Sounds like your thermal fuse thats located in your console went out, you would need an ohm meter to test that for continuity.
Turn the breaker off to your dishwasher first!
Just unscrew the console screws and you'll see the thermal fuse thats snapped onto the control board.
You MUST replace the wires that come with it, or the fuse will keep blowing in the future.
Comments:
Oct 21, 2009
- If there are normally lights on, but they do not light... would definitely be a power problem... wall switch or a switch under inside bottom cabinet....usually if there is a bank of switches on the wall, one of them will shut power off to dishwasher when flipped.... try flipping the breaker off and back on.... if you do not know which one, look for one or feel for one that is kinda different or spongy if you press it toward on position (which is where it should be).. other wise you may have to turn them all off. Probably switch will have to be replaced.
Oct 21, 2009
- Please accept my solution if satisfied.
Popular Solutions for Kenmore 24 in. 17482 / 17484 /
The wash cycle continues for longer then normal and the heating element( on bottom of inside )stays...
(More)
The wash cycle continues for longer then normal and the heating element( on bottom of inside )stays hot.What is wrong with this dishwasher? kenmore model # 665.15789300
Cycle is disrupted. Many lights f;ashing. I have reset it previously when lightning struck near the...
(More)
Cycle is disrupted. Many lights f;ashing. I have reset it previously when lightning struck near the house causing the same problem. I have cut the power for fourty-five minutes. What buttons should I depress at the same time??
