Kenmore 4292x Front Load Washer
Problem for Kenmore 4292x Front Load Washer
How to replace below on he3 washer
By eightsaints on Oct 21, 2009
to replace bellow
Best Solution
posted on Oct 21, 2009
Very Helpful)
jsrock516
Rank: Guru  Kenmore Washers & Dryers  Expert
Rating: 96%, 7173 votes
If you are attempting to replace the door bellow on a Kenmore Elite front loader, the following link explains step-by-step how to replace one:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Read through the link provided and let me know if you have any questions.
NOTE: There is another method you may try as well. Although I do not prefer this next method because these washing machines are very heavy, an alternative way of replacing the door bellow is to remove the lower toe panel and tilt the washer back at a 45 degree angle instead of removing the washer front panel. If you use this method, make sure it rests against the wall and will not tip forward. This allows the wash tub to drop down and away from the front panel and gives you access to the the rear bellow clamp through the bottom. This can save you some time. Thanks to user DGBG for the helpful tip!
If you would like some helpful exploded view diagrams of your washer that you can reference, you can use any of these web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
Just use your model number to begin your search criteria.
If you have any questions, please let me know. I hope this helps you.
NOTE: These door seals do wear out and require replacement from time to time. However, overloading the washer to the point where items get caught in the door area can contribute to premature wear and tear.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" very helpful. ichanged the bellows without difficulty thanks " - eightsaints
Popular Solutions for Kenmore 4292x Front Load
Questions and Unsolved Problems for Kenmore 4292x Front Load
Do you recommend Kenmore 4292x Front Load Washer?
Answer
Answer
I have a Kenmore 42922 washer that keeps having the belt fall off. This happened twice now in the... (More)
Answer
I just moved Kenmore Elite HE3t Mod No, 110 42926 200 front loading machine. I am trying to wash my... (More)
Answer
my washing machine is leaking water from the bottom of the drum
Answer
My new "low water" washer does not use enough water to get the clothes clean. I have... (More)
Answer
my washing machine spin cycle doesnt work it doesnt drain nor does it spin on any of the cycles but... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
