Question about Canon PIXMA iP4200 InkJet Photo Printer
More than one yellow cartridge installed
It would seem i am not alone with the two cartridge installed nonsense....does any one have a solution otherb than buying a new cartridge
  • bellcamp Jun 10, 2008
    I have taken out and replaced the offending yellow tank and it works for a while but not a permanent solution - is buying a new tank the only solution?
  • 286 Answers
No
Buy a new cartridge. The little chip in the cartridge is bad. Contact Canon and see if they will replace the new cartridge for you. Canon is a good company and may send a new cartridge right to your door.
Posted on Dec 29, 2007
I own a canon iP1300 printer and just bought a new canon pg- 40 black cartridge but its not being recognized by the printer, wat do i do
Can be a problem regarding the cartridge. What is the status of the color cartridge. Take a printout with the color cartridge alone. If no problem found get your PG40 cartridge replaced. One thing to be noted is that the printer always needs the color cartridge installed. Printer can work with color cartridge alone. But will not work without a color cartridge
Apr 09, 2011 | Canon PIXMA iP1300 Printer
Dell 926 Printer ink refill instructions
*see the manual and follow the instructions and fill it
* contact manufacturer about details
Jul 02, 2008 | Dell 962 Photo All-In-One InkJet Printer
Yellow ink will not print
On the Brother MFC series printers it uses remote ink trays as you will know, instead of having print heads directly on the ink cartridge. Whilst this approach makes it cheaper to produce the ink, and easier to change the cartridge, it can make it difficult to clear clogs.
There are several things you can do which may help, but B. and C. are at your own risk. All steps assume you have a new yellow ink cartridge.
A. In paint or another program, create a full page yellow image and keep printing it out. See if it gets any better after each print. If it does, continue until it seems to be working fine.
B. If you can manage to get to the print head, you can get a cue tip, dip it in rubbing alcohol and gently clean the print head. Leave 20 minutes to dry, and then do step A. again.
C. (AS A VERY LAST RESORT AT YOUR OWN RISK. THIS IS GOING TO RUIN YOUR YELLOW INK CARTRIDGE SO USE AN OLD YELLOW ONE IF YOU CAN) If steps A. and B. fail, you can put a "little" rubbing alcohol in the Yellow Ink Cartridge, and keep trying step A. If Yellow starts printing again, swap to a yellow cartridge that does not have rubbing alcohol in it. You are now going to have to cycle through many pages to clear the rubbing alcohol from the ink lines.
Note that if you keep cleaning the cartridges, it is going to use a lot of ink, and may actually hinder solving your yellow ink problem.
Good uck
Apr 24, 2010 | Brother MFC 240C All-In-One InkJet Printer
Printer will not print yellow in new cartridge or old.
If there was a tape stuck onto the cartridge, you must peel this tape off before installing the cartridge into the printer.
nLinked
Computer Support Services
Jun 07, 2009 | HP DeskJet 810c InkJet Printer
Canon iP4500 not printing yellow
take the print head with all the cartridges still installed out of the printer. take a soft microfiber cloth and gently wipe the exposed surface on the bottom of the printhead. You should get some ink to wipe off the printhead.. reinstall and retry your printing.
May 31, 2009 | Canon Pixma iP4500 InkJet Printer
Re-installing yellow cartridge in HP 2840
There is a gray button right of the LCD display that has a black arrow circling clockwise and four color dots (magenta/black/cyan/yellow). Push it until you see the "Rotating to Yellow" in the LCD display, then open up the top of the printer by pushing the big gray latch next to the picture card reader at the right front of the printer. You now have access to the cartridge. pull it out and examine it. If it is a new cartridge, check to see if you pulled the plastic dam strip out (which keeps the toner in place in shipment etc).
Sep 07, 2008 | HP LaserJet 2840 Printer
Hp Photosmart 3110
I have changed the BLACK cartridge ( as suggested ) but still cannpt print or move breyond the PROBLEM Note that comes up to CHANGE the Yellow and Black Cartridge - I cannot SCAN or COPY leave alone PRINT - please suggest a solution - Thanks ,
Adrian
May 14, 2008 | HP PSC 2210 All-In-One InkJet Printer
Cartridge error
remove the cartridge & install the new one cartridge other wise
May 10, 2008 | HP Photosmart C5180 All-In-One InkJet...
Won't recognize new cartridge
see here: http://www.fixya.com/support/t192382-near_empty_yellow
Sep 03, 2007 | Brother MFC-5440CN All-In-One InkJet...
Canon PIXMA iP4200 InkJet Photo Printer Logo
48 people viewed this question
old marine
old marine
