Question about Philips DVDR3450H DVD Recorder/HDD Recorder
Philips DVDR3450H I have the above hard drive DVD recorder. When recording onto the HDD everything works fine. however when I want to burn a programme onto DVD to archive it, the burner seems to work, it transfers the content to the DVD and the DVD+R seems to have been burnt. However the disc will not read on any other DVD player. Is there a button I need to press to finalize the burn and create a menu? There is no mention in any paperwork I received, but most other philips DVD burners require this. Any ideas?
  • 2 more comments
  • Anonymous Apr 29, 2008
    impossible de graver sur un DVD RW , pas de probleme sur un DVD standard
  • evrard miche Apr 29, 2008
    impossible de graver a partir du disque dur vers un dvd rw par contre aucun probleme pour graver vers un dvd standard
  • chris-master Sep 08, 2008
    will not play any discs at all keeps coming up wrong format
  • cookie 10 Feb 26, 2009
    Recording from HDDto DVD .
    Wont record todisc,even though red light comes on.
    wont update stays at 0%
    Problem Solver:
  • 25 Answers
Put the DVD back into the drive...Then open the DVD menu by selecting the first tittle on the disc....Hold down the up arrow on the remote to make the "Editing menu" appear....Then select "Finalize Disc".
These instructions can be found on page 54 of the instruction book.
Posted on Dec 31, 2007
DVR will not record to hard drive
I did a (General Settings) RESET. Then I erased all programs on the HDD. Presto - it now records to the HDD a-ok.
Dec 19, 2011 | Philips DVDR3575H/37
How can I reset DVDR3450H, somethimes no menu sometimes we cannot get disk out
I have a problem getting disks out of mine most of the time, afraid to say that lifting the machine at the front, about 1cm.....and dropping it, unsticks the drawer
Xo)
Sad but it works
Jul 30, 2011 | Philips DVDR3450H DVD Recorder/HDD...
I have a DVDR3450H dvd Recorder and it cannot open when i open there is a 'philips' sign on the lcd and do nothing after some seconds it seems it restarts with the philips sign again but doesnt work.. i...
Pull out the hdd and format it in a computer in one single partition NTFS. Put the hdd back and upgrade with the last file disponible on Philips and enjoy again your device. Success.
Jun 13, 2010 | Philips DVDR3450H DVD Recorder/HDD...
Philips DVDR3450H. How format the HD?
Found a document DVDR3450H_3452H_3460H_eurp FWUpgradewk635.pdf Describes procedure of firmware update and disc formatting. Some cut'n'paste from the document:
2. Preparations for new HDD
In the event when the set unable to boot up or recordings not stored due to an defective HDD, the HDD will have to be replaced with the steps describe below:
1. Replace the Faulty HDD with a new HDD.
2. Before connecting the new HDD on the Digital Board ,the jumper pin at the connector of the HDD is to be removed.
3. Connect the new HDD to the Digital Board.
4. Power up the set . It will open the tray and prompt to load the upgrading disc.(the upgrade disc is
the same disc under firmware upgrading.)
5. The set will display
“Load”.
6. Put the upgrade disc and close the tray and the set will show
“Copy” ……… “Boot”
7. The rest of the procedure follows the software upgrade given in 1B -Procedure to apply the firmware upgrade.
*Note : 1)Do not press any button or interrupt the main supply ,otherwise the set may
become defective.
2)When the HDD formatting is successful ,the set will go to standby mode.
Jan 17, 2010 | Philips DVDR3450H DVD Recorder/HDD...
I'd like to access the hardrive on my DVR with my computer
No you can't access it with a computer. Some recorders (Pace, OpenTel and Humax) use a STAVFS file system which can be accessed by a programme called TDU. Philips use a totally different file system which is inaccessible by a PC.
Mar 15, 2009 | Philips DVDR3450H DVD Recorder/HDD...
I have aDVDr3460H Recorder it will not copy to disk direct nor from hdd.
Reset, then call Philips to see what exchange options you have. laser reader most likely bad
Aug 24, 2008 | Philips DVDR3450H DVD Recorder/HDD...
DVD Recorder
double check the firmware from philips website, but most likely that hard drive has an internal problem
Philips DVDR3450H Recorder does not record all of timed programs
When setting the record timer make sure that PDC / VPS is switched OFF.
PDC - Programme Delivery Control / VPS - Video Programming System is designed to allow for late starting or running programmes. Not all channels support PDC/VPS, so the recorder may be waiting for a PDC/VPS signal which isn't there.
Jan 17, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Problem Recording HDD to DVD-R
I had a few problems with my philips 3450 - I downloaded the latest software upgrade at www.philips.com/support , and my issues were resolved. Worth a shot...
Only other thing I can think of is you may have a faulty batch of DVD-Rs?
Best of luck!
Jan 16, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Philips DVDR3450H DVD Recorder/HDD Recorder Logo
381 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
