You'll first need to obtain the IMEI or ESN (both basically mean serial number, but depending upon who the carrier is, it will have a different name). You can do this by removing the battery and looking at the sticker located on the back of the phone. There will be several numbers on this sticker, but only one labeled an IMEI or ESN.
Next, contact the provider/carrier the phone is locked to currently. You'll see their name or logo on the phone somewhere. Some common ones are AT&T, Verizon, and T-Mobile. Provide them the IMEI or ESN and they will provide you with the unlocking code as well as HOW to put in the code since all phones are different.
Hope this helps! :)
SOURCE: HELP WITH VERIZON BLACKBERRY STORM 9530
crackberry.com if the app is available they will have it for download
SOURCE: want to unlock my verizon blackberry storm 9530 free codes
Don't waste your time, looking for free codes. Unprofessional work can only destroy your phone.
There are different online services that will calculate the unlock code for your Blackberry for only few bucks. I can recommend this one (cheap and reliable).
Click here to unlock your BlackBerry Storm.
Note: don't share your IMEI number on free forums like this.
SOURCE: my blackberry storm 9530 is locked to verizon
So you will need blackberry storm 9530 unlock code for verizon network. This code can be obtained from verizon or you can purchase at blackberry unlock code retailer on internet.
SOURCE: My blackberry 9530 verizon shows
Actually there is no clue to reset mep counter back to 10, the only things that you can do to unlock blackberry 9530 network by using blackberry unlock code. This code will reset your phone network to default factory setting so you can use any sim card in your phone.
SOURCE: I need MEP Code to
As far as i know unlocking by codes is the simple and safe way.You will need the unique MEP Code for your Blackberry storm 9530 and to get it you can use a website with service for Blackberry unlocking .so you can use a website to Unlock your Blackberry storm 9530 online instantly - OR local mobile shop .they are mostly using cables to unlock it and the price is higher then on unlocking websites but the result is the same: SIM free Blackberry.
