DVR/TV connection Motorola DVR connects to 50" LG Plasma with HDMI cable. No Signal message out of nowhere. Checked with local cable provider signal OK to box. Changed to new HDMI cable same result. Tried standard RBG video and RW audio picture but no sound
    Sniper:
  • 59 Answers
With the RGB you have to run seperate audio ,I think you have ran the seperate cables for the sound but they are in the wrong place.try changing the RW from the DVR to the TV and you should get sound from them.The unfortunate truth about the HDMI is that the HDMI format has a problem effectivly communicating between components.I am a Directv certified High Definition technition and %50 of the TV's that I connect the HDMI to will not receive the signal.One trick that I have found that works is to make sure you have a picture on the RGB then connect the HDMI.Once you have these connected ,turn your TV off and unplug the power cord from the DVR for 30 sec then plug the DVR in and wait 5 minutes for it to power up then turn your TV on and switch to your HDMI input.This method sometimes works to "Jumpstart" the HDMI input on the TV .There is no guarantee that this will work but is sounds like for now this is your only option,GOOD LUCK.
Posted on Dec 30, 2007
My tv wont connect thru hdmi any longer
If you have only been using one cable it may need to be replaced or the HDMI port on the television may be broken. Check the port and make sure it is clean and if it still dose not work speak with a local tv repair shop
Mar 05, 2011 | LG Electronics 50PK750 50 1080P Plasma...
Hello I received a lg flatron plasma MZ42PZ14 and just wanted to connect the tv cable to the tv, but i can't find any coax on the tv. what can i do?
This kind of tv u must have cable or satalite tvs pay broadcasting signal cable,so u have a box .Tv have HDMI ports or RCA AV component cable input?The incomming broadcating tv signal go to the cable or satalite boxes.Than u use a HDMI cable or RCA AV component cable go through those boxes than to ur tv HDMI input ports or RCA AV component cable input holes.
Jan 22, 2011 | LG MZ-42PZ14 42 in. Plasma Television
The TV model is Sanyo DP32648. DVR Cable Box - Motorola DCT6412 III I have a DVR cable box connected via an HDMI cable to the TV's HDMI 1 slot. I have had the TV for around a year now and haven't had...
If you have the DVR connected to the TV with the Coaxial and the HDMI that is probably causing the problem I work for a Cable company and have dealt with this problem on numerous occasions. Try just disconnecting the Coaxial cable from the cable box that should fix this issue.
Dec 02, 2010 | Televison & Video
Flickering problem with our LG Plasma 60 ps4 when connected to hd
I had a problem similar to that. I couldn't get a full picture from my laptop or desktop. I went into the menu and hit the adjust screen. Now I have a full picture on my 50" plasma tv.
sawrepairman
Jul 23, 2010 | LG 60PS60 60 in. Plasma HDTV
I have a brand new LG 50 plasma and a Bravia Sony surround sound system as well as a Cox Cable HD DVR box. I currently have it connected as such: HDMI from Bravia Sony System direct into TV HDMI from Cable...
you may have to set the input value on the bravia for optical on the input from the cable box. sometimes there is more than one way for a particular input to receive an audio signal, you may have rca(red and white), a black or orange rca type for digital, and then the optical. i would suspect you have to tell the bravia how the sound is inputed into the bravia. also , just a thought.... on the cable box there should be a volume control on the front of the box........ make sure the cable box volume is ALL the way up (it is the preamp volume).
Dec 08, 2009 | LG 50PX5D 50 in. Plasma HDTV
Olevia 242 and Motorola DVR Cable Box switching
Have you tried using component cables instead. One of my Time Warner cable boxes did the same thing using HDMI.
Dec 01, 2009 | Televison & Video
Connect lifestyle 48 to plasma and dvr
You need to buy a Bose VS 2, video enhancer. Your cable/sattelite, vcr and aux connect to the VS 2 and the VS2 connects one HDMI cable to the TV. The VS2 then upconverts DVDs played on the lifestyle through the VS2/HDMI.
Sep 10, 2009 | Bose Lifestyle 48 System
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Televison & Video Logo
244 people viewed this question
Top Televison & Video Experts
