Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Problem for Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Wont drain wont spin
By shellgranata on Oct 21, 2009
wont drain wont spin
Best Solution
posted on Oct 21, 2009
Very Helpful)
lilhelper
Rank: Guru  Washers & Dryers  Expert
Rating: 96%, 46 votes
This problem can be caused by a few things. first I would check the lid switch. You should be able to hear a clicking sound, this is the switch actuating. If you can't hear it, chances are you may need a lid switch. The machine won't spin but it should drain. part number for the lid switch is 8054980. The second problem could be that there is something caught inside the drain pump and now won't drain. It is also possible that the damage has already been done to the pumps impellers and can pump little or no water. If however you are hearing any sort of loud banging noise. this could indicate that your direct drive coupler needs to be replaced. part number for the coupler is 285753. These are common problems and can be easily diagnosed and replaced by a technician.hope this helps.
Thanks
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #2
Somewhat Helpful)
mrbyaninch
Rank: Master  Washers & Dryers  Expert
Rating: 75%, 4 votes
IS your lid depressing the lid switch? using a pencil push gently on switch when unit is on
Was this helpful?
Yes
No
Popular Solutions for Whirlpool Ultimate Care II
Questions and Unsolved Problems for Whirlpool Ultimate Care II
Do you recommend Whirlpool Ultimate Care II LSQ9549L Top Load Washer?
Answer
Answer
Water won't empty. Spin operates, other cycles don't all work. Hear a bit of an electric short sound... (More)
Answer
loud clank and slow speening even after i replace old clutch complite
Answer
replaced the motor coupling but the washer still makes a grinding sound and doesn't spin
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Whirlpool Ultimate Care II...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14885
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
