Question about Samsung SIR-S4040R DirecTV DTV Receiver / 35-Hours Video Recorder
My SIR-S4040R no longer turns on..
A Power line snapped, causing a Spike! What I want to know - is there a built in circuit breaker in the SIR-S4040R that can be switched, or replaced? Any other ideas to test or fix it?
Thanks
John
  • numerics Jan 02, 2008
    Is there a way to test the power supply?
  • BlakJax May 19, 2008
    I have the same problem but my fan does turn on. So I am getting power but no lights on the front of the unit turn on and nothing happens. Does this mean I have a bad hard drive?
  • 38 Answers
If the unit doesn't power on at all, no fan spinning and no power light, then it's either your power supply, and/or motherboard. Your hard drive could be damaged as well. You can find power supplies by googling tivo power supplies.
You may be better off sending out the unit for testing/repair. I recommend CCS in Indiana. Fast, and friendly service, used them many times. You will need to lose anything that was on the unit (settings, season passes and recordings) to ensure the drive is fully functional.
Posted on Dec 30, 2007
  • Steve Vance Jan 02, 2008
    If you know how to test for voltages, yes there is to determine if the power supply is outputting the correct voltage, however, it doesn't sound like that is something you know how to do because you asked about it (no offense, I don't know how test the voltage on them either).
    Pretty much, if your unit isn't powering on at all, it's almost always the power supply.
    I would strongly recommend leaving it to the pros and sending it off for testing and repair. It's less headache on your part as you don't have to wonder if you've missed some minor detail where they know what to look for.
This happenned to me, and I took the power board out of the tivo and found that one of the solder joints on the main power supply connector had vaporized. I re-soldered it, and now the tivo boots, but gets no signal....
Posted on Sep 07, 2008
Can I remove a breaker from panel box cap the wires turn electric back on till I go get a new breaker.
You can but why not get a new breaker first. Once into the panel and you're done.
Nov 28, 2014 | Electric Electrical Supplies
Any ideas as to why the panel breaker for my Goodman CPE24-1AB heat pump would immediately trip when the air conditioner is turned on?
Without looking up the specifications for this heat pump, I cannot be certain, but I expect the operation to provide cooling may require more power than when heating. You probably can find the specifications online for this unit. As you probably know, power is measured in watts and is calculated by voltage times current. This also is likely to be 240 volts operation. If you take the specified power on cooling and divide by voltage (240), that will indicate the current in amperage that will be required to start it. Your circuit breaker is set for current and needs to be a higher current than is required. If that is the problem, you can buy circuit breakers at Home Depot or Lowes. You have to remove the front panel of your breaker box and snap out the circuit breaker. To be safe it would be good to turn off the main breaker switch before you open the front panel and remove the circuit breaker for the heat pump. Should your calculation of current required be less than the rating of the circuit breaker, that implies a malfunction of the heat pump in the cooling mode and would require a service call to the local representative of the heat pump manufacturer.
May 16, 2014 | Goodman CLQ36AR49 Air Conditioner
I have a Campbell Hausfeld oil type direct drive 7 gallon compressor. It often works fine but it frequently locks up until the internal circuit breaker cuts off the electricity to the motor. When the...
In our shop we have found the conditions you describe are almost always attributable to the power supply. First, never run a compressor on an extension cord, you are always better off running longer air lines. If you absolutely have to run an extension cord use a least a 12 guage cord no longer than 25 feet. If possible plug the compressor in as close to the circuit box as possible. Lastly the circuit the compressor is plugged into should be rated at least 15 amps, 20 amps is recommended for most compressors. Low amp lines cause the motor to overheat trying to get enough power and usually blow the circuit breaker at the motor and not at the circuit breaker. Lastly, use only compressor oil in the pump and make sure it's not overfull. This will also cause the motor to work harder and trip the circuit breaker.
Dec 17, 2010 | Campbell Hausfeld 2 - Gallon Direct Drive...
I have a 3 year old GE Profile microwave that began tripping the breaker recently. We would just reset the breaker and all would be fine for a day or two and then it began happening more and more...
If it tripped the breaker with you only hitting the door switch it sounds like the door switch has a direct short. This means a hot wire is going to ground not good. But the first part of your problem sounded like the circuit was overloaded for the breaker or right at the limit of the breaker.(probably a 15 amp breaker) Breakers do get old and if you are working at there limit they will trip and more often over time. What else is on this circuit? Make sure you are not overloading your line. Take each appliance or light and take the wattage listed on it and devide it by the voltage this equals your amps then add all the amps up they should not be more that your breaker and usually only 80% of your breaker the 20% is for devices with motors or compressors that spike amps temporarily. good luck and be careful
Aug 13, 2010 | General Electric GE Profile CounterTop...
Find remaining recording space on SAMSUNG SIR-S4040R
You will have to "Find space" by deleting something/anything to make "space" for "New" material. Basically it is trying to tell you the drive is filled up and ya need to either delete or cut & paste away to some other media, some data, to get more space to record more stuff. OK?
Jan 27, 2010 | Samsung SIR-S4040R DirecTV DTV Receiver /...
Dishwasher will not start after change in electric meter outside. Dishwasher "popped " when it was started Check all circut breakers etc- all fine
if you have 120volts at plug,chk for a breaker inside unit and again voltage inside unit at terms on cord,then if so chk motor for a breaker on the motor,some have built-in breakers,then check door interlock switch for continuity and proper operation, then if electonically controlled check for a fuse and burns on the circuit,you may have suffered a voltage spike,and do it soon,the power supplier may be liable if you can prove he disconnected the neutral and you only had 240volts,this could be a cause also as it becomes a voltage divider circuit w/o the neutral connected
Jul 29, 2009 | Dishwashers
Invertor connections to protect from utilty power backfeed
Inverters normaly have inbuilt protection built into them check for reset button/switch.
Jun 19, 2009 | ABB S272-k16 2-pole Miniature Circuit...
No power to dishwasher?
few possibilities......DEAD-need new one, not connected properly or needs new circuit inside dishwasher. Have you been able to test the power source? Is there power coming from the outlet hard-wire? if si is it the full 120v? Dishwashers require a designated line with a 20amp breaker. Without adequate amp thru the breaker to the line it may not operate to it's fullest or turn on.
May 03, 2009 | Kenmore 24 in. 16049 Built-in Dishwasher
SIR-S4040R will no longer power up (except the fan)
hold in the power button for at least 10 seconds. It should reboot. If not the DVR needs to be replaced.
Nov 12, 2008 | Samsung SIR-S4040R DirecTV DTV Receiver /...
Washer trips circuit breaker
Is washer relatively new? Check circuit breaker for proper size (20 AMPS). Washer must also be on its own circuit. It appears that when the motor starts up it is causing a spike in current (as with any motor), so the breaker is either undersized (Note that if breaker is undersized and you up it to the next size you would also need to replace the wire with the next size up which would be 12/2 with ground), or if you have had your washer a while which I believe is your case the circuit breaker is weakening and is tripping on the current spike. Try swapping out your circuit breaker with a new one and try running the washer again.
Sep 04, 2006 | Maytag LAT2600A Top Load Washer
Samsung SIR-S4040R DirecTV DTV Receiver / 35-Hours Video Recorder Logo
383 people viewed this question
Jerry Greenberg
Jerry Greenberg
