Question about Janome 4623 Mechanical Sewing Machine
Skipped stitches and getting worse
My stitches started skipping about a year ago. I took it into the dealer I purchased it from and they serviced it and said it was fine. It has continued to skip and now skips all the time. Not only on stitch 12 like before but also my straight sticth, my zig zag, etc. I am extrememl;y frusterated by this and am in the process of sewing over 50 costumes right now and its not working correctly.
  • taximommie Dec 31, 2007
    Where would I find directions on fixing the timing myself. All shops around here are closed till Wed or Thursday and I have taken it a few times now for the same thing to the dealer I opurchased it from....over a 2 hour drive. They make me leave it a week and then still don't fix it. I am more than a little irritated since I have purchased 3 different machines from them over the past few years.
  • taximommie Jan 01, 2008
    Ken you are wonderful. It works....my husband and I were able to fix it. Thank you thank you thank you...
    I am truely blessed.
  • 136 Answers
Try another repair center, unusual for this machine to have continuing problems
Posted on Aug 26, 2009
    Problem Solver:
  • 6 Answers
It might be that you have the wrong needle/ thread combination for the fabric that you are using. sharps for wovens, ball point for knits. the heavier the fabric and the thicker the thread the larger needle you need to use.
Posted on Jun 24, 2009
2 Suggested Answers
  • 980 Answers
SOURCE: MC4400 skips on the zig zag stitch when sewing
You must buse an anti static needle otherwise yoiu will miss stitches.
Posted on Jul 14, 2010
My machine is skipping stiches it seems its not picking up from the bobbin
Install a brand new needle and confirm it is inserted with the flat side facing the proper direction.. A bent, damaged needle will sometimes cause skipped stitches or even needle strikes inside the machine. A new needle is the least expensive cure for a lot of sewing machine problems. The needle should be changed about every 8 hours of sewing or at least when starting a new project.
Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Sometimes, skipped stitches will occur if the needle, thread, and fabric are incompatible. Be sure to use the correct needle for your project. Use a good quality thread--AVOID old or bargain bin thread!
If the machine continues to skip stitches, then it may be out of time. Search for sewing machine timing or take it for service.
Basic Maintenance Tension Skipped Stitches
What to Do If Your Sewing Machine Is Skipping Stitches
Don Ignore Your Sewing Machine Skipping Stitches Simple Solutions
May 24, 2017 | Sewing Machines
Skipped stitches
Skipped stitches could result from several different origins. First, easiest, and least expensive thing, try a brand new needle. However, if it is failing to pick up the bobbin thread all together, then it is probably out of time (search for sewing machine timing or take it for service).
Here are other suggestions for intermittent skipping:
10 reasons for skipped stitches
http://www.sewingreviews.org/what-to-do-when-your-machine-starts-skipping-stitches
Jan 03, 2017 | Sewing Machines
Skipping stitches?
skipped stitches is usually an indication of timing of hook and needle being off. The needle is not always picking up the bobbin thread. Suggest that it be serviced by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck. Home
Feb 18, 2015 | Husqvarna Husky 165
Skipping stitches
Skipped stitches
1. A bent or dull needle
2. The wrong needle for your fabric
knit fabrics require a jersey or ballpoint tip. Most wovens do well with a universal tip, and specialty fibers, like leather or metallic, usually require specific needles.
3. Incorrect machine threading
4. Unbalanced needle thread tension
Start by making relatively small changes and run a test stitch to evaluate the impact. If you need to adjust the tension dial using woven cotton fabric with good quality all-purpose thread and a new needle
5.check the needle is inserted correctly. The needle needs to be pushed as far up the needle shaft as possible. It's easy to insert the needle half way, clamp it down and think it is inserted correctly.
the flat part of the needle should be positioned towards the back. If the needle is not inserted correctly, it will not be able to pull up the bobbin thread and will cause skipped stitches.
6. If the suggestions don't help then it is time for a tune-up.
Nov 19, 2013 | Singer 7256 Fashion Mate Sewing Machine
Open-toe darning foot skips all stitches....help!
Hmm, have you installed a brand new needle? Make sure the needle is compatible with the thread and fabric. Sometimes a top stitch or microtex needle will work better for free motion quilting or darning.
https://www.superiorthreads.com/education/what-causes-skipped-stitches
https://moonlightingquilts.wordpress.com/2012/04/19/skipping-the-skipped-stitches-in-your-free-motion-quilting/
https://www.generations-quilt-patterns.com/skipped-stitches-driving-you-nuts1.html
Feb 26, 2018 | Kenmore Sewing Machines
Pfaff 1222E machine not working right
Skipped stitches means a bent or dull needle or improper needle for the fabric being sewn. Try a new needle of the correct type for the material being sewn. If this doesnt correct it, then it will be a timing or needle to hook problem and should go to a qualifed dealer for repair.
May 06, 2010 | Sewing Machines
Skipped stitches
You will need to take your machine to a dealer and have it adjusted. Machines should be cleaned and serviced at least once a year. Needles should be replaced when dull. Skipping stitches can also be from using the wrong kind of needle. When quilting on cotton, use sharp needles, when sewing on knits use a ball needle. You can use a universal needle but they aren't perfect and will cause skipping on some fabrics.
Apr 26, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Janome 4623 Mechanical Sewing Machine Logo
305 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
