Posted on Oct 21, 2009
Need to set clock on jvc compact component stereo amp
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 21, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
257
Points
How do I set the clock on my jvc compact disc audio system. model # KD-G110
2000 buick lasabre Does it have factory amp??where is it located??
Depends on what audio system you have . Base , upscale etc.... You need to look on the RPO code sticker , could be in the glove box , center console , trunk , driver door jam ? RPO - regular production order .
UL0
Radio AM/FM Stereo, Seek/Scan, Auto REV Music Search Cass, Auto Tone, Clock, ETR
UM7
Radio AM/FM Stereo, Seek/Scan, Clock, ETR
UN0
Radio AM/FM Stereo, Seek/Scan, Compact Disc, Auto Tone, Clock, ETR
UN6
Radio AM/FM Stereo, Seek/Scan, Auto Rev Music Search Cass, Clock, ETR
UP0
Radio AM/FM Stereo, Seek/Scan, Auto Rev Music Search Cass, CD, Auto Tone, Clock, ETR
Jvc stereo model mx-kc4 cd tray won't open make loud noise
sounds like theres something keeping it jammed in might be one of those pull hard and hope jobs :) good luck
Stereo
You will need to change the audio output ic in the stereo to reset it.
4helpful
How to set the clock
IT IS STUCK ON DEMO AND CANT SET THE CLOCK
Need manuel or how to set clock
Are you sure that is the model number? I looked it up and that isn't a model number for a JVC.
2helpful
P-Error on JVC compact component system FS-GD7 when turned on
1. Unplug the JVC compact component power cord from the power outlet.
2. Unplug any connected devices.
3. Press and hold the JVC compact component power button for five seconds.
4. Plug the JVC compact component power cord back into the power outlet and turn on the JVC compact component
5. Open the menu to confirm that the JVC compact component is responding again.
6. Turn off the JVC compact componentand reconnect the devices.
7. Turn on the JVC compact component...
14helpful
Clock set
To set the time press and hold the select button in the centre of the volume dial until the word demo appears on the screen. From here you can change the time by pressing the next track >>I button to select clock h. Use the use the volume dial to select the hour. Use the next track button >>I to select clock m and use volume dial to set the minute. This same procedure can be used to change the dimmer on/off, demo on/off and the amp gain. Have a play around. Hope thjis helped.
2answers
HOW TO SET CLOCK
I NEED INFO ON HOW TO SET MY CLOCK ON MY JVC, MP3, KD-AR300. SPILLED COFFEE ON INSTRUCTION SHEET...........BUMMER.................:>((((((
NEED YOUR HELP ASAP PLEASE...............
THANK YOU VERYMUCH grandmangrandpa34yahoo.com
2helpful
2answers
Car clock setting
For the JVC KD-G200 look here for instructions on how to set the clock...
http://www.fixya.com/support/p187738-jvc_kd_g200_cd_player/manual-17158/page-9
18helpful
4answers
Setting Clock for JVC-KD-G420
Here is the link for the manual http://books.jvcservice.com/download/289413083/38360.pdf page 7 Hope this helps :)
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
