Question about Canon DC210 DVD Camcorder
I record then put dv rw in computer and nothing
So then i go to my computer and open the cd drive and it says the disc is currupted or not compatable with windows???? now i know it is not scratched------ so then i try another disc and when i got to open the drive this time it says e is not accessible incorrect function---- same type of disc not scratched either now i use the disc that was in the camcorder when i got it cause someone returned it an i can whatch the videos the people had before me in windows gallery -this is a rw disc as well ....... so now im puttin in one of my dvd r 's and the disc is full but when i try to open the drive it says please insert disc into cd drive e ---what the fu****........................tried to import to gallery n everything i still get nothing ------- so i can whatch the peoples videos that returned the camera but i can't whatch mine this sucks
Re: i record then put dv rw in computer and nothing
You have to finalize the cd before taking it out of your camcorder. check the user guide on how to finalize it.
Posted on Jan 02, 2008
0 characters
3 Points
How to finalize a CD-R disc
If you did make a audio CD, the toaster (CD R burner) should have finalised the CD.
But not all CD players are compatible with the CD R's. A normal CD has a metal coating as reflective coat. CD's and DVD's you make yourself only have a dye that is changed from colour, by a laser. Older CD players can't read the digital info. Newer players for that reason have a logo CD R and CD RW compatible.
If you think you did not finalise the recording, you should try to do so in the computer you made the CD in the first place. Using the same program choosing finalise.
Jul 15, 2014 | Video Cameras
Describe your Hitachi DZ-MV580A DVD Cant Read Discs ERROR 2881
here is the instruction manual for it,go through it carefully and u will find the sol.
Click here to download
Dont forget to rate me as fixya..
Jan 31, 2008 | Hitachi DZ-MV580A DVD Camcorder
Dvd-r or dvd-rw discs not recognised
my computer not reconocing tha sofware of my camera, not open fails.disk of sofware is error help me please
Aug 12, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
I want to delete a part of what I recorded on my Handycam before I finalize it
I'm confused by your ?-you state you have a HC14 Mini DV cam which is tape but your asking about dvd-if you have dvd you can only delete on rw discs-not r type-doesn't matter before or after just won't work-if not transfer to computer and edit that way and reburn new dvd
May 25, 2008 | Sony Handycam DCR-HC14E Mini DV Digital...
Format a cd
First some explanations:
The Canon DC210 will only take 'minus' format DVDs (DVD-R, DVD-R DL and DVD-RW). Only the DVD-RW must be formatted (initialised) before use. During initialisation you'' be asked whether you want to initialise the disc in VIDO mode or in VR mode.
VIDEO mode: Once finalised discs recorded in VIDEO mode can be played back in most common DVD players, offering the best compatibility. However, recordings cannot be edited (deleted, rearranged etc) on the camcorder.
VR mode: You can easily edit the recordings on the camcorder. However, discs recorded in VR mode can only be played back with DVD players that are compatible with DVD-RW discs in VR mode.
My preference is Video mode - I can then play the disc on a DVD player and edit it on a PC.
Now, to initialise a DVD-RW
1. Press the 'FUNC.' key
2. Use the joystick to select 'MENU' - it's in the bottom left corner of the screen
3. Use the joystick to select 'DISC OPERATIONS'
4. Use the joystick to select 'DISC INITIALIZE'
5. Use the joystick to select either 'VIDEO' or 'VR' mode
6. Use the joystick to select 'YES' to confirm your choice
7. Use the joystick to select 'YES' to start initialising the disc
Close the menu only after the screen display returns to the 'DISC OPERATIONS' menu.
Don't forget to rate this solution once you've tried it !
May 11, 2008 | Canon DC210 DVD Camcorder
Burning DVD
try DVD-R Dics the manual says not compatable with +R.
Jan 13, 2008 | JVC Everio GZ-MG130 Camcorder
Sony DCR-DVD 108 disc won't play or record
Movies shot DV Camcorder forms mpg files when down loaded in computor and can not be converted to a CD. Problmes comes in conversion of mpg files to AVI, WMV, AVSEQ or MPEG2 etc.
Oct 29, 2007 | Sony Handycam DCR-DVD108 DVD Camcorder
Connecting to computer
You should have got a sofware disc with the handycam when you bought it.if you load the disc it should accept the video on usb.if you dont have the disc try sonys website for software,.
May 15, 2007 | Sony Handycam DCR-HC36 Mini DV Digital...
When should I use a DVD-R / DVD-RAM / DVD-RW?
Write Once – After finalizing, a DVD-R disc can be played back in approx. 95% of home DVD players and PC DVD drives Capacity – 30-60 minutes (depending on the selected filming mode) of high quality motion video can be stored on a single of a disc. Re-writeable – DVD-RAM allows for recording and re-recording of movies and still photos up to 100,000 times per disc. DVD-RAM is like a removable hard drive. Compatibility for video playback of DVD-RAM in standard home DVD players is fairly low. DVD-RW cannot store true .jpeg digital still photo’s like DVD-RAM, however it is re-writable and has 80% compatibility with home DVD players.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Canon DC210 DVD Camcorder Logo
150 people viewed this question
Top Canon Video Cameras Experts
Sheryl Bahr
Sheryl Bahr
Chris Phillips
Level 1 Expert
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
