Question about PDAs
MP3-PD-6110 how do i remove unwanted songs from the 6110
0 characters
1 Points
You can simply drag the application to the trash and empty it. BUT, that method will leave any associated files on your Mac.
There is a freeware application named "AppCleaner" that you open and then drag an unwanted application onto it's interface window. AppCleaner will then scan your Mac for all files that are associated with the application you want to delete. You simply then choose which files for it to remove.
Do a google search for "AppCleaner", then download it from a trustworthy site (like CNet).
Hope this helps!
Sep 26, 2013 | Nokia 7510 Good Purple Cosmetics Wi Fi, Fm...
Why i put on my Lg like 215 song all mp3 and he only recognize 125 :(( it's so annoying
it may not be able to hold enough data for 215 song files. You can increase yur micro sd card upto 2 gb and styore more songs on their. If this isnt the problem, the file type of the songs ma not be compatible
Apr 01, 2010 | LG KU990 Viewty
How to play .rem music
Mr Dinesh
REM file extension appears when media files are saved to device memory and are not removed when the media file is transferred to a computer.
You cant change this..after transferring the media file to the computer, rename the file to remove the .rem extension.
I hope this info help full for you
Nov 11, 2009 | RIM BlackBerry Curve 8310 Smartphone
When you connect your phone to your pc it should appear as a removable drive (sometimes F) once you know what "drive" to send your files either drag and drop or right mouse over the song and send to "F: removable drive" . Also make sure it is an MP3 or a file the phone can use. Hope this helps.
Oct 30, 2009 | Samsung SGH-E840 Smartphone
I want more mp3 songs and how can i download from pc 2 my cp..
Hi I am bhavya Here's Your answer
By logging into
Jul 12, 2009 | LG KU990 Viewty
Format error
hi thanks for using fixya!
Try to reformat the MP3 player.
If you need further assistance, let me know.
Apr 19, 2009 | PDAs
I cant send mp3 music from my phone through bluetooth
in continuation to ronali's ans
after u activate bluetooth and all-------go to start-------programme------file explore----------select storage card-----------tap on option -------------beam file
Jan 12, 2009 | HTC Touch P3452 Smartphone
Cannot apply mp3 ringtones as ringers
U really need the phone tools disk to change your songs into useable clips. This phone won't play a full song as a ringtone, only clips. THe software is really easy to use and you can find it on ebay fairly cheap, just make sure to enter the correct phone into the software for correct support. Good luck!
Oct 22, 2008 | Motorola Mobility ROKR E6 Smartphone
MP3 Player
Nov 08, 2007 | PDAs
PDAs Logo
Top PDAs Experts
Are you a PDA Expert? Answer questions, earn points and help others
