Question about LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
Installed on MAC, then Plugged it to PC, now MAC won't recognize Drive
I installed my Lacie D2 Quadra on my MACBOOK PRO 17" and have been using it for months. Everything has worked great. I downloaded a large file and wanted to transfer it to my PC. I thought I could just use it like a jump drive and plug it into my PC and download the file. The PC opened a Wizard and I went through it. When it asked me if I wanted to Format it, I said no! Then I assigned it a Drive letter. I then realized, it wouldn't work with my PC. I plugged it back into the MAC and it doesn't see it now. I tried repairing it and re-initializing it, but it still won't see it. What do I need to do, to get my MAC to recognize it again and salvage all my files on it??
  • c33raven Jan 13, 2008
    I, too, tried to use the LaCie d2 Quadra as a sort of 'jump drive' between my friend's Mac and my PC. Nada, zip, bupkis... The "Safely Remove Hardware" window sees it there but that's all. Can't access it to transfer files and I certainly don't want to mess it up so it won't work on my friend's MAC.
    Advice?
    Thanks!
Look into Disk Warrior...its a hundred bucks, but it is a miracle worker of sorts and might fix everything for you.
the frustrating thing about DW besides its $100, is it takes less than a minute to fix problems I would fret over for weeks
Posted on Mar 01, 2008
My Macbook Pro running Mountain Lion does not recognise My Lacie D2 Quadra V2 (301442a) after upgrade from Snow leopard
Here's a good start.
Plug your Lacie drive into someone else Mac or PC using MacDrive Pro and see if it shows up.
Dec 02, 2017 | Computers & Internet
Lacie d2 Quadra Ejects Itself
I've had issues with the lacie mini power supply before. I can cause some wierd issues. Unfortunately, it isn't the cheapest thing to replace but that's probably the best place to look first.
Oct 16, 2012 | LaCie 1TB D2 Quadra eSATA/USB 2.0/FireWire...
My 500gb lacie d2 hd quadra is no more recognized by my macbook pro sys 10.7.3 (lion)???...
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.
Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4
if still no luck
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
May 10, 2012 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Upon start up I see the icon on my screen but then disappearing and reappearing along with all my other icon. the Lacie is disrupting my entire desktop & when I shut it down (Lacie) everything goe
I think the problem is because mounting problem of the logical drive .In this case to access your data in the drive you just need a macbook hard drive recovery tool .Remove the drive from your pc install the drive in some other mac pc and start it in target mode .Install this recovery tool and start recovering files but save it in different healthy drive .I am suggesting this tool because it works good for my missing partition problem.But purchase the full version to get good results.The demo version link is here...
Feb 03, 2012 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie d2 Quadra is inert: service/repair or buy new one?
Check with LaCie's support site at http://www.lacie.com/us/support/ and it's a good idea that you write down the serial number of your external disk.
Jul 09, 2010 | LaCie (300770) 250 GB Hard Drive
Will not mount on a Mac Book Pro 17"
try to connect lacie to windows base computer if it work, there a problem, with your mac book check if device manager recognize lacie drive if not check for the fire wire port.
Apr 10, 2010 | LaCie 1TB D2 HD Quadra FireWire 400 Hard...
Doesn't work
am not so sure if this is a similar issue with iomega2_bing.gif external drive in which the drive wont show up on My Computer but when the external drive was plugged into an ubuntu machine the drive was being detected and working just fine.
Please try to do the same. plug your external drive to an ubuntu machine and lets see if it can be detected. If it is then the hard disk has a similar issue with iomega drives. check this link for the solution.
Apr 05, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
How to format the LaCie 500GB d2 Quadra for Windows XP??
This way it should work...
Connect your drive to the computer...
Go to: Start > Control Panel > Administrative Tools > Computer management.
A new window will appear...
Select Storage > Disk management on the left of the window.
Now you will see the different drives that are connected or part of your system.
One of the drives listed there is your LaCie, i think you'll recognize it by name...
Right-click on it, and select 'format'
In the new window, select the new volume label (as you like it), the file system (use NTFS), and set allocation unit size to default.
Make sure 'Perform a quick format' is not checked...
Then click OK. Your drive will be formatted now... Don't interrupt the process
Mar 31, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie d2 Quadra drive... not showing up on PC after working on a MAC
You need to make sure the drive is formatted for the PC. The Mac will read and write to a FAT32 partition, but the PC cannot see a Mac formatted drive as you have seen.
The only problem is that there is a 32Gb limit per partition for FAT32 drives.
It's not ideal but it's the best you can do easily.
Jan 13, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Help please -LaCie D2 Quadra
Take a look at this link and see if it helps -
http://homepage.ntlworld.com/allcam/pc2mac.html
Jan 07, 2008 | LaCie D2 Extreme 300 GB Hard Drive
LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive Logo
163 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
