Question about Belkin (F5D7001) 802.11g/b Wireless Adapter
My F5D7001 won't work
I can't seem to be able to connect tot he wireless internet. Whenever I attempt, i am unable to use my device as per the instructions. i followed the instructions exactly, and it still refuses to work.
  • Anonymous Feb 14, 2008
    Same here, I know this card works because I pulled it from a Win2K server but I can't get it to work under WinXP 64bit. I'm pretty sure that these cards won't share an IRQ because it wouldn't work in another server that only had one slot available but it would work if I removed the SCSI card and put it in that slot or removed the Graphics card and used that one but I couldn't get all three cards to work together...
    Anyway I think I know why mine isn't working, not 64bit compatible?
    Just a guess.
    Genius:
  • 1,124 Answers
Check the settings with your wireless router and also If the wireless network is available.
Renew your Ip address. Disconnect and connect your device.
If you're using the belkin software, only install the driver of the card instead of the wireless utility.
Try using Windows Wireless utility.
For support and further question you can go here:
http://www.belkin.com/support/product/?lid=en&pid=F5D7001
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Posted on Oct 15, 2008
Blinking lights router
The POWER lamp should be green, 100% of the time.
The WIRELESS lamp should blink, as it "pools" many times per second, chatting with (or looking for) wireless devices.
The INTERNET lamp should blink, whenever any wired/wireless device tries to access the Internet.
For each WIRED device, the lamp should be green, 100% of the time, whenever the device is responding (maybe even when the device is "sleeping").
Jul 15, 2014 | SonicWALL TZ100 UTM Appliance
I am using Linksys Wireless- N (wrt120) and my download speed seems to work great but when I browse the internet my pages won't load. Sometimes they will load very slowly. It seems like the connection
There may be competing wireless routers or networks nearby on the same band. Within the router's interface, try switching to a different band (2.4 Ghz vs. 5.0 Ghz) or use different radio channels. By default the router will attempt to do this automatically, but you may want to try adjusting them yourself and see what you get.
Oct 24, 2017 | Cisco - Linksys Wireless-n Home Router -...
Unable to connect to the my wireless Internet
Try "rebooting" your internet. If it's fed through a router, disconnect the power to the router, as well as all of the connections, then reconnect them. Re-connect the power last.
Also, try moving closer to the source of your wireless internet. Sometimes the Dsi won't pick up on the signal because it has a weaker wireless receiver than a computer or most devices that will connect.
May 19, 2011 | Nintendo Dsi Pink Console
When I connect my computer to Netgear MR814v3 router via wire, I can get internet on my computer. However, when I try to connect wireless internet, I can see my router's SSIP (the name I gave for my...
You have to enter the router password on every wireless device you want to connect to the internet. You usually only have to do it once per device, but it won't connect without the password. The password it's looking for may be on the label on the router or in the wireless setup page of the router.
May 09, 2017 | NetGear MR814 Wireless Router
Can not change the wireless channel
A very good question!
I'd love to answer this. Belkin utility at times has some bugs. As you said you have downloaded the latest version of drivers and utility. Latest drivers are good but utility will not be of much use, I, as a technician would highly recommend that you use Wireless Zero Configuration in case of Win XP or WLAN Auto-config in case in case of Win Vista or Win 7. But if you have older versions of Windows, older than Win XP, only then utility has to be used. Enable WZC and WLAN A-C in Microsoft Services(Local) page.
Start > Run > services.msc > Ok > Services (Local) > Start the service.
At worst instances, if you are forced to use the utility, remove all SSID (wireless network names) from My Connections. Note: Remove all of them completely.
Also, i would recommend that you configure your wireless mode to be "802.11g only" on the router as F5D7001 is a 802.11g standard PCI card, and also turn ON the wireless PROTECTED MODE on the router. This will enhance the performance of your wireless devices in cases of heavy wireless traffic.
This is sure to work! Again, thanks for such a question.
Feb 02, 2010 | Belkin (F5D7001) 802.11g/b Wireless...
Belkin N wireless modem router cant connect
http://en-us-support.belkin.com/app/answers/detail/a_id/534/kw/7001/r_id/166
go this website select your version and model number download the drivers and install
go to ->run>services.msc
select wireless zero configuration -.>right click and start it
Jul 17, 2009 | Belkin (F5D7001) 802.11g/b Wireless...
Abit wireless adapter unable to locate wireless network
well!! I have an answer for you.your comp is loosing the IP address.connect your computer through cable then goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 26, 2009 | Abit (WLP-01) Wireless Adapter
Unable to connect a WGR614 Wireless Router to a DM111P Modem
Sounds like you need to port forward your router. Go to port forward .com. find your router and follow the instructions. Hope this does the trick for you.
Nov 26, 2008 | NetGear WGR614 Wireless Router
Ntl:Home Compatibility
When you say the networking is fine, I assume that you can connect all wireless devices together and access the router menu on IP 192.168.2.2 (refer page 23)
Is it possible that when you connect the router to the modem that both are trying to assign an IP to the other?
My router is set to get it's WAN IP from the modem (it's a d-link though)
refer to the manual on page 28- try setting the WAN/internet setting to dynamic. You should leave the host name blank and not clone the MAC address.
MANUAL
Post back results and I will try to assist further if required
Jul 06, 2008 | Belkin Wireless-N Wireless Router with...
I have purchased a Belkin Wireless G Router for a cable modem. I have installed however i am unable to see the wireless network. What have i done wrong ??
Hello experts....
My problem is not being able to work wirelessly with my laptop. My answers to your questions are underlined(I've used your questions to someone elses problem)
One possible issue is your router's wireless radio is not enabled- the light on the router is lite on the symbol for wireless
or the wireless radio is not enabled on the computer you are attempting to connect to the router with - there is a switch on the front of this machine which is switched to wireless.
There are many other possibilities as well. That is why we need you to carefully answer EACH ONE of the following questions.
(01) Which of the following is your router?
-->> F5D7230-4 (Wireless G Router)
(03) Are ANY of the computers connected to your Belkin router able to access the Internet?
YES
(04) If there are other computers connected to the router that are able to access the Internet, how are they connected? (in each case, please)
only this machine is connected but it is by....
(b) wired (using an Ethernet patch cable connected between the router and the computer)
(05) What is the manufacturer and model number of the computer you are attempting to access the Internet via the router on?
HP Pavilion dv2500
(06) What operating system is installed on the computer you are attempting to access the Internet via the router on?
This machine is operating on Vista but the internet access I have is with talktalk
(07) Have you ever successfully connected (wirelessly) to the Internet from the computer you are attempting to wirelessly access the Internet through your Belkin router on?
NO
I hope you don't mind me using your questions to someone else, I thought you might be able to figure out what I'm doing wrong. I am connected to the internet but don't seem to be able to work wirelessly. Lorraine
Apr 09, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin (F5D7001) 802.11g/b Wireless Adapter Logo
155 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
