Question about Sony KP-57WV600 57" Rear Projection HDTV-Ready Television
What's wrong with TV?
LED light flashed at times, then TV would cut off. Now the screen is all reddish.
  • rebtop Jun 11, 2008
    Well it happened to me. The reddish screen stay on for about 20 seconds and then goes blank.
    Bob Black
    Problem Solver:
  • 11 Answers
Go to this site, follow the instructions, and it may fix your problems. I did, and my tv is better than ever!
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
I was having this problem with blue. I was able to fix it, and now my tv works again. For those having trouble removing a different front panel, here is what I found on mine -
I own a KP57WV600. Removing the front panel is a little trickier on this model. You remove the 6-8 screws on each side behind the two speakers. You will access these from the lower rear/sides of the TV. Remove the small 2ft plastic pieces. Now from the front of the machine grab the entire lower piece (speaker covers & power/volume/chanel buttons) from the bottom and pull down and towards yourself. There are 4 slots that this piece fits into. I had to take off the lower back panel to see why it wouldn't come out. Don't pull to far because this lower front piece is connected to wires. I'd say you have about a foot of play. Now you can remove the fiber board panel and access the blue/green/red lower screws. When you adjust these, go a fraction of a milimeter at a time.
Posted on Apr 09, 2008
    President:
  • 4,402 Answers
How many times does it flash?
i suspect a bad red tube
sony has a recall on the tubes
http://esupport.sony.com/perl/news-item.pl?news_id=24
Posted on Jan 07, 2008
What's wrong with my LG 55LV9500 LED TV? Power on, black screen.
Hello, either the power supply is failing to power up the LED's or the LED strips in the screen have failed, a common issue with these sets. Power supply part # is EAY62169701. LED strips are only available as a complete screen assembly from LG....thanks
Apr 23, 2017 | LG Televison & Video
Whats wrong with my hl61a750a1fxza tv it wont come on led light flashes then i hear a click and all three lights start flashing.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sep 06, 2014 | Samsung Televison & Video
Tv turns on a second, LED flashes
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Mar 19, 2014 | Insignia NS-P42Q10A Plasma TV
1 dg board, (stv 5v sense time out). ........ive
To pettinabatem
I am having a shutdown problem with a Panasonic TC-32LX50. Initially when pressing the on switch, you see for 1 second a right half white screen (the left side of the screen remains black) and the TV turns off and the LED flashes 1 time. I did a T-Con cable check (based on the half white screen) and indeed this went away. Got backlight (full screen and no half white screen anymore). But still the TV shuts down after 1 second and the Red front LED flashes one time. Since this code is also illustrating a "dg board, (stv 5v sense time out)" problem in this unit, I was wondering if indeed you have encountered a defective DG board with yours. I am enclining towards a defective Power supply board.
Jun 27, 2011 | Panasonic Televison & Video
THE TV IS CUTTING OFF BY ITSELF AND THE OPC LIGHT IS BLINKING
This problems very common on Sharp Tv.Do ur tv LED power light turn on solid first.Few mins,than LED,OPC flahes.Power LED,OPC flashes,push power button again,do this at leat 5 or 6 times somtimes the backlight will come back on and work.The power LED,OPC light flashes,turn off/on more than 5 or 6 times don't work.Ur Tuner signal board is dead,must replaced.
Mar 30, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Power green light will flash then flash red when first turned on
Please intimate exact model of your Sony TV to find out reason of no power up.
Jul 09, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Reddish screen on sony wega kv-28fx68 100hz trinitron
it sounds like a b+ cap going bad and is intermittant that feeds the the video drivers on the crt pcb or the crt is shorting.
Oct 14, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KP-57WV600 57" Rear Projection HDTV-Ready Television Logo
106 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
