Question about Logitech Cordless Desktop MX3200 Laser Keyboard Mouse
KVM switch Previous to purchasing new wave keyboard, I used to double click scroll lock key to switch from one computer to another on my screen. How do I do that with this keyboard?
It might have something to do with the KVM Switch. Check that your switch will handle Keyboard shortcuts. If you are using the same KVM switch then you should be able to use the same short-cuts regardless of the keyboard you use.
Posted on Oct 27, 2008
How do you switch back and forth between computers on the KVM-02
try [scroll lock] [scroll lock] [UP].
To fast clicks on scroll lock and then the up or down key on the directionkeys on the right side of your keyboard.
If you have a wireless keyboard attached that can prove to be a problem to.
Best wishes :)
Feb 07, 2011 | Freedom9 freeView 2UA (KVM02U) 2-port KVM...
How can I connect my view sonic vp181 to two computers at once? Is there a way to do it without a kvm switch? A client of mine switches from one computer to another (monitor mouse and keyboard) by double...
Your client is using a KVM switch. Most two port KVM switches use a hot key such as 2 scroll lock presses to switch computers. You will have to connect your keyboard and mouse to the switch for it to work. You can get a KVM switch from many places on the internet for as little as $10-12.
I hope this helps, if so please rate our solution.
Corporate Computer
Jan 06, 2010 | Computers & Internet
Not working
Make sure your keyboard and mouse are plugged into the right USB ports on the switch. If you plug the keyboard into the mouse USB port the hotkeys will not work! The USB ports on the KVM switch are labeled under each port, with a mouse and keyboard icon respectively.From the Quick Start Guide/Manual: The Numlock hotkeys are listed as:
[Num Lock]+[-] [1] Switches to output 1
[Num Lock]+[-] [2] Switches to output 2
[Numlock]+[-] [A] Auto-scans and chooses which ever port is connected.
Alternatively: Tap [Scroll Lock] twice to automatically switch between ports.
Note: I've never been able to get the Numlock key combinations to work correctly. I always just use double-tap [Scroll Lock] trick to switch.
If you get stuck with your scroll-lock and Alpha lock lights flashing, just hit [Esc] to fix it.
Source: (Scroll down to "Quick Start Guide" and choose CS62U out of the drop down).
Oct 03, 2009 | Altusen Aten CS62U-2 Port USB KVM Switch
On my KVM switch it works pressing
Scroll lock key twice then
press up or down arrow
to toggle
Apr 11, 2009 | IOGear MiniView GCS612A 2-port KVM Switch
Users manual for KVM model ''MT-471s Auto KVM''
turns out if I double tap and hold the scroll lock key, the kvm rapid beeps and while in this mode, I can hit the numbers 1 to 4 to pick the port I want to connect to.
The double tap on the scroll lock suggestion was sent to me by a fixYa responder. Thanks,
Mar 19, 2009 | Computers & Internet
Don't have scroll lock on wireless keyboard/mouse combo, what other hot keys can i use?
You can try CTRL CTRL instead of scroll-lock. it was working for me. It is not mentioned in the manual.
Mar 10, 2009 | Belkin F1DK102P 2-port KVM Switch
About the belkin 2 port kvm switch
i already have one computer hooked up to a beklin. can i hook up another
Apr 09, 2008 | Belkin F1DK102P 2-port KVM Switch
Yes try uninstaling the kvm switch reboot pc's install the kvm again and try another key and see if that works
Jan 29, 2008 | JustCom jc-102cp 2-port KVM Switch
Two port kvm belkin
Switch to the First PC [Scroll Lock] [Scroll Lock] [1]
Switch to the Second PC [Scroll Lock] [Scroll Lock] [2]
Previous Active Port [Scroll Lock] [Scroll Lock] [Up Arrow]
Next Active Port [Scroll Lock] [Scroll Lock] [Down Arrow]
Switch Audio to the First PC [Scroll Lock] [Scroll Lock] [F1]
Switch Audio to the Second PC [Scroll Lock] [Scroll Lock] [F2]
AutoScan Mode [Scroll Lock] [Scroll Lock] [0]
Change All to the First PC [Scroll Lock] [Scroll Lock] [A] [1]
Change All to the Second PC [Scroll Lock] [Scroll Lock] [A] [2]
Other information:
In AutoScan mode, the switch remains on one port for 10 seconds before switching to the next. This time interval cannot be changed. To exit autoscan mode press [Spacebar].
When in AutoScan mode, no mouse or keyboard controls. If the user moves the mouse or uses the keyboard while switching the connection between computer and the switch might be interrupted and cause erratic mouse movement and errant display when using the keyboard.
Maximum resolution supported is 2048 x 1536 @ 75Hz.
If mouse movement is erratic:
make sure you do not have more than one mosue driver installed. Make sure that the driver is either for a standar PS/2 mouse or a Microsoft compatible PS/2 mouse. Make sure you do not have any mouse drivers loaded in your CONFIG.SYS or AUTOEXEC.BAT files. Avoid moving the mouse or pressing the mouse button when switching ports on the switch. You can reset the mouse and resume porper mouse movement simply by unplugging the mouse from the switch and allowing 2-3 seconds before plugging it back in.
Company information:
Nov 03, 2007 | Computers & Internet
Logitech Cordless Desktop MX3200 Laser Keyboard Mouse Logo
344 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
