Question about RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
DCM 425 Modem
I just installed a LINKSYS Wireless G Access Point (Mod. #WAP54G) via ethernet cable from RCA Modem directly to back of LINKSYS. Then I slipped in a Trendset USB network adapter into my desktop PC. Perfect! All is well and works perfectly. The problem is I put a Belkin Wireless G Notebook card into my laptop slot and it just will not connect. Signal is great, it sees the network, but it won't connect. Any ideas?
  • 4 Answers
Check your wap, or wep keys. these can be checked on your wireless connection options or the wireless utily setup
Posted on May 02, 2008
Hi Support team, I use Modem Motorola SB100 with Linksys WAP54G, and DLink Wireless G DWA USB Adapter to connect to Linksys WAP from my PCDesktop. Connection from the PC to Linksys is ok but can't...
peter_picasa:
You cannot use a Wireless Access Point (WAP) to connect directly to your IPS's modem. A WAP does not provide the ability to share a single IP address on the internet like a router does.
Either return the WAP for a refund and buy a wireless router or buy an Ethernet wired-only router and plug the WAP into the LAN side of that router. You would then plug the WAN side of the Ethernet wired router into your modem.
Thanks for using FixYa.
Feb 20, 2011 | Linksys Wireless-G WRT54G Router
I don't know how to reinstall the linksys access point!!! Our wireless network that we made simply disappeared, so I'm trying to re-make one. However, when I tried that with a flash drive, it couldn't work...
T
o access the Access Points Setup, and the LAN IP address has not changed, then computer must have an IP address of 192.168.1.XXX. If the Access Point is plugged in via Ethernet to a Linksys Router and the computer is also connected a Linksys router via Ethernet, then the PC should already have a correct IP address (unless the LAN IP Address of the Router has been changed). If unsure, please assign the computer a Static IP Address so it will have an IP address in the same range as the Access Points IP Address.
If the Access Point is being connected to a hub/switch/router via Ethernet, then use the cable that was provided with Access Point. If the Access Point is being connected to the computer directly, then a Cross Over cable must be used. Cross over cables can be purchased at most electronic stores.
    Remember: When ever a change is made in the Setup of the Access Point, the Apply button must be used to save the settings to the Access Point.
  1. Open a web browser (such as Internet Explorer or Netscape)
  2. When the browser opens, go to the "Address" bar and input the IP address of the Access Point.
      Default IP addresses:
    • WAP11 v2.8 - 192.168.1.251
    • WAP54G v1.1 - 192.168.1.245
  3. A "User Name" and "Password" prompt will appear, leave the "User Name" field blank and input the Access Points password (The default password of a Linksys Access Point is admin) into the "Password" field.
May 14, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
Installing my wireless router
Setup by cable, Use Ethernet, then save.
Feb 28, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
SETTING WIRELESS
1. Shut off the power to your cable or dsl modem for about 30 minutes.
2. Connect the ethernet cable from your modem to the Internet port on the router.
3. After 30 minute power on ONLY the modem NOT the router
4. Wait about 60 seconds and power on the router
Try it now.
Oct 29, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
I hooked up a wap54g access point to a cat-5 line then connected to a router...but cant print to the printer on the network. any help?
If the wireless works okay, then you need to add the printer to your pc. Go to printers in the control panel, select add printer, and follow the prompts. If still no good , let me know if the make/model of the printer and whether it is connected directly to a pc on the network, or plugged into a router/switch with an ethernet cable.
Aug 08, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
My friend give me the linksys access point, but when i use it its paaaphrase, i dont know the key. can anybody tell me what to do????????? i m using the wireless access point first time,so i dont hv any...
First connect your router with ethernet cable with 1 computer .
Then access this link
http://192.168.1.1 or
http://192.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
then go t o wi fi security then go to encryptripn key it is your password.to connect netwrok
Jun 30, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Is my modem a WiFi router?
This RCA DCM 425 is a cable modem only its not even a router, its just a plain cable modem that is being provided by some cable company like Cox and Comcast, try searching again for a different box there they have a brnad name of Linksys, Netgear or Dlink because those are the common manufacturer of wireless router ...
Hope that helps............
Sep 18, 2008 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Need Setup CD for WAP54Gv.2 wireless router
perhaps this can help you
http://www.shooter.co.nz/Linksys_WAP54G_setup_procedures.pdf
Jul 14, 2008 | Linksys Wireless-G WAP54G 802.11g/b...
Linksys WAP54G connection to WRT54G
Ok, so why do you need an access point upstairs and a router downstairs connected wirelessly? If you can't connect with a laptop or a pc, why whould you think you could connect the access point? The purpose of this configuration would have to be with the access point to the router via ethernet. What's the point? If the problem is range, check out http://www.dd-wrt.com/dd-wrtv2/index.php to enhance the capabilities of the WRT54G... and maybe building a parabolic antenna for it as well. Plans to do so abound at Lifehacker.com.
Sep 05, 2007 | Linksys Wireless-G WAP54G 802.11g/b...
RCA DCM425 DIGITAL CABLE MODEM (RCADCM425) Logo
423 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
Jose Velazquez
Jose Velazquez
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
