Question about Linksys Wireless-G WRT54G Router
Xbox 360 dns problems
All of a sudden today i am having a problem with my Dns i have entered it in manually and automaticly. and i still cant connect any tips?
I have done some troublrshooting and I found a way that may fix the problem (cause it fixed my DNS problem) I call my method "DNS Leaching"...don't ask why I have such crappy method names. I thought that since the Xbox was having trouble getting the DNS data so that I just hooked the Xbox's eaithernet directly into the modem, waited a few minutes then hooked the eaithernet back into my router. The Xbox then worked perfectly.
Step 1: Xbox <----> Modem wait a few minutes.......... then Step 2: Modem <--> Router <-->Xbox (or whatever your setup is)
Posted on Aug 25, 2008
Kk thank u
Posted on Jan 22, 2008
  • 32 Answers
There is an option that needs to be set on your router. I cannot recall the exact setting, but Im sure google can yeild the results. I would also give the XBOX a static address and put that address in the DMZ. Umm... My friend had the same issue, and I will check with him and report back.
Posted on Dec 31, 2007
Connection to winows media failed
1. check your netwok calble properly
2. check your router internet connection
3. follow these steps
Accessing network settings loadTOCNode(2, 'moreinformation'); To access the Network Settings area, follow the steps for the version of the Xbox 360 Dashboard that you are using.
New Xbox Experience Dashboard:
  1. From the Xbox 360 Dashboard, select System Settings in the My Xbox area.
  2. Select Network Settings.
  3. Select Configure Network.
Legacy Xbox 360 Dashboard:
  1. From the Xbox 360 Dashboard, move to the System blade.
  3. Select Edit Settings.
IP settings, IP address, subnet mask, and gateway loadTOCNode(2, 'moreinformation'); Collapse this imageExpand this imagenetworksettings-basic.jpg
After you select either Configure Network or Edit Settings, you will be on the Basic Settings tab, which contains your IP and DNS settings. When you select the IP Settings block, you are prompted to select an Automatic or Manual configuration. If you select Automatic, the Xbox 360 console will try to automatically determine your IP settings from your network or from your modem or Internet service provider (ISP). This option is recommended for most users.
You may have to or prefer to manually configure the IP settings, especially when a static IP address is used. This is necessary only if your ISP has issued a static IP address, or if you have configured the router to issue static IPs (and DHCP is not used). To manually configure the settings, select Manual, and then enter the IP Address, Subnet Mask, and Gateway by using the keyboard on the screen. When the information is complete, select Done.
DNS settings, primary and secondary DNS servers loadTOCNode(2, 'moreinformation'); After you select either Configure Network or Edit Settings, you will be on the Basic Settings tab, which contains your IP and DNS settings. When you select the DNS Settings block, you are prompted to select Automatic or Manual configuration. If you select Automatic, the Xbox 360 console will try to automatically determine your DNS settings from your network or from your modem or ISP. This option is recommended for most users.
You may have to or prefer to manually configure the DNS settings, especially in scenarios in which a static IP address is used or where DHCP is not available or not offered by the ISP. To manually configure the settings, select Manual, and then enter the primary and secondary DNS server names by using the keyboard on the screen. When the information is complete, select Done. Note You do not have to enter a secondary DNS server to connect to Xbox LIVE. A secondary DNS server is required only if the primary DNS server has technical problems.
Wireless settings loadTOCNode(2, 'moreinformation'); To configure your Xbox 360 console to connect to your wireless network by using an Xbox 360 Wireless Adapter, follow these steps:
  1. Access Network Settings .
  2. On the Basic Settings tab, select Wireless Settings.
    Note If the wireless settings area does not appear or is unavailable, click the following article number to view the article in the Microsoft Knowledge Base: 909333 (http://support.microsoft.com/kb/909333/ ) While attempting to view the settings for a wireless network connection, all the wireless functions appear to be disabled in the Xbox Dashboard
  3. Follow the instructions to select your wireless network, select your wireless network name, and then enter your wireless security information.
  4. Select Done.
PPPoE settings loadTOCNode(2, 'moreinformation'); If your Internet service provider uses PPPoE authentication, you have to enter the settings in the Xbox Dashboard if you have a direct connection through a modem. If you use a router or a gateway instead, leave the PPPoE settings blank because the router performs PPPoE authentication. Note If your ISP does not use PPPoE authentication, make sure that these settings are blank. To learn whether your ISP uses PPPoE authentication and to learn the correct PPPoE information, contact your ISP.To configure the PPPoE settings on your Xbox 360 console, follow the steps for the version of the Xbox Dashboard that you are using.
New Xbox Experience (NXE) Dashboard:
  1. Move to the System area of the Xbox Dashboard by using one of these methods:
    • Press the Xbox Guide button on your controller to open the Xbox Guide, scroll to the right to access Settings, and then select System Settings from the list of options.
    • Select the My Xbox channel, and then scroll to the right to select System Settings.
  4. On the Additional Settings tab, select PPPoE Settings.
  5. Use the keyboard on the screen to enter the PPPoE information that was provided by your ISP.
  6. Select Done.
  7. Select Back to return to the main Network Settings area.
  8. Select Test Xbox LIVE Connection to restart the test with the new PPPoE settings that you have configured.
sure it will work thank you
Mar 14, 2010 | Microsoft Xbox 360 Console
How do i set up xbox live
  4. Select Done.
  6. Select Done.
Feb 11, 2010 | Microsoft Xbox 360 Elite Console - Black
I cant get a valid ip address for my xbox 360
set settings to automatic
if that doesnt work open command prompt on your computer type ipconfig and hit enter
manually enter the ip and dns settings that come up
if that doesnt work google xbox 360 port forwarding
Nov 17, 2009 | Microsoft Xbox 360 Console
Xbox live trouble
Try putting everything to Automatic if it still doesnt work go to your pc go to Start then Go to RUN in RUN type CMD hit enter, Black screen pops up type in ipconfig hit enter SUBNET MASK IS YOUR DNS try that
Sep 19, 2009 | Microsoft Xbox 360 Console
Dns server
Hello.
Go to network settings in the system tab of your dashboard, then first set all to automatic and try if it works then if it shouldnt take a look at the setting gateway and write down the IP, it should be something like 192.168.1.1 or so, then manually edit the DNS servers in the network configuration and add the gateways IP as primary DNS.
Retry if it works if it shouldnt you will have to get the direct addresses of the DNS servers of your provider to get these click on your start menu button in Windows then look for "Run..." and enter the command cmd and hit enter.
A command line should pop up enter the commain ipconfig /all in it that will list the DNS servers set these up for the xbox as well and retry again.
If it should still not work then something else must be wrong with your connection setup like your router blocking your xbox because you didnt allow it to connect to the internet or so, there are various reasons.
I hope this helps.
Kind regards,
Wilhelm@Xboxexperts.com
Jan 04, 2009 | Microsoft Xbox 360 Console
Xbox 360 Connection to internet
the IP address will fail when it is set on manual, rather than automatic. Be sure, once you enter it, it is set to automatic
Jan 03, 2009 | Microsoft Xbox 360 Console
Xbox 360 live DNS test failed
if you are connecting directly to the modem, then you are going to need to get the dns info from your ISP. If you have a router just put the router address or let it find it automatically. Also check that the router has the right dns settings from the ISP.
Jun 09, 2008 | Microsoft Xbox 360 Console
Dns numbers
Maybe you have a bad Xbox 360 Wireless Modem.
Feb 16, 2008 | Microsoft Xbox 360 Console
Xbox 360
Contact the people you get your internet from. tell them you need to register your xbox. I have the DNS issues when i visit my girlfriend at college since they dont like to keep the Download speed high for the students. always fails
Dec 16, 2007 | Microsoft Xbox 360 Console
Linksys Wireless-G WRT54G Router Logo
285 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
