Question about Logitech G7 Mouse
Logitech G7 Mouse problems
The pointer on my G7 wireless mouse freezes intermittantly on screen for no apparent reason, then comes back after some five to ten seconds...any clues
  • 3 more comments
  • WarDragon Jan 04, 2008
    cursor stops responding after 5 seconds it works again.
    It does this quite often and seems to be getting worse.
  • Anonymous Feb 15, 2008
    I have exactly the same problem; cursor freezes on screen for 3-5 seconds then restarts. It has been getting worse and happening more frequently ever since i first noticed it..
  • Anonymous May 19, 2008
    same problem
  • escapedg002 Oct 28, 2008
    Same problem here.
  • screwdriver1 Mar 09, 2009
    Yeah same problem. Mouse freezes randomly then starts again then freezes again after awhile. Pretty crappy for an expensive mouse.
This is a well documented problem with the G7.  Which sucks b/c this is the best mouse I've ever used.  Thankfully though the problem appears to be the battery contacts on the inside of the mouse just get pushed back with changing the batteries.  Solutions I've read about is putting a few layers of tape on the back of the battery to push the battery further forward agaisnt the rear stop.  A drop of solder on each of the battery contacts would also do the trick, but getting the solder to stick is a trick.  (If you try this, it is very bad to heat up a battery with a soldering iron, so be extremely careful).  A better solution is to take the mouse apart, a brief overview of disembly can be found here,
http://www.bitbenderforums.com/vb22/showthread.php?p=441061
Although since I didn't have teflon tape laying around...if you have used the mouse enough or just push a bit on the pads, you can see the outline of the screw holes, and just cut through the pad w/ an exacto knife.  The one under the label already had scored lines which made that one easy.  Once the cover is off I just used the tip of the exacto knife to pry the contacts out a bit more (remove the battery before disembling), cleaned the scroll wheel off, and put the mouse back together.  Works like new so far, which is good b/c from what I've heard Logitech isn't very good about replacing the mice w/o a recipt (which I think I lost after a week, nevermind 3 years).
Hope that helps, this really is the best mouse.
Posted on Jan 25, 2009
I've had the now infamous G7 intermittant freezing issues for over a year now, first with XP and now with Vista 64bit on a brand new OS install (same hardware). As others have noted there is a strong consenus that this is a hardware issue potentially related to multiple factors including radio interferance, battery malfunction / contact issues, usb power, etc.
Here is a list of things to try, any of which may (or may not) solve the problem:
1) unplug the usb transmitter from the adapter and plug it back in. This did the trick for me about 50% of the time. Sometime toggling the DPI buttons (the + and - buttons on the mouse) up and down also helps.
2) if the freeze gets so bad that the cursor wouldn't move try shutting down the PC, unplugging the cord to the power supply, toggling the power supply switch to discharge the motherboard capacitors, then turn on the PC and reboot.
3) clean the battery contacts. Remove the battery and use one side of a Q-tip soaked in isopropanol and clean the contacts on the battery and inside the mouse (the 3 prongs sticking out of the end of the battery slot). Make sure to use the dry end of the Q-tip to remove all of the isopropanol before sticking the battery back into the mouse.
4) if the transmitter is near a wireless router or other transmitter (bluetooth radio, modem, etc.) place it as far away from these devices as possible.
Posted on Apr 07, 2009
Had the same problem, contacted Logitech and they had me do the usual troubleshooting steps (try it on another computer, make sure most up to date software, does it happen in multiple programs, etc.), which i had already done but humored them nonetheless and they ultimately decided it was a hardware failure and sent me a new one. There is a 3 year warranty on the mouse from logitech so if you still have the receipt (or in my case the online retailer still had my invoice history) then with a little bit of work you can get a new mouse. Best of luck.
Posted on Nov 18, 2008
Why are my wireless logitech mouse suddenly responding intermittently?
If it has a base unit, press the button to pair with the mouse and then press the button on the mouse itself.
If it is USB transmitter type. With computer off, remove the transmitter, power up and then insert the transmitter.
You can also go to the Logitech website and make sure you have the latest drivers.
http://support.logitech.com/en_us/category/mice-and-pointers
Sep 23, 2015 | Logitech Computers & Internet
I use a Logitech G7 Laser cordless (RF) gaming mouse. The operation has become intermittent, with the mouse freezing, sometime every couple of seconds, sometimes every couple of minutes. I normally use...
It's possible the Firefly remote is interfering. It's also possible the mouse is going bad (G7s have been around for a while). I'd contact Logitech and see what they can do for you - their warranty support for mice is terrific.
Feb 28, 2011 | Logitech Inc G7 Cordless Laser Gaming...
Pointer on a G7 logitech mouse and win vista 64 pointer will not access any buttons I am trying to access and its like someone else is taking control I try to enter a message and use the click symbol on...
Dirty lenses. Simply clean the lens with a cotton bud and some clean alcohool or.. replace the mouse.
Rechech if the mousepad is not a shiny refflective surface like glass. Try a sheet of paper under for test
Dec 14, 2017 | Logitech G7 Mouse
Mouse Is Recongnized but wont Move
On the bottom of the mouse is a little tiny button that say: connect or reconnect. Place the mouse close to the transmitter dongle (the do hicky comes out of a USB) and look for that button on the transmitter and the mouse to reconnect the signal.
(batteries are good ?)
May 14, 2009 | Logitech 9313960403 Mouse
Eratic pointer movements with wireless mouse
Hi
Uninstall the mouse software from the device manager, if not resolved need to change the mouse
With regards
Apr 19, 2009 | Logitech 9311570403 Mouse
My wireless mouse freezes
I had a similar freezing problem with a wireless Logitech mouse and also a problem with the wireless keyboard, sometimes keystrokes would not register and sometimes they'd repeat a dozen times.
I was not able to fix the problem, so I got a Microsoft wireless mouse and keyboard, hoping it was a driver conflict that wouldn't affect both products. Wrong. The exact same thing happened to the Microsoft mouse and keyboard.
The cause of the problem turned out be that I had the receiver plugged into a USB hub along with several other devices. Moving the receiver to one of the USB ports in the back of the PC fixed the problem.
Apparently these wireless desktop devices don't like sharing USB resources with anything else.
Apr 17, 2009 | Microsoft Wireless Optical Mouse USB...
Wireless keyboard and optical mouse
Thanks! I fixed the problem by installing a USB mouse and using fn+f9. That unlocked the mouse so I could use the pointer leaving just the keyboard problem. I then tried reconnecting the wireless keyboard (by using the button on the receiver and under the keyboard) Hey Presto!!
Feb 02, 2009 | Logitech Wireless Access Duo Optical...
POINTER FREEZES THEM MOVES THEN FREEZES DRIVING ME NUTS. THANKS
When this behavior is observed when using a Logitech product withinWindows® XP, it may be caused by a feature within Windows called"enhanced pointer precision". This feature may conflict with Logitech's software, causing the erratic movement. Enhanced pointerprecision became available in Service Pack 2 and therefore is notapplicable in any version of Windows® XP without Service Pack 2installed. For more information on enhanced pointer precision,please click HERE. If this link does not work, then you should go to Microsoft and search for Knowledge Base article 895550.
Please see these articles from the Logitech database for possible troubleshooting tips as well:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=970
Troubleshooting: Erratic Cursor Movement in Optical Mice and Trackballs
Mouse cursor is uncontrollable or behaves erratically
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> Interference with Cordless Products
Download latest version of software
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. – I would greatly appreciate a FixYa!rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Nov 27, 2008 | Logitech Cordless Mouse
G7 Wireless Mouse keep double clicking
Same Problem, use canned air to clean it. bash the button a few times. seems to help for a while. Dont bash it to hard or you'll break it. love the mouse but this is a crappy issue within 3 months of use. in a clean environment.
Dec 08, 2007 | Logitech Inc G7 Cordless Laser Gaming...
Logitech G7 Mouse Logo
3,959 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
