Good luck.
Mar 01, 2011 | Maytag Dryers
Okay my dryer has been popping the CB for the last three days, I through it was the two thermostat's were replaced. Ran the dryer ops checked normal, now when I put a load of wet clothes in it runs for...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
I garee with you about the motor, but it also could be the heating element heating up and shorting out...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Sep 09, 2010 | Hotpoint NVL333EY Electric Dryer
The igniter fires the gas, it burns for a minute or less, then stops and won't restart unless the dryer is stopped and restarted? Is this a coil problem?
Sounds like a clogged vent. If you let it run for a few minutes after it shuts off, it will come back on. Your overtemp. thermostat doesn't allow it to work, because the hot air is not being sucked in. But to answer your question, not the coils for sure in my opinion. When coils fail, it won't turn on after 10 min of running or more. Not right away.
Maytag Neptune dryer repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | Maytag MDG9206 Dryer
Mdg5500aww no heat / flame.
Yes, that open switch is the high limit thermostat. this will shutdown the unit and prevent it from heating. you must replace the open switch(thermostat) asap and, replace the thermal fuse as well.
Jul 24, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dyrer will spin but no heat, i noticed the other day after i took cloths out it was fire red in the back of dryer. model # ler6620pq0
It sounds like a lack of airflow.
Has the lint trap been cleaned?
Depending on the view you had of the "fire red", you could be looking at the heating coils, which will glow some. Unless the overtemp switch is not functional, returning air flow to the dryer may be the only issue.
Jul 09, 2009 | Whirlpool Dryers
I have a Kenmore Elite model # 11063032101. It
If exhaust is blocked or restricted from back of dryer to outside of home it will cause the dryer to over heat the high limit switch. Repeated overheating will weaken the over load switch and it will need to be replaced if normal operation can not resume without restriction. Sea Breeze
Mar 26, 2009 | Kenmore Elite HE4 Electric Dryer
Whirlpool gas dryer
From the sound of your problem, it appears you may have a faulty overtemp switch that gets too hot , opens the circuit to disable gas and flame, then cools down and allows it to start again.. Since you didn't provide a specific model number with your question.. use this link to find replacement whirlpool thermal fuses etc..
Hope this helps..
Sep 06, 2008 | Whirlpool Dryers
Ghost in my dryer????
Here are a few ideas of what might be wrong.. based on your description.. You've bypassed the thermal fuse and the dryer worked however once you removed the bypass, did it work after that? based on your symptom.. it appears that one of the auto-ressting 'overtemp snap switches' may be your problem and may be shutting your system down because it is tripping from excessive heat or it is prematurely tripping because it is defective. I've included a website link that shows assembly drawings and parts breakdown for you to examine but I suspect that you have a bad overtemp switch.. ( I assume that you've cleaned out all lint etc from the vent system both inside and outside the dryer) If you haven't... then you may not get adequate air flow and you truly are getting an overtemp condition.. Good luck.. Here is the link
Hope this helps !
Sep 05, 2008 | Whirlpool LER4634J Electric Dryer
Dryers Logo
611 people viewed this question
Top Dryers Experts
