Question about Vacuums
Mach 5 hoover turns off
I have a hoover mach 5 bagless that I purchased last year. Recenlty it began to shut off after a short amount of use. At first I thougth it was a short, but after awhile it will start again only to shut off a few minutes later. Is it overheating? If so is it something that can be fixed or am I out of luck.
  • ryanw Dec 30, 2007
    I have the same problem. I purchased my vacuum about a year ago also. I went through a detailed cleaning of the hose and connection tubes thinking something had clogged the hose overheating the vacuum. Unfortunately when I used the vacuum today, it worked for 10 minutes and turned off. Let me know if anyone has any suggestions
Just got a solution off another website. There is a pre motor filter about the dust collection container. I opened mine and it was very dirty. I washed the filter and you are supposed to let it dry out for 24 hours. Hopefully this will work. Another guy said it worked for him.
Posted on Dec 31, 2007
  • Len Sholtz
    Len Sholtz Apr 18, 2014
    Yes this works, clean after prolonged use or after you have vacuumed up fine powder.
It is a Hoover mach 5 runs a few minutes then shuts off no power laglass@sbcglobal.net
This sounds like a thermal limiter issue, usually caused by restricted air flow. Investigate until you find a blockage.
Dec 12, 2010 | Hoover U8145-900 Savvy Bagless Upright...
Hoover Mach 5 turns off after 5 minutes of using. Can you advise the problem?
5 minutes everytime? If so, raise brush all the way, and vacuum next to nothing. in fact, tilt vac up so the brush touches nothing. wait 5 minutes. If it doesn't shut off, your brush is set too high. if it does, the motor is over heating. make sure bag is empty, no debris in brush, filters clean and make sure you're not plugged into an outlet that a breaker on the outlet can pop too.
Sep 28, 2010 | Hoover U5194-900 Mach5 Multi-Chamber...
My mach 5 vhoover vacuum cleaner shuts itself off alsomst as though it is overheated
No your motor is going bad. Have you ever owned an electric fan. If you can remember when the motor started going bad on it the fan would quit turning on its own.Your vacuum is doing the same thing. Please call Hoover and order a new one or go to ebay type in the make and model..
Aug 27, 2010 | Hoover U5194-900 Mach5 Multi-Chamber...
Mach 6 shuts off
If the vac shuts off and then turns back on after waiting a while. could be a thermal fuse. it is in the motor compartment. recommend a pro shop service this issue.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Sep 27, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Hoove Cyclonic Bagless vacuum shuts off after only a few minutes
The motor has a protective overload cutout device to stop it from over heating - this can be caused by a blockage of some sort in the hose or brushroll compartment or blocked filters.
After checking the above and it still cuts out, take it back under gurantee
Sep 20, 2009 | Hoover U6630-900 WindTunnel Bagless...
Our Mach 5 turns off after running for about 5 minutes and smells hot!! Help!!! We have 3 kids and I need to Vacumn.
Hello:
Go here
Then find the clean filter section and clean all the filters especially the secondary filters. i think this will solve your problem.
Jul 07, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Hoover mach6 the brushes don't turn
Replace the skinny belt, but here's the kicker. turn the belt inside out so that the writing is on the inside and sits against everything. Thats what I did and I have used it once and it worked well, Lets hope it'll keep working.
May 20, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
My hoover mach 5 stopped during use and will now not turn on
If the machine overheats, a breaker trips. Most breakers reset themselves after they cool off. You may have a manual reset button to push on your model. The machine will overheat if the bag is too full, or if the exhaust port is clogged. The reset switch is usually on the back of the motor housing, near the footswitch.
Dec 22, 2008 | Hoover Commercial C1660-900 Bagless...
Hoover mach 5 only used 3 times
If the filters are ok, and there is no clog in the hose or dirt inlet down by the brushroll, then the motor protector is probably bad.
Mar 13, 2008 | Hoover Commercial C1660-900 Bagless...
Vacuums Logo
658 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
