Question about KitchenAid KWVU205YBA Kitchen Hood
Lights & Fan Don't Turn On
The light and fan will only function when the sliding hood has been pulled out about 2". Any other location and nothing will work. I figured it was the microswitches in the sliding track. Nope that didn't do it. I am now leaning to replacing the electronic switch membrane. Anyone have any experience with this? Thank you.
2 Suggested Answers
  • 833 Answers
SOURCE: Fan runs continually
Could be. Cut off the power first. Remove the fan box cover and discover the switch location. If you have a continuity tester, you should be able to test the switch. Sometimes, they even jam with cooking grease. If in doubt, replace it.
Posted on Dec 09, 2007
High and Medium don't work, only low
Check your capacitors to see if they're bad. That's the black box near the pull chain switch with wires going to the switch. If bad call 1-888-830-1326 Hunter parts.
2 wire part # 74132-01-000 ( probably not this one)
Other capacitor part # 74133-05-000 (probably this one)
Jun 02, 2013 | Hunter Dryers
Tip
How to disable LED light in a CPU fan
<p>Some desktop computer towers, also known as a processor with decorative LED lights on the fan. LED means light emitting diodes. This is a small, lightweight, durable savings of energy that goes into a variety of colors. It connects to a device with two metal terminals of the connector is similar to a power cord. This can affect a beautiful, but can also be irritating. If the computer in your bedroom at night, these lights can affect your sleep, so it's important to know how to turn off the LEDs on the fan. <br /> <p><br /> <p>1. Remove the computer side. Tighten the screws on the side of the CPU. Slide the face up and away from the side of the CPU. This ensures that the fan and the LED lights on the computer. <br /> <p><br /> <p>2. Pull the LED on the bottom and away from the fan with a plier. Hold the head with an LED light pressure and drag it to yourself. It is easily accessible from the release of the fan, because it only comes with two small clips. <br /> <p><br /> <p>3. Flip the CPU. Slide the side in the slots on the CPU. And tighten all the screws through the holes on the side of the CPU, making it in a clockwise direction. <br />
on Jun 22, 2011 | Computers & Internet
I have a hunter ceiling fan model 23898 which has a dimmer switch built in one day a light bulb blew out on it and now we cannot turn off the lights with the switch the only way is to loosen the bulbs in...
Has anyone found a solution for this problem? I have tried a bulb in each light socket and attempted to use the pull/dimmer switch that is on the fan itself. The lights no longer dim nor turn off. I have unscrewed all of the bulbs and tried each bulb in each socket one at a time and still nothing. I have also taken the pull switch out of a different hunter fan to put into this one, hoping that atleast the lights would turn on and off. Still the lights won't turn off using the pull switch. I am out of ideas.
Sep 11, 2011 | Hunter Ceiling Fans Individual...
Nissan Quest 96 Engine running hot
In the fuse/relay box under the hood in front of the battery are 3 fan relays. 1 for low speed, and 2 for high speed. 1 of high speed is back up. check the relays first.
B3 CHECK FUSES
  • Key OFF.
  • Check the 10A RELAYS fuse located in the interior fuse junction panel and the 65A RAD FAN fuse located in the main fuse junction panel. (engine compartment)
pLease rate as fixya if this helps. good luck
Mar 10, 2009 | 1996 Nissan Quest
Range master 50000 exhaust fan stopped working
Extremely likely the fan motor.  get to it then , after removing fan blade,plug it in directly to a 110v  outlet ,just for a second to see if it works well( don;t touch it while prefoming this test,only the plug), or jumper out the switch(with electric disconnected) momentairly to see if the fan runs after turning the electric back on.
Jan 07, 2009 | Rangemaster Kitchen Hood
Fan and remote not working
make sure the main switch is on ,also the chain switch on ,before using control remote!!
Dec 23, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Range Hood Issue
Definetly need a new motor control.
Nov 26, 2008 | Kitchen Ranges
New fan not working but lights work
There is less than 120v getting to the fan. Its possible that the lights will turn on etc. Take an extension cord and plug it in another plug and grab both power wires from the fan and stick them in other end of extension and I do service calls for broan & Nutone
Jean-Marc
try it out. Im sure your not getting 120v completelty.
Feb 05, 2008 | Broan-NuTone Allure QS130SS Kitchen Hood
Broan allure II range hood
Did you ever find out what blew the fuse originally? Do the lights have a dimmer feature on them? If so, the reostsat may be bad, or the switch that controls the light intensity, 1,2,3. ect. Something caused the fuse to blow, maybe a wire on the bulb or switch somewhere.
Dec 20, 2007 | Broan-NuTone Broan Range Hood Accessory
Broan Allure II
I called Broan technical support. They said that they had heard of this issue before, but that there was no recall. I suggested that it was a frequent enough problem for it to come up 3 times in 12 mo. on one website. She was underimpressed with this statistic and said that they sell millions of them. She would not disclose the name of their supplier so that I could get some information on the actual controller unit. She did not seemed as pained as I was by having to part with $130 for a new controller.
Jan 30, 2007 | Broan-NuTone Allure II QS230SS Kitchen...
KitchenAid KWVU205YBA Kitchen Hood Logo
61 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
